  $100 brake upgrade (Page 3)
$100 brake upgrade by Phil
Started on: 04-04-2006 08:37 AM
Replies: 426 (58321 views)
Last post by: 82-T/A [At Work] on 09-13-2023 08:09 AM
Phil
Total ratings: 154
Report this Post06-23-2006 04:26 PM Click Here to See the Profile for PhilSend a Private Message to PhilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cut the ring end off of the new booster and cut the rod off of the Fiero booster ( making it as long as you can). I used a hunk of steel rod and drilled a hole in each end ( to match the dia of the push rod, the S-10 and Fiero rods are slightly different diameters). Make the new pushrod equal to the length of the original Fiero rod. The S-10 booster has 4 bolts coming out of the back and the bracket fits right over these bolts, you just have to buy 4 nuts and washers.
Chicken McNizzle
Total ratings: 108
Report this Post06-23-2006 04:36 PM Click Here to See the Profile for Chicken McNizzleClick Here to visit Chicken McNizzle's HomePageSend a Private Message to Chicken McNizzleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Phil:
Just as a side note , I did have the 12" Vette rotor setup on my car before but I didn't like having to carry a 16" spare in the front ( sunroof glass wouldn't fit in the front anymore) and I think that I now have better braking with the stock rotors and the bigger booster than with the Vette setup. I don't know if I would do both conversions at the same time - brakes might get a little too touchy.
WCF offers a spare tire that will work with thier Corvette Brake Upgrade, however will still fit under the front area as it is based off of the factory spare
fierogt88
Total ratings: 100
Report this Post06-23-2006 04:51 PM Click Here to See the Profile for fierogt88Send a Private Message to fierogt88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've looked into this a little bit more, and I have one small word of caution at this point. The s10 has come with quite a few different boosters over the years. The one in the fiero and the bigger one used by Phil in this upgrade look to me like double diaphragm boosters. There are smaller boosters and even single diaphragm boosters used in the s10s at different points in time. You definately want a bigger double diaphragm booster for best effect, and a smaller single diaphragm booster or single diaphragm booster (apparently from the earlier years) could be a brake downgrade. It would be nice if Phil could provide some more details fo the exact year and what part number he used? If he already posted this I apologize in advance...
Phil
Total ratings: 154
Report this Post06-23-2006 09:13 PM Click Here to See the Profile for PhilSend a Private Message to PhilEdit/Delete MessageReply w/QuoteDirect Link to This Post
i used the booster from a 97 S-10
RotrexFiero
Report this Post06-27-2006 07:05 PM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay, I started this upgrade. Purchased the brake booster, and have removed my old one. One thing that concerns me is the slight modification to the compartment via a BFG. I tapped that area and it appears to be very fortified. Which makes me think that there is some heavy hitting required. Would it be better to cut and then weld a section into there?
My concern is that the front suspension is directly below that area. Could I possible harm something, shock mount or suspension attachments?
87 Fiero GT (3.2 Turbo)
E-mail: david88@peoplepc.com
www.angelfire.com/pa5/davidfiero/
Phil
Total ratings: 154
Report this Post06-27-2006 07:32 PM Click Here to See the Profile for PhilSend a Private Message to PhilEdit/Delete MessageReply w/QuoteDirect Link to This Post
You only have to dent it about 1/8 inch or so - might even be able to squeeze it in without the BFH. Nothing major is affected by the denting
Michaell Knight
Report this Post06-29-2006 01:51 PM Click Here to See the Profile for Michaell KnightSend a Private Message to Michaell KnightEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does the offer still stand " if you bring the booster and some bolts i will slapp it on there " , lol !!
I'm an actor ( well......trying to be ) and i will be in a small budget film up in CT towards the end of the summer.
Think maybe i could make a small detour on the way back?
Phil
Total ratings: 154
Report this Post06-29-2006 01:58 PM Click Here to See the Profile for PhilSend a Private Message to PhilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sure - unless I can arrange to be out of town at that time.
