  84-87 12" Corvette Brake Swap... (Page 7)
84-87 12" Corvette Brake Swap... by Jncomutt
Started on: 06-09-2005 09:43 PM
Replies: 279 (46449 views)
Last post by: adifferentlook on 01-28-2021 09:00 AM
PerKr
Report this Post06-15-2011 04:33 PM Click Here to See the Profile for PerKrClick Here to visit PerKr's HomePageSend a Private Message to PerKrEdit/Delete MessageReply w/QuoteDirect Link to This Post
finally it seems that I have the money to buy the rotors. Corvette Central part no 574596 seem right to you guys?
PerKr
Report this Post06-22-2011 03:30 PM Click Here to See the Profile for PerKrClick Here to visit PerKr's HomePageSend a Private Message to PerKrEdit/Delete MessageReply w/QuoteDirect Link to This Post
*bumping this one up in hope of getting an answer before placing an order*
jb1
Report this Post06-23-2011 01:51 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone selling the brackets for the brake swap?
87 GT
PerKr
Report this Post06-28-2011 03:14 PM Click Here to See the Profile for PerKrClick Here to visit PerKr's HomePageSend a Private Message to PerKrEdit/Delete MessageReply w/QuoteDirect Link to This Post
just realized, I haven't seen any comment on what kinds of aluminium alloy have been used (successfully). 6061? 7075? other? aluminium isn't just aluminium after all...
Boogaloo
Report this Post06-28-2011 03:31 PM Click Here to See the Profile for BoogalooSend a Private Message to BoogalooEdit/Delete MessageReply w/QuoteDirect Link to This Post
I tried this design many years ago and found there was a flaw in the design of that adapter ,I just used a piece if 1/4" steel plate and mocked it up with a piece of cardboard then transferred it to the metal then used nuts and bolts and washers to space it out and that solved the problem.
That design works but not 100% practical wish I still had those pics
jb1
Report this Post06-29-2011 01:54 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
well I priced a guy out of Canada to laser cut the brackets and rings but he wanted $285 a set out of raw steel... alittle pricey I thought compared to some of the prices on here in the past...
87 GT
Knight
Report this Post07-18-2011 05:12 PM Click Here to See the Profile for KnightSend a Private Message to KnightEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
PerKr
Report this Post12-15-2011 05:10 PM Click Here to See the Profile for PerKrClick Here to visit PerKr's HomePageSend a Private Message to PerKrEdit/Delete MessageReply w/QuoteDirect Link to This Post
I now have a set of front adapters cut from steel. Well, they cut the basic shape and centerpunched and I then drilled the holes. Very reasonable price. But I keep hearing bad things about using washers to space the adapter out as well as having oversized holes in the adapter (I have 14mm holes for the upright M12 bolts and 16mm holes for the bracket M14 bolts, while apparently I should have gone with 12mm and 14mm holes respectively).
PerKr
Report this Post12-27-2011 03:34 PM Click Here to See the Profile for PerKrClick Here to visit PerKr's HomePageSend a Private Message to PerKrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone had problems with the adapter not being parallell with the rotor? My adapters aren't perfectly flat, but still not twisted enough to explain the difference I'm seeing. I don't recall seeing anyone mentioning having planed the front of the upright either...
Total ratings: 236
Report this Post12-27-2011 04:03 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's not a machined surface... YMMV.
PerKr
Report this Post12-27-2011 04:35 PM Click Here to See the Profile for PerKrClick Here to visit PerKr's HomePageSend a Private Message to PerKrEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know it's a cast surface, but am I the only one to have this problem (as it hasn't been mentioned)?
Total ratings: 236
Report this Post12-28-2011 09:04 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
I thought the knuckle was a forging...
It occasionally does happen.
If you look at WCF's brake kits, you'll see that they build comparatively elaborate brackets in order to mount to the machined side of the mounting ears.
[This message has been edited by Will (edited 12-28-2011).]
