  Other Cars
  Lebaron Fuel Issue (Flooding)
Lebaron Fuel Issue (Flooding) by heypal
Started on: 10-14-2021 09:13 AM
Replies: 5 (91 views)
Last post by: LitebulbwithaFiero on 10-19-2021 08:49 AM
heypal
Report this Post10-14-2021 09:13 AM Click Here to See the Profile for heypalSend a Private Message to heypalEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I recently bought a '90 Lebaron convertible. It has sat for a couple years. 3.0 V6. Turns over but does not start. Fuel pouring out of the throttle body. Bad fuel pressure regulator?
LitebulbwithaFiero
Report this Post10-14-2021 12:57 PM Click Here to See the Profile for LitebulbwithaFieroSend a Private Message to LitebulbwithaFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have not worked on any Chrysler's, but I would think there would be a shrader valve some where to hook a fuel pressure gauge to.
I assume this is throttle body injected?
Could be an injector stuck open?
heypal
Report this Post10-15-2021 09:00 AM Click Here to See the Profile for heypalSend a Private Message to heypalEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, it's multi port. Very similar to the set up on the 2.8L Fiero. However, Chrysler doesn't provide a schrader valve to attach a gauge. Jerks.
LitebulbwithaFiero
Report this Post10-15-2021 03:55 PM Click Here to See the Profile for LitebulbwithaFieroSend a Private Message to LitebulbwithaFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like injectors stuck open more so then fpr.
How much gas is in the oil?
heypal
Report this Post10-18-2021 05:37 PM Click Here to See the Profile for heypalSend a Private Message to heypalEdit/Delete MessageReply w/QuoteDirect Link to This Post
A fair amount. When I pull the dipstick, the level is about 1/4" above the full line and the color is fairly light. Should the injectors be pulled and cleaned?? The plenum is currently off (in order to pull the FPR) the engine so they would be easy to pull at this point.
LitebulbwithaFiero
Report this Post10-19-2021 08:49 AM Click Here to See the Profile for LitebulbwithaFieroSend a Private Message to LitebulbwithaFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is up to you. It can be hard to find a place to clean and test them. And they may be fine already.
On some cars, the injectors are retained well into the fuel rail. This allows to pull the injectors out of the manifold and pressurize the fuel rails to see if the injectors are holding.
