Thread Closed  Topic Closed
  Inside the GM tilt steering column (Page 2)
Post New Topic
Printable Version
This thread has been moved here: FAQs & HowTos.
Inside the GM tilt steering column by JazzMan
Started on: 12-04-2007 08:54 AM
Replies: 140 (129024 views)
Last post by: Vintage-Nut on 11-23-2024 12:02 AM
JazzMan
Total ratings: 653
Report this Post12-21-2007 09:07 AM Click Here to See the Profile for JazzManSend a Private Message to JazzManEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by JazzMan (edited 11-22-2011).]
Fastback 86
Total ratings: 231
Report this Post12-21-2007 01:15 PM Click Here to See the Profile for Fastback 86Send a Private Message to Fastback 86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Jazz, I was curious about something. When I switched from 15" wheels to 16" wheels, my car suddenly developed an intermittent shudder in the steering wheel at freeway speeds. Its only there at freeway speeds and there's no pattern to it, though it does seem more pronounced on poorer quality roads. Someone indicated to me that this could be a problem in the steering column, and from what I gathered from your article here, it may be those plastic gears that are meant to break in an accident, is that correct? You say this is non-repairable, does that mean I would need to replace the column or could it be rebuilt? My car has an aftermarket steering wheel that was installed by the previous owner, so I have no idea what amount of force may have been used to remove the original. My car is also sans steering dampener, though I would happily put it back if it might make a difference.
Toddster
Total ratings: 504
Report this Post12-21-2007 09:27 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
The steering column can't cause a shudder in the car. The opposite is true of course. More likely your problem is the alignment. Damper might be cause but without taking it for a spin it's hard to say.
BTW Jazz, Very nice write-up. I guess you're good for something afterall.
Fastback 86
Total ratings: 231
Report this Post12-22-2007 02:03 PM Click Here to See the Profile for Fastback 86Send a Private Message to Fastback 86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Its not a shudder in the car, though. Just the steering wheel itself, and only intermittently. The rest of the car feels perfect, its just the steering wheel.
Toddster
Total ratings: 504
Report this Post12-22-2007 04:29 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd check that alignment first. It could be the steering rack, tie rods, or ball joints but start with the cheaper problems first. It is unusual for a steering column to shake on its own. And considering it was fine until you changed wheels I'd go with the undercarriage first.
JazzMan
Total ratings: 653
Report this Post12-22-2007 07:07 PM Click Here to See the Profile for JazzManSend a Private Message to JazzManEdit/Delete MessageReply w/QuoteDirect Link to This Post
THE BEAST
Report this Post12-22-2007 07:48 PM Click Here to See the Profile for THE BEASTSend a Private Message to THE BEASTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow, I like it.
Thanks,
JG
buddycraigg
Total ratings: 478
Report this Post12-22-2007 08:42 PM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by JazzMan:
Ok, I've tuned this article up as much as I can, so barring any input or suggestions I'm going to consider it done.
Thanks for stopping by!
JazzMan
well you could have had more hot chics.
Fastback 86
Total ratings: 231
Report this Post12-23-2007 12:55 PM Click Here to See the Profile for Fastback 86Send a Private Message to Fastback 86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good to know, I'll check it out.
carnut122
Total ratings: 83
Report this Post12-23-2007 06:54 PM Click Here to See the Profile for carnut122Send a Private Message to carnut122Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm glad you posted this, as I "explored" my column when I installed a new turn signal shaft and ended up "forcing" things. Now I can refer to this to take care of issues in a better manner next time.
JazzMan
Total ratings: 653
Report this Post12-24-2007 10:09 AM Click Here to See the Profile for JazzManSend a Private Message to JazzManEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by JazzMan (edited 12-18-2008).]
Robert 2
Report this Post12-24-2007 11:57 AM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Why are they afraid ?
jscott1
Total ratings: 415
Report this Post12-24-2007 01:05 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wow how did I miss this thread? Awesome work. I have a loose column I'm ready to replace the whole thing rather than mess with it. I've been in the column before and it's kind of like brain surgery except harder.
Oh and thanks Cliff, for lifting the pic per post limit. Threads like this would have been impossible before, and harder to read with people interrupting every few posts.
[This message has been edited by jscott1 (edited 12-24-2007).]
Daredevil05
Report this Post12-25-2007 12:58 PM Click Here to See the Profile for Daredevil05Send a Private Message to Daredevil05Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good write up. You get a plus from me. I hate it when mechanics use the steering wheel as leverage to get in and out of these cars.