PerKr
Report this Post12-28-2011 03:30 PM Click Here to See the Profile for PerKrClick Here to visit PerKr's HomePageSend a Private Message to PerKrEdit/Delete MessageReply w/QuoteDirect Link to This Post
you're probably right. I can't really tell the difference (don't know what to look for) :-)
mounting on the machined side would be preferrable. Not sure how I would make such a bracket with this rotor/caliper combo though. The adapter I have is 19mm thick and uses 2.5mm shims to get the bracket in the correct position. The upright mounting ears are ~13mm thick and I'd say I'd want about 15mm of material on the adapter... That's a 50mm thick piece of steel to work with :-D Would be interesting to make up a design if I could find the time for it :-)
Total ratings: 236
Report this Post12-28-2011 04:53 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
PerKr
Report this Post12-30-2011 05:32 PM Click Here to See the Profile for PerKrClick Here to visit PerKr's HomePageSend a Private Message to PerKrEdit/Delete MessageReply w/QuoteDirect Link to This Post
that's pretty much what first popped into my head but I was kind of worried about the stress concentrations around the two towers.
Also just crossed my mind (as I was looking at the pictures) that I could have two 30mm long cylinders turned for each caliper to get the same result (without the stress concentration issue but possibly with other issues).
Total ratings: 236
Report this Post12-31-2011 08:23 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
As long as bolts go through the "towers" and give you compressive preload, it shouldn't be a problem.
gambler85
Report this Post01-09-2012 05:20 PM Click Here to See the Profile for gambler85Send a Private Message to gambler85Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was wonderinh if anyone has the cadd drawings for the adapter brackets? I have all my parts for this swap just needing the adapters. I have a shop that can make them cheap. Thanks my email is mtkrusmark@yahoo.com
PerKr
Report this Post06-25-2012 04:23 PM Click Here to See the Profile for PerKrClick Here to visit PerKr's HomePageSend a Private Message to PerKrEdit/Delete MessageReply w/QuoteDirect Link to This Post
gambler: I put my assembly up on grabcad.com, you could use those models to make up your drawings
About the MC suggested here, is it the 1.125" or 1" master? I'm using the fiero MC now and the pedal is rather on the low side. Not sure how low would be considered normal (vette pistons are 54mm, isn't that the same as for the grand am? if so, I guess someone might know)?
zmcdonal
Report this Post10-16-2014 02:36 PM Click Here to See the Profile for zmcdonalSend a Private Message to zmcdonalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Edited to avoid confusion.
[This message has been edited by zmcdonal (edited 10-16-2014).]
zmcdonal
Report this Post10-16-2014 03:12 PM Click Here to See the Profile for zmcdonalSend a Private Message to zmcdonalEdit/Delete MessageReply w/QuoteDirect Link to This Post
zmcdonal
Member since Oct 2005
Jncomutt
Total ratings: 221
Report this Post02-20-2015 01:17 PM Click Here to See the Profile for JncomuttSend a Private Message to JncomuttEdit/Delete MessageReply w/QuoteDirect Link to This Post
Updated year range for MC. I had 67, it's supposed to be 77.
E.Furgal
Total ratings: 278
Report this Post02-21-2015 01:14 PM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Incorrect.
From the factory, the wheels DO center on the hub pilot.
Using brake upgrades with separate rotors does indeed reduce the length of the protrusion such that the wheels no longer contact it.
After doing the upgrade, the wheel is then centered by the lug nuts. This is NOT the same and is NOT as good as a positive location via pilot & bore.
However, this seems to be "good enough" that people don't have any problems with it.
I think it's sloppy and one of the major problems with Fiero brake upgrades. Would you trust that the lug studs locate the wheel well enough that it won't shake you into a crash at 150+ mph?
preamble I know this is an old thread
from What I gather conical lug nut seat wheels, the conical seats center the wheel the center hub fitment is more about weight so the lug studs are not carrying the vehicles weight, the hub center is..
having said that, I'd use ARP(for exp) studs over a parts store "dorman/help" . The Fiero isn't that heavy so the center hub isn't as big as an issue as it would be on a truck,
Cajun
Report this Post02-21-2015 08:34 PM Click Here to See the Profile for CajunSend a Private Message to CajunEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is replacing the MC with a Corvette MC as straight forward as noted? I did note the fitting sizes are different from the Fiero MC.
thanks
Total ratings: 236
Report this Post02-22-2015 04:17 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Still incorrect.
