  The Other Mall
  WTB -- Your Fabrication Services
WTB -- Your Fabrication Services by Notorio
Started on: 08-26-2021 01:57 PM
Replies: 5 (522 views)
Last post by: Notorio on 10-15-2021 11:50 AM
Notorio
Report this Post08-26-2021 01:57 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
To the Fabricators on the Forum, I'm looking for your help on a small job for my business. I'm returning to my roots as a cleaning formulation designer and am firing up an antique scrub tester where I can test soiled ceramic tiles. What I need fabricated is a shallow, stainless steel tray to hold the test run-off from the formulations (most will contain 3-5% chlorine bleach) and then some rinse water. Please see below for a picture of the set up and a diagram of the tray and then send me a PM for what you would charge. Thank you!
Trinten
Report this Post09-10-2021 09:49 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you haven't already -- just in case they don't check this forum, I would say it's definitely worth reaching out to Will and FieroGuru. I believe they both have all the equipment to make that. I know they are both busy, but this doesn't look like a time consuming project - just limited by needing specific equipment.
Notorio
Report this Post09-10-2021 11:56 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you very much for the tip! I shall definitely contact them.
Total ratings: 236
Report this Post09-12-2021 10:45 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
I received your PM. Thanks for thinking of me!
Is this a business or a hobby?
I imagine if you're running a business, your needs will change over time and you'll want to modify, expand or enhance the capabilities of your test apparatus. To that end, you're better off finding a local sheet metal shop that will do small jobs like this, and establishing a business relationship with them. Then you can just... go there when you need updates to your apparatus. It would be a heck of a lot more expeditious from a business standpoint to work with a local vendor on this.
Edit: I searched google maps for "sheet metal fabrication temecula, ca" and saw at least a dozen results. Some of those will be HVAC shops, but some also looked like hot rod/chassis fabrication outfits. There's gotta be one of those who likes small jobs for a few extra $$$.
Edit 2: For example... do you want to add a drain fitting to your tray? Easy to have a local shop do that
[This message has been edited by Will (edited 09-12-2021).]
87_special
Report this Post10-14-2021 09:00 PM Click Here to See the Profile for 87_specialSend a Private Message to 87_specialEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm in San Diego and can make it. PM sent.
Notorio
Report this Post10-15-2021 11:50 AM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the contacts everybody. I did take Will's advise and find a local shop to do the job. But I also now have some back-up contacts for future work so I'm all set.