Michaell Knight
Report this Post06-29-2006 03:46 PM Click Here to See the Profile for Michaell KnightSend a Private Message to Michaell KnightEdit/Delete MessageReply w/QuoteDirect Link to This Post
cool , i will keep in touch
thx
RotrexFiero
Report this Post06-29-2006 09:48 PM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just finished this upgrade/modification. Its was not that difficult, but does take some time, especially if you have not done it before. Thanks Phil for the simple advice about measuring, and checking your measurements. I was careful and I also welded, double welded my brake to power booster connecting rod.
The results. The brakes appear strong but I am not able to lock up my tires. I dont have stock tires and rims, both are larger so that might account for this. I will have to drive some more and see how the brakes feel at high speed. But, from first impressions it appears worth the time. I could not image I have lost any braking power, but still feel that I will have to eventually go to larger rotors. As if I did not know this. Thanks Phil, nice modification.
OldBob
Report this Post07-11-2006 09:51 PM Click Here to See the Profile for OldBobSend a Private Message to OldBobEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK - got some questions.
Here are a couple of pics of three boosters. The one in the middle
is a Fiero with the bracket removed. The one on the right is from a
90 S-10 fwd. Except for the bracket it appears to be identical to the
Fiero booster.
The one on the left is from a 97 S-10 from the junkyard. It is borderline
too large to fit into the space in the Fiero even with some heavy duty
BFH work. It doesn't look exactly like the one pictured earlier in this
thread. It has a smooth ring around the outside where the earlier pic
shows a scalloped edge like the Fiero. Phil mentioned the need to
deform the inner fender about an 1/8". Took a lot more than that to
get the bracket flat to the firewall and the booster was still touching the
inner fender.
The 97 S-10 is about 10 3/4" dia. The Fiero is about 8 3/4" dia.
Is this the right booster? If not, what do I look for?
Bob
Phil
Total ratings: 154
Report this Post07-12-2006 08:32 AM Click Here to See the Profile for PhilSend a Private Message to PhilEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's the correct booster 10 3/4", the ones I used were scalloped but I dont think it makes any difference. here are 2 pics of the BFH work
RotrexFiero
Report this Post07-12-2006 10:06 AM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have to test fit mine several times, and make "corrections" with the hammer. But, it will fit. Though I have to admit when I compared mine to the stock I thought "there is no way this is going in there without a cutting torch". But, yes it will fit and is a nice upgrade. Please, as Phil suggested, take your time and cut the pedal rod carefully. Probably want to have it welded, since if it breaks or comes apart your literally have no brakes. You would be pretty defenseless if anyone was hurt, or even yourself, trying to explain to the insurance company or police that you modified your brakes and that is why you ran over a squad of nuns.
LOL
schumi
Report this Post08-19-2006 09:39 PM Click Here to See the Profile for schumiSend a Private Message to schumiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did this upgrade on my 84 track car, which has stock braking system except has stock front calipers at both the front and rear. A few things:
1. It dramatically increased stopping power. I like it a lot.
2. Don't use JB weld, get it welded for real. I tried it with a steel coupling and JB weld and it failed after about 10 miles. Cost me $20 to get welded (used steel coupling again).
3. I had to use a couple of M10 washers on each of the m/c mounting bolts, because without them the pushrod thing from booster to m/c was causing brakes to be engaged even w/o pressing the pedal.
[This message has been edited by schumi (edited 08-19-2006).]
schumi
Report this Post08-19-2006 09:41 PM Click Here to See the Profile for schumiSend a Private Message to schumiEdit/Delete MessageReply w/QuoteDirect Link to This Post
schumi
Member since Dec 2005
double post, sorry
Scott-Wa
Total ratings: 147
Report this Post08-19-2006 10:38 PM Click Here to See the Profile for Scott-WaClick Here to visit Scott-Wa's HomePageSend a Private Message to Scott-WaEdit/Delete MessageReply w/QuoteDirect Link to This Post
FieroX did something interesting where he used an electric vacuum pump to draw down the power assist booster on his wild turbo setup. Instead of just being able to generate the 18-21 inches of vacuum the average car idles at around sea level, he can probably draw close to 29 inches.. a massive difference. As someone else stated, a booster is sealed and good for several stops once drawn down, even if the vacuum source goes away. It's not a mission critical item to have it keep up with braking or engine size unless your driving has you pumping the pedal continuosly. Experiment... start your car and then shut it off, then push the brakes. You should hear the booster functioning each time until it's equalized to atmosphere. Or after your car has been off a while, twist the elbow (check valve) going into the booster, it'll still be under vacuum and you'll hear the whoosh as you break the seal.