The hub pilot locates the wheel. Period. (Yes, there are lug-centric wheel/hub combinations, but the Fiero is NOT one of them, nor is any GM product to my knowledge).
The weight of the vehicle is carried by the FRICTION of the wheel to hub flange interface. This friction is enabled by the clamping force of the lug studs/nuts clamping the wheel against the flange.
sardonyx247
Total ratings: 219
Report this Post02-22-2015 11:48 PM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had someone come down to the shop with all the swap brackets, MC, calipers etc.
Looking it all over I found a huge flaw, then saw this post so I read through it to see if it had been covered, so far no one has even noticed it.
on the MC, where it bolts to the booster, it has a huge deep hole for the pushrod to sit in, the Fiero MC only has a dimple.
What I am getting at, to be correct you need a longer pushrod between the booster and the MC, otherwise instead of a metal rod pushing on the MC you have only plastic the surounds the rod doing all the pushing.
Has anyone else noticed this or addresed it in any way?
"DRIVE IT LIKE A FIERO"
'87 Quad 4 H.O.
KaijuSenso
Report this Post02-23-2015 01:02 PM Click Here to See the Profile for KaijuSensoSend a Private Message to KaijuSensoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Still incorrect.
This is correct. To add, conical lug nuts/bolts (while helping center the bolt pattern in the tangential direction) are designed to give more friction surface between the fasteners and wheels to resist loosening when properly torqued.
sardonyx247
Total ratings: 219
Report this Post02-24-2015 05:28 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone?.?
E.Furgal
Total ratings: 278
Report this Post02-24-2015 09:56 AM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone?.?
I haven't seen both side by side, but if the fiero booster stub has more girth than the vette pushrod hole in the masters piston.. it might not matter..
I know on my 71 c-10 the master for a emanual brakes and the power have different depth holes and girth in the piston in the master..
not knowing if the vette master use was for power or manual brakes,
it be good to know, with this threads age we might not get the answer without going to a parts store and looking at masters, IIRC that vette master listed if it is for power brakes originally, is the same as the 78-81 ws6 t/a's that had 4 wheel discs..
finding a local parts store with the masters on the shelf may prove to be out of the question.
[This message has been edited by E.Furgal (edited 02-24-2015).]
sardonyx247
Total ratings: 219
Report this Post02-26-2015 03:18 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
OK, Here are some pics of a Vette (not sure year, but this is the one with the same size line fittings as the Fiero) and the Fiero MC.
From what we could measure the pushrod between the booster and MC needs to be 1 5/16 ths of an inch LONGER than the stock Fiero rod.
This is to put the info in here.
With this type of MC if you don't get the right rod you will only have plastic pushing on the MC instead of a metal rod.
I haven't done this swap, I was only looking over a club members (good member) supplies he had gathered for this swap when I came across this.
[This message has been edited by sardonyx247 (edited 02-26-2015).]
Jncomutt
Total ratings: 221
Report this Post03-08-2015 04:41 PM Click Here to See the Profile for JncomuttSend a Private Message to JncomuttEdit/Delete MessageReply w/QuoteDirect Link to This Post
I still have a spare vette MC at my shop that I was considering installing on another car. I will check next time I'm there if it is the same as yours.
Jncomutt
Total ratings: 221
Report this Post03-11-2015 07:49 PM Click Here to See the Profile for JncomuttSend a Private Message to JncomuttEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is a picture of the master cylinder I had laying around. I don't know how this compares to stock.
sardonyx247
Total ratings: 219
Report this Post03-12-2015 02:34 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
That looks more like a stock Fiero one, just a dimple. The MC with the hole is supposed to have the same size line fittings, thus why he chose that year of one.
