Here is some background information that may prove helpful.
. .Stock wheels for 1988 Fiero GT and Formula:
. .15x6”. . .+37mm offset. . .1988 Front ONLY.
. .15x7”. . .+30mm offset. . 1988 Rear ONLY.Below is a link to a thread on PFF that has a diagram that may also prove helpful.
https://www.fiero.nl/forum/Forum1/HTML/058236.htmlBelow is a link to a web site that will allow you to compare the stock wheel & tires to what ever wheel & tire that you are thinking of buying.
http://www.rimsntires.com/specspro.jspAlso I have a 1988 GT. Before I upgraded to coilovers,
I had the the following wheels & tires with a
completely stock suspension.
. .Wheels 16x7" +48. . BBS RG-F wheels (Front & Rear)
. .Front tires 225/50-16 tires
. .Rear tires 245/50-16 tires
I had no problems with the tires rubbing any where. I hope the above info proves helpful.
If you still have questions you might drop a PM to either Boozberry, or Fieroguru here on PFF.
They are two of the most knowledgeable guys on PFF.
I wish you Good Luck in your search.
~ Bob ~
"Its nice to be important.
Its more important to be nice."
