  Other Cars
  Radio reception
Radio reception by Robert Barth Jr
Started on: 06-23-2021 06:43 PM
Replies: 3 (102 views)
Last post by: Jake_Dragon on 06-23-2021 11:29 PM
Robert Barth Jr
Report this Post06-23-2021 06:43 PM Click Here to See the Profile for Robert Barth JrSend a Private Message to Robert Barth JrEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a radio reception problem on an 89 corvette. Engine not runningradio is crystal clear. Engine running radio reception is gone. Anybody have any ideas? Thanx
Total ratings: 403
Report this Post06-23-2021 07:27 PM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is it radio only or do you have the same issue playing from other sources?
https://www.crutchfield.com...tallation_guide.html
Ground wires would be my first go to.
I also had an issue with a bad alternator.
If its just the radio then check the antenna cable for any damage, if its grounding to any part of the chassis it could be your issue.
TM_Fiero
Report this Post06-23-2021 07:40 PM Click Here to See the Profile for TM_FieroSend a Private Message to TM_FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know enough about Corvettes throughout the different generations, but at least earlier ones had special shields over the distributor and wires for the specific reason of reducing radio interference. You may want to see if that was still in use for your Corvette and if so you have all the proper shields in place.
Total ratings: 403
Report this Post06-23-2021 11:29 PM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
My bet is on the alternator. Had an 84 and the alt was always making my system freak out