Dave
shawnkfl
Total ratings: 72
Report this Post01-05-2008 12:36 PM Click Here to See the Profile for shawnkflSend a Private Message to shawnkflEdit/Delete MessageReply w/QuoteDirect Link to This Post
awesome. my tilt function is loose. i can just pull the wheel down without using the lever. i have nother column that looks like crap but works good, so i think i'll go tear them down and build one back up. thanks for this write up! i'm going to print the whole thing and get to work!
buddycraigg
Total ratings: 478
Report this Post06-11-2008 11:42 PM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
(this post will sound wrong because this person contacted me via youtube)
Troy,
read through this thread also
https://www.fiero.nl/forum/Forum2/HTML/089378.html
[This message has been edited by buddycraigg (edited 06-11-2008).]
Intel
Total ratings: 53
Report this Post07-25-2008 07:07 PM Click Here to See the Profile for IntelSend a Private Message to IntelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tore down my tilt column today because it was loose.
Everything went smooth, got those 4 torx bolts tightened with red loctite but when I put it all together I got some movement in the shaft.
After looking at your pictures I think I put the preload cup on the upper bearing the wrong way (it fell out when I was struggling with the U-joint separation so I didn't notice how it was placed).
Will have to check this tomorrow. Hope it's the culprint because the threads in my pivot pins won't last another pull (using M4 homebrew puller).
The only thing I can't see in your pictures is how the black plastic ball bearing retainer (upper) is located. It's a little bit bigger in one end and when you put the bearings in you hold it with the bigger chamfered end up. Do you just lower it onto the shaft like this or flip it over using grease to hold the bearings in place?
Anyway thanks for making stuff like this... I know you've put lots of time making this guide. Every time I'm going to make a writeup I get so carried away that I forget to take any pictures and end up with before and after shots.
Intel
Total ratings: 53
Report this Post07-26-2008 01:46 PM Click Here to See the Profile for IntelSend a Private Message to IntelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok I fixed it.
It was the preload cup that I had reversed so that it didn't put enough pressure on the race.
Now it's all tight and non-wobbly.
And again...thanks for this super detailed writeup!!
Sidecar 2M6 SE
Report this Post10-08-2008 12:49 AM Click Here to See the Profile for Sidecar 2M6 SESend a Private Message to Sidecar 2M6 SEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks man!! This so informative. If you are not already a technical writer by trade, you should be!
I have two wobbly columns. The one I took out 2 years ago and the one I put in as a replacement which at that time didn't wobble but does now. Now I know why and I agree about the small tab area on the lower plate. Loctite on those 4 torx bolts it is!
fieroboom
Total ratings: 81
Report this Post12-18-2008 03:57 PM Click Here to See the Profile for fieroboomClick Here to visit fieroboom's HomePageSend a Private Message to fieroboomEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wish I'd had this 2 years ago! Awesome job, Jazzman. Another + for ya!
Journal of a concept: http://southeastfieros.com >>> Build Thread >>> Parts thread (for project funding)
DIY_Stu
Total ratings: 111
Report this Post01-01-2009 02:18 AM Click Here to See the Profile for DIY_StuClick Here to visit DIY_Stu's HomePageSend a Private Message to DIY_StuEdit/Delete MessageReply w/QuoteDirect Link to This Post
For anyone who would like a printable version of this I have converted this and another thread to PDF for you.
Jazzman_Steering_Rack_Rebuild.pdf
Stu
Robert 2
Report this Post01-01-2009 03:23 AM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Tried to download
result : message File corrupted can't be fixed ?
[This message has been edited by Robert 2 (edited 01-01-2009).]
DIY_Stu
Total ratings: 111
Report this Post01-01-2009 04:25 AM Click Here to See the Profile for DIY_StuClick Here to visit DIY_Stu's HomePageSend a Private Message to DIY_StuEdit/Delete MessageReply w/QuoteDirect Link to This Post
I made so many changes to it I reuploaded it. Might have been whenyou were getting it. I'm done now.
DIY_Stu
Total ratings: 111
Report this Post01-01-2009 12:23 PM Click Here to See the Profile for DIY_StuClick Here to visit DIY_Stu's HomePageSend a Private Message to DIY_StuEdit/Delete MessageReply w/QuoteDirect Link to This Post
DIY_Stu
Member since Jun 2007
I decided to make these pdf's because the write up is better than the one in the Factory Service Manual. That and the fact that I need it due to my sector slide gear failing on me last night. I had to drop the column just to get the dang thing started. Now knowing that I have to go somewhere I should have pulled the Ignition switch off until it was fixed. Grrrrrr.
Robert 2
Report this Post01-02-2009 03:22 AM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Works OK now thanks
telefragg3d
Report this Post02-06-2009 04:32 PM Click Here to See the Profile for telefragg3dSend a Private Message to telefragg3dEdit/Delete MessageReply w/QuoteDirect Link to This Post
this post is fantastic! thanks so much. i might have to pull apart the column to fix my turn signal switch...agh!
Fiero1Fan
Total ratings: 100
Report this Post03-10-2009 11:54 PM Click Here to See the Profile for Fiero1FanClick Here to visit Fiero1Fan's HomePageSend a Private Message to Fiero1FanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great How To.