FLGuyTpa
Report this Post08-20-2006 02:50 PM Click Here to See the Profile for FLGuyTpaSend a Private Message to FLGuyTpaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wonder if one of these 9" boosters would work? It appears to be slightly smaller and perhaps
not require mods to fit. It looks to have a threaded rod which might make it a bit simpler to adapt.
64-72 GM BRAKE BOOSTER, Delco Moraine Stamp part number 2410990 9" Booster.
http://cgi.ebay.com/ebaymotors/64-72-Chevrolet-9-CHEVY-GM-BRAKE-BOOSTER_W0QQitemZ270019774748QQcmdZViewItem
Formula88
Total ratings: 554
Report this Post12-08-2006 12:00 AM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Keep in mind, the smaller booster won't give as much brake assist. Since the reason for the swap is to get more assist, I would think you'd want to go with the largest booster that will fit. The S10 booster looks to be about as much as you can squeeze in there without major surgery.
avengador1
Total ratings: 571
Report this Post12-08-2006 11:48 AM Click Here to See the Profile for avengador1Send a Private Message to avengador1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here is something else I found that might also help: https://www.fiero.nl/forum/Forum1/HTML/062913.html
roccofiero
Report this Post01-20-2007 05:42 PM Click Here to See the Profile for roccofieroSend a Private Message to roccofieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey, I just did the booster upgrade on my 86 GT. Easy, low cost and "At last I have brakes like a real car." No more panic every time a quick stop is required. THe brakes feel just like the brakes on my new dodge. Very impressive for the price. Thanks a million, Phil. It is the answer to my prayers. The install was as easy as you stated. The new booster (A1 Cardone P/N A154-71061, cost me 110.31 @ AutoParts Warehouse. Unfirtunately, the core cost ($30) will be lost as the booseter is different and the old one is cut up. The new booster is 2 inches larger in diameter, but fits well with the "hammer" mod. Very little hammering required. The whole mod would have taken about an hour if not for the brake shaft change. I cut off the end of the new shaft and the old shaft so as to connect the old brake connector to the new shaft. The new total shaft length is 9 1/2 in. from the face of the booster to the center of the brake banjo connector. I cut to size, found a sleeve at a hardware store and welded the shafts together. That's it. I didn't even have to bleed the brakes, since the master cylinder lines were never removed. What a difference. If you are looking for real brakes on a Fiero, this is the ticket.
Mickey_Moose
Total ratings: 145
Report this Post01-20-2007 06:18 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by theogre:
The issue is that many people that might do this, and see a performance increase, are compairing apples to oranges. IE compairing a defective OE part to a new or better condition used part. This happens allot when people compair OE rubber suspension parts to polyurethane aftermarket parts.
Can't agree more...
Was there a problem with the original 20+ year old part that could solved by replacing it with a 'new' unit (not necessary a bigger one)?
triker
Report this Post03-05-2007 07:30 PM Click Here to See the Profile for trikerSend a Private Message to trikerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I finally got around to doing the S10 booster mod today. Wow, what a difference! Real power brakes! I think it could be called a "must do" modification.
Hudini
Total ratings: 165
Report this Post03-05-2007 07:41 PM Click Here to See the Profile for HudiniSend a Private Message to HudiniEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone done this mod with GA brakes? With GA brakes and the K5 master cylinder?
How about the GA brakes and S10 master cylinder? lol, too many questions.
[This message has been edited by Hudini (edited 03-05-2007).]
Australian
Report this Post03-05-2007 07:53 PM Click Here to See the Profile for AustralianClick Here to visit Australian's HomePageSend a Private Message to AustralianEdit/Delete MessageReply w/QuoteDirect Link to This Post
How many mouse power is your car? Looks like a mouse wheel under front bonnet?
