| quote | Originally posted by streetrod1:
I'm curious about what people are doing for exhaust on ls4 swaps. What manifolds or headers are you running? I'm having a cradle built but they don't notch it for any exhaust. Will I have room to run one side over top. Its had me so concerned I have been looking at cheap pipe benders in hopes I can mock it up myself. I'm in a rural area and my exhaust man an hour and 20 minutes away does wonders. I hate the idea of hauling it there and then you still got bugs and tuning to work out so you haul it back. If I can figure out exhaust it will make this project much easier. Knowledge is power so I am open to ideas and pictures too. i'm running a carb and 6014 for timing.. so i may have a lil more room up top. GTO MANIFOLDS OR HEADERS? I know headers are nice and pretty.. but if they are not long they truly do lil lol except leak. A good cast manifold and oem gasket is my ideal choice. What about a turbo style manifold. When I got my engine it was a low miles pull out from years back..it has manifolds. but thats it..not the over top crossover i keep seeing. Im kinda old school I would rather run two tiny mufflers than one big muffler..i was thinking maybe 2 cats just to muffle noise and no mufflers..we will see..I had a chris moore northstar car with just hipo cats and gt tips and it was loud but not super loud. I dug it lol. Also on a side note will an LS2 timing cover work on ls4..im curious. |
Hi, have fun with your swap. The LS4 is a good swap.
For the record I live in California so I was forced to use the original exhaust manifolds and cross over pipe. All of this was unmodified with the exception of header wrapping. I did the header wrap under the original heat shields because I wanted the heat protection and stock look. I used the original cat also, but this was modified to orient it transversely. I did not cut out any of the trunk but I did use a big hammer to make a dent for clearance. I did not use mufflers, but I did weld 6" glass packs to the exhaust tips.
There just isn't a lot of room for multiple cats and mufflers but some people cut out the bottom of the trunk.
I have pictures in my build thread in the Construction Zone.
