  4T60 vs 4T60E How to tell them appart
4T60 vs 4T60E How to tell them appart by BrittB
Started on: 05-26-2014 10:26 AM
Replies: 10 (717 views)
Last post by: fieroguru on 05-27-2014 08:00 AM
BrittB
Report this Post05-26-2014 10:26 AM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I'm out shopping for a 4T60, how can I spot the difference between it and a 4T60E? Also, what are the clues as to if it may be a 4T60HD?
Total ratings: 290
Report this Post05-26-2014 11:02 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
4T60 has a 5 pin weatherpack connector on it.
4T60E has a 7 pin metripack 'round' connector on it
Sorry I didn't have a 5 pin weatherpack connector but the 4 pin connector show is a weatherpack connector. The two to the right are the 7 pin metripack connectors.
[This message has been edited by phonedawgz (edited 05-26-2014).]
BrittB
Report this Post05-26-2014 11:13 AM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very nice! Does the trans have any external markings like 4T60 on it?
Total ratings: 463
Report this Post05-26-2014 12:34 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 4T60 will have a connection for a TV cable, while the 4T60E will not.
Note that they BOTH have vacuum modulators.
Report this Post05-26-2014 01:50 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
In 85 to 90 there were models of the 4T60 that had the 4 pin weatherpack connector as well as versions with the 5 pin weather pack connector. By 88 they were all using the 5 pin weatherpack connector.
Website: fieroguruperformance.com
Products: 88 13" Brake Kit, 88 12" Brake Kit, 88 Lateral Link Relocation, 84-87 Machined Front Hubs, Custom Machining
Engine Swaps:
LS4/F40, HSR/SBC/F23, Pro-Flo/383/Getrag, 4.3CPI/4T60, Ramjet SBC/Getrag, 4.9/Isuzu, Carb SBC/Isuzu, 4.5/Isuzu
[This message has been edited by fieroguru (edited 05-27-2014).]
BrittB
Report this Post05-26-2014 02:14 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
This true no matter how many pin connectors it has?
Total ratings: 463
Report this Post05-26-2014 03:14 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Should be. The "E" version has no need for the TV cable as all the shift points are controlled by the PCM.
BrittB
Report this Post05-26-2014 05:41 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks!
Knight
Report this Post05-26-2014 07:06 PM Click Here to See the Profile for KnightSend a Private Message to KnightEdit/Delete MessageReply w/QuoteDirect Link to This Post
Saw that the pre 88 trans only uses three out of the 4 pins. The 88 trans has 5 pins and appears to use all 5. What are the other theory used for. The diagrams are too poor resolution for me to read it. Just trying to decide if I should look for the later trans. Plan on upgrading ECM.
BrittB
Report this Post05-26-2014 08:12 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
And might you have one for the TH125 for comparison?
Report this Post05-27-2014 08:00 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are several wiring variations:
One 4 Pin version uses 2 wires: +12V to the TCC with the TCC being internally grounded. Then another wire to the 4th gear pressure switch.
One 4 Pin version uses 3 wires: and has the 3rd gear pressure switch wired in series to the TCC and a ground. The 3rd wire goes to the 4th gear pressure switch.
One 4 Pin version uses 4 wires: 2 for the TCC, 1 for the 3rd gear switch, 1 for the 4th gear switch.
One 5 Pin version uses 4 wires: 2 for the TCC, 1 for the 3rd gear switch, 1 for the 4th gear switch.
One 5 Pin version uses 5 wires: 2 for the TCC, 1 for the 3rd gear switch, 1 for the 4th gear switch, one for the fluid temp.
One 5 Pin version uses 5 wires: 2 for the TCC, 1, for the 2nd gear pressure switch, 1 for the 3rd gear switch, 1 for the 4th gear switch, one for the fluid temp.
While going through the manual again, I noticed that the 4 Pin connector was used up through 90, only 1991 was all 5 pin .