Hudini
Total ratings: 165
Report this Post03-05-2007 08:21 PM Click Here to See the Profile for HudiniSend a Private Message to HudiniEdit/Delete MessageReply w/QuoteDirect Link to This Post
bottle fed mouse = nitrous small block chevy.... pretty funny
Phil
Total ratings: 154
Report this Post03-05-2007 08:23 PM Click Here to See the Profile for PhilSend a Private Message to PhilEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's Leonard - he's been all over the country in my Fiero
twocoda
Report this Post03-14-2007 12:18 AM Click Here to See the Profile for twocodaSend a Private Message to twocodaEdit/Delete MessageReply w/QuoteDirect Link to This Post
wow that was alot of reading ....lol....now this thread defines the different of practical and theory
good mod phil....as soon as im in need of an upgrade (why fix whats not broken) knock on wood) link added to favorites for when the time comes
thanks
It isnt re-creation....its recreation!!!!
Fastback 86
Total ratings: 231
Report this Post03-14-2007 11:48 AM Click Here to See the Profile for Fastback 86Send a Private Message to Fastback 86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Mickey_Moose:
Can't agree more...
Second. I can lock the brakes in my car no problem, and its stock brakes and stock booster stopping 16" wheels. I worry for people who say this made a monumental difference, makes me think you had a serious problem beforehand.
That said, if I'm not impressed with my brakes when I upgrade to 11 1/4s, I'll be doing this mod.
[This message has been edited by Fastback 86 (edited 03-14-2007).]
triker
Report this Post03-14-2007 01:19 PM Click Here to See the Profile for trikerSend a Private Message to trikerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fastback, if your brakes are so great, why are you going to upgrade to 11 1/4's. Try this simple and cheap mod and you too will be saying "wow". I have two Fiero's, one of them since it was almost new. Though the brakes on both have always been adequate, they've never been awe inspiring. Now, I keep looking for excuses to make panic stops instead of trying to avoid them!
[This message has been edited by triker (edited 03-14-2007).]
Misred
Report this Post06-12-2007 12:03 PM Click Here to See the Profile for MisredSend a Private Message to MisredEdit/Delete MessageReply w/QuoteDirect Link to This Post
the booster off an 88 Fiero is another route..it gives a bit more umph aside from the check valve being bigger, you will need the master cyl. from the donor. The check valve wont fit between the booster and the old pre 88 master cyl.
Red
Fastback 86
Total ratings: 231
Report this Post06-12-2007 02:32 PM Click Here to See the Profile for Fastback 86Send a Private Message to Fastback 86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cheesy sales pitch aside, you're missing the point. Did you do any work to repair or replace your stock brakes before you did this modification? If I can lock the wheels with the stock brakes, why would I need to upgrade them with this mod? Increasing the force on the brakes isn't going to do anything if I can already lock them, it'll just make them easier to lock. My point is, if you haven't made sure your brake system is in perfect working order (no old bulging hoses, no old fluid, no leaks in the vacuum booster, no leaks in the master cylinder or the calipers, no sticking calipers, etc etc), then how can you know that this mod was so beneficial?
Now in my case, I'm interested in all around improvement. Locked wheels are useless, so I want more stopping power before I get to the point of locking them, which the larger brakes will afford me. Even more beneficial over the stock brakes is that the new ones will be larger and vented and will not overheat nearly as easily, which will be much nicer (not to mention safer) when driving hard on windy roads. On top of all of that, I figure if I'm going to replace all the brake parts anyway, why replace with stock stuff when I can spend a little bit more and get a lot more performance?
Also note that, if I can't get enough stopping power out of the stock booster and master cylinder, I will be doing this mod.
fierogt88
Total ratings: 100
Report this Post06-15-2007 11:57 AM Click Here to See the Profile for fierogt88Send a Private Message to fierogt88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well in my case I'm running larger wheels and much stickier tires on my car. My stock brakes were in perfect condition, but I was not able to lock them up after putting on big wheels and sticky tires. I upgraded to the 13" corvette rotors, and now I can lock them up. I see this upgrade as the same kind of thing. What you say is true about stock parts, but there are other parts that are getting upgraded on fieros all the time (such as my wheels and tires) and at some point the braking system can be the weak link in the total package even though it's in perfect condition. With my 13" upgrade, I achieved the better braking I needed, but I also picked up unsprung weight. I highly doubt this one adds as much weight to the car, and what weight it does add goes in the front cargo bay instead of at the wheels. I plan on doing this upgrade, even though I can lock them up now, because when I eventually get back into autocrossing I'll probably go with even stickier tires and go back to stock sized rotors.
