  How To - Repair the Fuel Level Sending Unit (Page 1)
How To - Repair the Fuel Level Sending Unit by Xanth
Started on: 05-26-2008 06:36 PM
Replies: 95 (22679 views)
Last post by: 813-fiero on 06-14-2018 08:48 PM
Xanth
Total ratings: 174
Report this Post05-26-2008 06:36 PM Click Here to See the Profile for XanthSend a Private Message to XanthEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did this repair on mine today, and now my gauge went from running out of gas at 1/2 tank, to actually reading almost right on.
Also available on FieroDomain: http://fierodomain.com/arti...ro-fuel-level-sender
First step, drop the tank and pull the sending unit. Process on doing so is covered elsewhere.
Now, check the resistance at the terminals connected to the Black and Purple wires. Or if yours is different just test the ground wire and whichever is connected to the float. Normal operation is 0ohms empty, 90ohms full.
Here is mine before the repair, with the float in the empty position I'm getting a reading of 40.6, nearly a half tank.
Remove these two Torx screws to get at the resistor, be careful not to lose the two springs:
Here is the resistor, you can see quite a bit of build up. Fortunately we are only really concerned with the leading edge, and the mount location.
Gently clean this leading edge, this is where the float mechanism slides against. I used a coarse sponge, very fine sandpaper may work as well.
Clean this plate as well, the spring needs to make good contact in this area:
Sand clean both ends of the upper spring, as well as the metal plate it contacts:
Re-assemble the resistor to the sending unit, ensuring the plate from the float is behind the resistor:
Re-test your sending unit in both the empty and full positions. I now get 7.6 empty and 107.6 full, this will work okay for now. I can adjust the gauge to compensate for the slightly high reading.
Re-install your sending unit into the tank and re-test. On mine, I had to bend the float arm up slightly, it appeared to be hitting the bottom. In fact, in the empty position it was below the bottom level of the pump.
Bending float arm:
Re-testing in tank:
My tank used to run out when the gauge read 1/2 , and filling the tank would result in the gauge pegging way off to the right. Now the gauge is nearly right-on. With the tank totally empty the needle is just above the empty mark, and filling the tank puts the needle just above full. This is the result of being high by 7.6ohms. Since its off by the same amount on both ends I'll just re-adjust the needle to be correct on empty.
www.FieroDomain.com
"If any car is both the parade and the rain, it is the Fiero"
[This message has been edited by Xanth (edited 06-17-2011).]
Nazareth
Total ratings: 60
Report this Post05-26-2008 06:41 PM Click Here to See the Profile for NazarethSend a Private Message to NazarethEdit/Delete MessageReply w/QuoteDirect Link to This Post
Excellent write-up... I'll be trying this in a few weeks... Thanks alot!!
daniel87fierogt
Total ratings: 52
Report this Post05-26-2008 08:54 PM Click Here to See the Profile for daniel87fierogtSend a Private Message to daniel87fierogtEdit/Delete MessageReply w/QuoteDirect Link to This Post
The fiero sending unit is 0-90 ohms. So your are about 17 ohms over full but you got really close to 0 on the bottom end.
Xanth
Total ratings: 174
Report this Post05-26-2008 08:57 PM Click Here to See the Profile for XanthSend a Private Message to XanthEdit/Delete MessageReply w/QuoteDirect Link to This Post
Doh!
You're right I overshot, I'll correct the info in there. Have to see what I can do about getting it down to 90 ohms
Saxman
Total ratings: 114
Report this Post05-26-2008 10:05 PM Click Here to See the Profile for SaxmanClick Here to visit Saxman's HomePageSend a Private Message to SaxmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great stuff! Thanks for posting. I need to do this on the Formula. I ran out of gas last week at a 1/4 tank!
Cheers to you!
randye
Total ratings: 210
Report this Post05-26-2008 10:14 PM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just curious how tuff the crud on the resistor and other parts was to get cleaned off?
I was thinking maybe "TARNEX" brand tarnish remover might work really well. I've used it on old corroded copper ground straps and various electrical connections and had them come out looking brand new. It's also plastic safe as far as I know. Works good on other metals too, except aluminum.
Just a thought.....
procarnut
Report this Post05-26-2008 10:39 PM Click Here to See the Profile for procarnutSend a Private Message to procarnutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Excellent! Good job on the write up and kudos for the pictures....Now I just need to find a clean gas tank, Upgrade fuel pump and get to work...
fresnofiero
Report this Post05-27-2008 12:54 AM Click Here to See the Profile for fresnofieroSend a Private Message to fresnofieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is that the 88 sending unit? It looks way different than my 87 sending unit. I did mine today. I had to pry a tab back to get to everything inside then is carefully used a stainless steal wire brush and scrubbed everything and went from empty at 43.2 ohms - 304.6 ohms full with multiple OL's along the swing to 0.9 ohms empty - 92.3 ohms full with a clean signal from top to bottom. Now I just got to get the tank back in. If I hadn't seen your post I wouldn't have thought about cleaning mine while replacing my tank.
fresnofiero
Report this Post05-27-2008 12:57 AM Click Here to See the Profile for fresnofieroSend a Private Message to fresnofieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
fresnofiero
Member since Mar 2006
I hate it when I double post. Woops. Sorry.
