  Neutral Safety switch
Neutral Safety switch by shruggernaught
Started on: 05-29-2020 01:34 PM
Replies: 7 (2104 views)
Last post by: Gall757 on 06-01-2020 12:32 PM
shruggernaught
Report this Post05-29-2020 01:34 PM Click Here to See the Profile for shruggernaughtClick Here to visit shruggernaught's HomePageSend a Private Message to shruggernaughtEdit/Delete MessageReply w/QuoteDirect Link to This Post
When trying to start my 1986 V6 SE 4speed I have to press my clutch pedal so hard it feels like I'm going to push the pedal through the floor board, but once it has started and I'm driving and switching gears its like the breeze. Any Help? Is it my neutral safety switch or something more difficult?. Its getting so bad I almost stranded myself last night.
FX
Report this Post05-29-2020 01:45 PM Click Here to See the Profile for FXSend a Private Message to FXEdit/Delete MessageReply w/QuoteDirect Link to This Post
...The switch is adjustable...
shruggernaught
Report this Post05-29-2020 01:46 PM Click Here to See the Profile for shruggernaughtClick Here to visit shruggernaught's HomePageSend a Private Message to shruggernaughtEdit/Delete MessageReply w/QuoteDirect Link to This Post
So how do I go about adjusting it?
LoveBirds
Report this Post05-29-2020 03:18 PM Click Here to See the Profile for LoveBirdsSend a Private Message to LoveBirdsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can view/download lots of manuals here: http://www.fieronews.net/fusion/downloads.php
I thought only the auto trans had a neutral safety switch?!
Report this Post05-29-2020 03:30 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, yes and no. It's called a clutch safety switch on manual transmission equipped cars.
...it feels like I'm going to push the pedal through the floor board, but once it has started and I'm driving and switching gears its like the breeze. Is it my neutral safety switch or something more difficult?
Not sure what the safety switch has to do with "switching gears"? Your issue is simply starting the engine, not disengaging the clutch, right? In other words, when you turn the ignition key to Start, often nothing happens until you "push the (clutch) pedal through the floor board"? If so, yes, it's a simple adjustment of the clutch safety switch.
[This message has been edited by Patrick (edited 05-29-2020).]
FX
Report this Post05-30-2020 01:35 PM Click Here to See the Profile for FXSend a Private Message to FXEdit/Delete MessageReply w/QuoteDirect Link to This Post
shruggernaught... Look at the clutch pedal arm, for the switch. Unplug it and screw the switch in or out. In your case it would seem you need to screw it in so it activates sooner...
shruggernaught
Report this Post06-01-2020 11:42 AM Click Here to See the Profile for shruggernaughtClick Here to visit shruggernaught's HomePageSend a Private Message to shruggernaughtEdit/Delete MessageReply w/QuoteDirect Link to This Post
What do you mean by "screwing it in"?
Report this Post06-01-2020 12:32 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