bspring
Report this Post06-15-2007 01:58 PM Click Here to See the Profile for bspringSend a Private Message to bspringEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would using the S10 master cylinder be a viable braking solution along with the booster as well? I have read a few don't do it posts in the past, but thought I would bring it up for current discussion. I have an 88 Fiero with Carbomet pads and vented discs.
Billl
Fastback 86
Total ratings: 231
Report this Post06-15-2007 03:56 PM Click Here to See the Profile for Fastback 86Send a Private Message to Fastback 86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well said. In non-autocross/racing situations, the stock brake system works fine if its well-maintained. I was able to lock up slightly larger than stock wheels (15") with good tires with my stock brakes. I haven't tried yet with my 16s, but that extra weight and rotating mass will make a difference. The only time I've ever had a problem with the stock brakes is a) the stopping distance, since you can only put so much force on those little rotors with one piston before the lock, and b) the fade under hard driving/racing conditions.
Fastback 86
Total ratings: 231
Report this Post06-15-2007 03:58 PM Click Here to See the Profile for Fastback 86Send a Private Message to Fastback 86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fastback 86
Member since Sep 2003
Billl
Personally, I would only do the S10/Blazer Master Cylinder WITH this large booster mod. Increasing the fluid capacity of the system (the master cylinder) really doesn't do much with out more force to work on it, which is where the large booster would come in.
FierOmar
Report this Post07-29-2007 01:38 AM Click Here to See the Profile for FierOmarSend a Private Message to FierOmarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone experience any problems yet?
FierOmar
RKSmallwood
Report this Post07-29-2007 02:41 AM Click Here to See the Profile for RKSmallwoodSend a Private Message to RKSmallwoodEdit/Delete MessageReply w/QuoteDirect Link to This Post
Neet Idea! Unless I am mistaken there is a differance between pounds per square inch and vacum. the both will affect a diaphragm in its intended manner. I work on valve operators in power plants the force that is applied is measured by finding the surface area of the diaphragm and multipling by the amount of psi applied, in the case of brakes it would be vacum, surface area would be Pi times the radius squared. then multiply this number by how many inches of vacum. this would give you the amount of force being applied to the MC. please correct if I have made a mistake. These are the kind of tips needed to help keep our toys where they belong on the road cruising
jstricker
Total ratings: 370
Report this Post07-31-2007 08:53 AM Click Here to See the Profile for jstrickerSend a Private Message to jstrickerEdit/Delete MessageReply w/QuoteDirect Link to This Post
You should not have a soft pedal. We have more than one car with the Blazer MC and we do NOT have a soft pedal. The brakes require more effort, that is pounds of force, to apply, but the pedal is not soft. If you have a soft pedal you generally have one of two problems. Bad rubber hoses that are expanding under pressure or, more likely, you don't have all the air out yet.
John Stricker
Originally posted by Quickster:
But I have a revelant question.........Does replacing the Master Cylinder with a Bigger one have an affect on the pedal? I replaced my M/C with a Bigbore and the brakes haven't been the same since! Now,...if I replaced the Booster with the aforementioned S-10 option,...would that help my "soft Pedal" problem?
Hudini
Total ratings: 165
Report this Post07-31-2007 10:08 AM Click Here to See the Profile for HudiniSend a Private Message to HudiniEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm hoping he meant the pedal goes further towards the floor before engaging the brakes. A soft spongey pedal is bad no matter what brakes you have. That is air being compressed.
EDIT: or the rubber hoses expanding as stated above. (Thanks, missed that one)
[This message has been edited by Hudini (edited 07-31-2007).]
WisconsinGT
Report this Post07-31-2007 03:39 PM Click Here to See the Profile for WisconsinGTSend a Private Message to WisconsinGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
CAn someone please put a list together on what is needed as well as a step by step of what has to be done? Thanks! Pictures would be welcome as well.