Fiero1Fan
Fieros Europe
Back On Holiday
Report this Post03-23-2009 09:41 PM Click Here to See the Profile for Back On HolidaySend a Private Message to Back On HolidayEdit/Delete MessageReply w/QuoteDirect Link to This Post
Excellent Work, only suggestion is to add a Tear down part to your rebuild part
katatak
Total ratings: 82
Report this Post03-23-2009 11:15 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am currently having a problem on my 88 Auto column. I have read through this thread but need some clarification. Here's my problem.
When I go to shut the car off - turn the ignition switch, it sometimes will not turn to the point where you can remove the key - like it is jammed. Sometimes it jams completely and I can not turn it in any direction or get the key out. If I wiggle the steering wheel and move the auto shifter back and forth, eventually it will release and I can get the key out. I believe there is a cable from the shifter to the column? if so, is there an adjustment that can be made or is the problem in the column in the ignition lock setup? Thanks in advance.
Pat
DIY_Stu
Total ratings: 111
Report this Post03-23-2009 11:52 PM Click Here to See the Profile for DIY_StuClick Here to visit DIY_Stu's HomePageSend a Private Message to DIY_StuEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had this problem right before it wouldn't start any more. Here's your fix.
http://www.autozone.com/aut...Value=100836&categor yNValue=101314&fromWhere=&subPartId=prod11818&itemId=prod11818&displayName=Ignition+Switch+Rack+Kit
Autozone Rack Repair kit Part Number: 83211
While you're in there if you wish you can also tighten up the reverse torx screws. Word to the wise MARK THE SHAFT that the steering wheel goes onto to indicate the UP position. I put mine on up side down after the ball joint popped loose at a 90º bend. So I got to tear down and rebuild the column twice!!!
[This message has been edited by DIY_Stu (edited 03-24-2009).]
DIY_Stu
Total ratings: 111
Report this Post03-24-2009 12:00 AM Click Here to See the Profile for DIY_StuClick Here to visit DIY_Stu's HomePageSend a Private Message to DIY_StuEdit/Delete MessageReply w/QuoteDirect Link to This Post
The metal part gets bent over time then starts hanging it all up.
Chris_86GT
Report this Post03-24-2009 05:19 AM Click Here to See the Profile for Chris_86GTSend a Private Message to Chris_86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Added to favorites, great job JazzMan, + for you.
Doni Hagan
Total ratings: 127
Report this Post03-24-2009 10:11 AM Click Here to See the Profile for Doni HaganSend a Private Message to Doni HaganEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks a lot for this thread. I got so disgusted with floppy steering wheels (2 different steering columns) that I got rid of the tilt altogether. I've still got the columns though and will try to rebuild them.
katatak
Total ratings: 82
Report this Post03-24-2009 07:52 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Stu - Sounds like I know what I'll be doing this weekend.
Pat
Back On Holiday
Report this Post03-24-2009 11:49 PM Click Here to See the Profile for Back On HolidaySend a Private Message to Back On HolidayEdit/Delete MessageReply w/QuoteDirect Link to This Post
you might consider sending them away to jazzman to rebuild if he still does them, it might be worth it
madcurl
Total ratings: 314
Report this Post05-12-2009 12:14 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
This thread must be... Saved! (as favorite).
fieroparts.com
Total ratings: 185
Report this Post10-28-2009 12:59 PM Click Here to See the Profile for fieroparts.comClick Here to visit fieroparts.com's HomePageSend a Private Message to fieroparts.comEdit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post10-29-2009 12:00 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
So you think a Ignition Switch is bad?
Maybe and Maybe Not.
Check very carefully the linkage. Linkage can die as well because bad switch overloads it. If link is anything but straight then is bad. Do Not try to fix it. Replacement is only option. Check gear teeth to.
Bend then straighten make it weak.
NAPA or Dorman's HELP! at most auto part store.
Always replace ignition switch when you replace linkage! You do not want to replace the linkage twice.
The Ogre's Fiero Cave (It's also at the top of every forum page...)
[This message has been edited by theogre (edited 10-29-2009).]
jwct7
Report this Post10-30-2009 08:12 PM Click Here to See the Profile for jwct7Send a Private Message to jwct7Edit/Delete MessageReply w/QuoteDirect Link to This Post
JazzMan
jwct7
Report this Post10-30-2009 08:15 PM Click Here to See the Profile for jwct7Send a Private Message to jwct7Edit/Delete MessageReply w/QuoteDirect Link to This Post
jwct7
Member since Mar 2004
Originally posted by jwct7:
So I have to dismantle all the top end just to change the ignition Barrel?
The chime switch had me thinking.... I have just had a problem appear where my Chime will not turn off, even while I'm driving??? I pulled it out for now, but I have changed the door switches and the one under the hood, I don't have anything at the rear. The lights all go out but the chime sings away, any ideas?
Post New Topic
