Appreciate PFF? Please consider making a donation.
Pennock's Fiero Forum has been the largest source for Fiero related information during the past 23 years and it has always been free for everyone - members, vendors and visitors. However, it isn't free for me to maintain. If you want to help me keep PFF up and running, please consider a donation. Your support will be greatly appreciated. Not only by me, but by the thousands of daily visitors that use PFF. If you want to make a donation (PayPal, Bitcoin, Ethereum, etc.) please (or simply send your PayPal donation to info@pennock.nl).
Thanks!
Cliff Pennock
  3800 4t65HD axle question
3800 4t65HD axle question by JCircs
Started on: 06-09-2014 02:57 PM
Replies: 8 (842 views)
Last post by: MstangsBware on 06-10-2014 09:38 PM
JCircs
Report this Post06-09-2014 02:57 PM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know how to use the search function and I'm aware it's been posted a hundred times but I'm still a little confused. I'd like to collect all the necessary parts to complete my swap before I start and I have not found a clear answer on axles, maybe there is none? It's a 87 GT using a 4t65e hd auto and a supercharged 3800 from a 2001 Bonneville and all WCF mounts and brackets. My Fiero axles are gone, all I have is the Bonneville axles. Can someone tell me what else I need to make this work. Thank you...
MstangsBware
Total ratings: 459
Report this Post06-09-2014 04:02 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
If u can't get it figures out then I build and sell a plug/play Pass side axle supplying all the parts. PM me if interested.
MulletproofMonk
Total ratings: 78
Report this Post06-09-2014 10:25 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hit up Stephen for the passenger side... Auto Fiero driver side axle for the drivers side...
-Brian
Removing the roof panel
My HUD install thread
Modified stock air canister and base to 3.5 inch for 3800na
Total ratings: 328
Report this Post06-10-2014 10:00 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
auto axle only works for some mountings. Did not work with WCF mounts that center the power train. My axles are about the same size . I believe that they are Transport Van axles bars with manual Fiero outer cups and Grand Prix inners tripots
I just measured up and went over to the axle shop.-done!
Lou6t4gto
Report this Post06-10-2014 02:43 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I Did get one from mustangsbeware. It's a bolt in.
JCircs
Report this Post06-10-2014 03:04 PM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you use WCF mounts? What did you use on the drivers side?
MstangsBware
Total ratings: 459
Report this Post06-10-2014 05:01 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Worked on every swap I have done using WCF mounts along with PR/FieroX mounts. Never had any issues with any figment issues at all.
Total ratings: 328
Report this Post06-10-2014 05:49 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The auto axle will fit in the drivers side but it was about 1/2" too short. IMO that can make for a broken cup with a hard launch.l lots of swaps have used them but the loose fit is concerning plus the,axle bar is of a,smaller diameter. . Maybe I like to cut it a bit too fine but that's the way I've always done things.
MstangsBware
Total ratings: 459
Report this Post06-10-2014 09:38 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Many many hard launches on the setup in my car and others with no breakage or any other issues...Setup works fine but everyones thoughts and processes e different so I understand where u r coming from.