Im not the one doing the swap, I just wanted to add info to the thread.
lou_dias
Report this Post03-12-2015 12:45 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie installed an '82 Corvette BMC into my 87GT ... I thought it was a direct swap but you may want to check with him for details...
pokeyfiero
Total ratings: 306
Report this Post07-25-2016 01:00 AM Click Here to See the Profile for pokeyfieroClick Here to visit pokeyfiero's HomePageSend a Private Message to pokeyfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bumping thread.
Jncomutt
Total ratings: 221
Report this Post08-24-2019 10:56 PM Click Here to See the Profile for JncomuttSend a Private Message to JncomuttEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow, Still alive! I'll have to update the first post when I get a chance.
redraif
Report this Post08-26-2019 04:41 PM Click Here to See the Profile for redraifSend a Private Message to redraifEdit/Delete MessageReply w/QuoteDirect Link to This Post
Funny you bumped this now... I have just been reading through it, as I decided about 2 weeks ago, I am bringing the Fiero back to life and doing the brake conversion to make it happen.
Going with C4 Calipers and 12 rotors in the rear and C6 calipers and 13 inch up front
[This message has been edited by redraif (edited 08-26-2019).]
P.O.L. Mafia
Report this Post11-08-2019 12:39 PM Click Here to See the Profile for P.O.L. MafiaClick Here to visit P.O.L. Mafia's HomePageSend a Private Message to P.O.L. MafiaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Glad to see this thread lives. I am in the process of finishing up the 4.9 install and have been reading on this upgrade. I probably jumped right by it, but is there a pic for the adaptors to mount brackets. Or does someone still sell them?
Mike T
CCWorks
http://www.ccworks.org
Choppers and Fiero's RUUUULLLLEEEEE
michael.tullock@ccworks.net
kevin
Report this Post11-08-2019 02:13 PM Click Here to See the Profile for kevinSend a Private Message to kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fellas,
I’m doing this upgrade. Can you purchase a caliper with the CORVETTE inscribed on it? For that matter, what about BREMBO, or BEAR or perhaps another manufacturer?
Good write up...šŸ˜‹
Cordially,
kevin
Jncomutt
Total ratings: 221
Report this Post02-16-2020 10:28 AM Click Here to See the Profile for JncomuttSend a Private Message to JncomuttEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry I still haven't updated with more in-depth details from when this first started. I'm working on another one of these brake swaps now though, and so I made a jig for the rotor drilling. I posted the link in my first page post, but here it is also.
https://www.thingiverse.com/thing:4166383
[This message has been edited by Jncomutt (edited 02-16-2020).]
adifferentlook
Report this Post01-28-2021 09:00 AM Click Here to See the Profile for adifferentlookSend a Private Message to adifferentlookEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Jncomutt:
Ok well ALL the information to do this brake swap is out on the internet somewhere. Bubbajoe has a good majority of the information on his website, but there is ALOT lacking. All of this other lacking material can be found elsewhere, but I'm going to try to compile it all in this one simple thread....
FRONT
Standard Duty..
84-87 Corvette
Left -- 10181205
Right -- 10181206
REAR
Left -- 10112652
Right -- 10112652 (same part fits left and right)
Rotors
Front -- 88 Corvette Fronts WITHOUT heavy duty brakes
Rear -- 88 Corvette Rears WITHOUT heavy duty brakes
Master Cylinder
77 to 82 Corvette
Calipers
Front -- 1984-1987 Corvette
Rear -- 1988 to 1996 Corvette
Lug Studs
Dorman Part # : 610-323
Advance Auto Parts # 98501 (Pik - a - Nut brand)
Banjo Bolts
Front - 10x1.0mm
Rear - 10x1.0mm
Mounting Bolts
(8) 12M 1.75 x 30mm Hex Head Cap Screws (fronts)
(8) 12M 1.75 x 20mm Hex Head Cap Screws (rear)
Brake Lines
Any replacement lines have been said to work
Lines used here were summit part#: "RUS 692110"
How do I buy your corvette rotor jig and do you know anyone I can get the brake adapters from for a 1984
Anthony
9192742487