[This message has been edited by fresnofiero (edited 05-27-2008).]
Gokart
Total ratings: 94
Report this Post05-27-2008 03:36 AM Click Here to See the Profile for GokartSend a Private Message to GokartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Excellent write-up! Thanks for taking the time to document this info! I'll be saving this and will add it to my list of jobs to do. My gauge does read full after fill up but never gets lower than the 1/4 tank mark. I found this out the hard way a couple years back when I first got this car
sjmaye
Report this Post05-27-2008 06:25 AM Click Here to See the Profile for sjmayeSend a Private Message to sjmayeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Excellent, Xanth. Thanks!
Jeckel
Report this Post05-27-2008 12:12 PM Click Here to See the Profile for JeckelSend a Private Message to JeckelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would this work on a sending unit that reads 1/2 tank when full, and just above empty when your coasting to a stop 1/2 mile before you get to the gas station?
revin
Total ratings: 234
Report this Post05-27-2008 12:40 PM Click Here to See the Profile for revinSend a Private Message to revinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dam where were you when I had my tank out last year? Mine is so waaaayyyy off it is not funny.
NOW I just reset the trip and when it hits around 125 miles...start looking for a gas station
Great write up
jetman
Total ratings: 273
Report this Post05-27-2008 03:13 PM Click Here to See the Profile for jetmanClick Here to visit jetman's HomePageSend a Private Message to jetmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Outstanding job.
You explain it so well that I can easily perform this repair myself.
It's contributions like this that make this forum such a great place.
Thank you.
TK
Total ratings: 200
Report this Post05-27-2008 03:58 PM Click Here to See the Profile for TKSend a Private Message to TKEdit/Delete MessageReply w/QuoteDirect Link to This Post
You deserve a plus for this. We need to start handing out more ratings in Tech and General and less in OT. This one qualifies.
85LAMB
Report this Post05-27-2008 05:15 PM Click Here to See the Profile for 85LAMBSend a Private Message to 85LAMBEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just wanted to say thanks for the great write up.
Can you please tell me what could cause the fuel gauge needle to go "nuts" jump up and down and do a 360 degree turn around ?
I am hoping you might have an answer.
Thanks for you help again
Xanth
Total ratings: 174
Report this Post05-27-2008 07:27 PM Click Here to See the Profile for XanthSend a Private Message to XanthEdit/Delete MessageReply w/QuoteDirect Link to This Post
Glad everyone likes the write-up so far, good to see its already helped a few people
On mine the build up was actually fairly easy to get off, but I was using a somewhat abrasive sponge to remove it. A chemical cleaner may do the trick if let to sit long enough.
Yep, 88. I'm kind of surprised it looks different than yours since the 87-88 used the same tank. I didn't realize there were variants in the sending units over the years.
That actually sounds like someone re-adjusted the gauge itself to read closer to empty. Typically the crud build-up on the sending unit will result in increasing the resistance, which gives you a higher reading. A full tank will peg the gauge, and you'll run out of gas around 1/4 or 1/2 tank. I would guess your sending unit has the problem, but someone re-positioned the needle on the gauge.
You could try filling your tank, then testing the resistance at the connector for the pump/sending unit in the engine bay to see how accurate it is.
Before I cleaned my sending unit, moving it from the empty to full position and back would show huge jumps in resistance as the float connector moved over the resistor. Once I cleaned it the reading was much more smooth across the resistor. Possible thats your problem.
Xanth
Total ratings: 174
Report this Post05-29-2008 08:23 PM Click Here to See the Profile for XanthSend a Private Message to XanthEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had one other thought, I believe the gauge is supposed to have some built-in damping function. So even if the signal is all over the place the gauge should only move slowly. This may actually be a problem with your gauge itself.
mickeyswing52
Report this Post05-30-2008 07:29 PM Click Here to See the Profile for mickeyswing52Send a Private Message to mickeyswing52Edit/Delete MessageReply w/QuoteDirect Link to This Post
Xanth Great write up. I did the repair tonight. My reading before I cleaned the resister plate was 13 on empty and 100 on full. Before I pulled the resister plate I used a calipers to measure the distance from the plate to the bracket so I could get it back to where it was, because the screws on two of the units I have were not tight. When I put it back together I was down to 8 on empty to 100 on full. I then put the meter on and read the low side and turned the screw out and I was able to get a reading off 3. Then went to the high and turned the screw in and was able to get it to read 90. Maybe that is why the screws were not tight in the first place because they are used to adjust the high and the low. If you look at the float arm it swings on an arc so that would change the low and high readings. Longer arc or shorter arc. Will have to try it later on the other sending unit but it should be the same. Hope this Helps. Lynn
mickeyswing52
Report this Post05-30-2008 07:34 PM Click Here to See the Profile for mickeyswing52Send a Private Message to mickeyswing52Edit/Delete MessageReply w/QuoteDirect Link to This Post
mickeyswing52
Member since Jan 2006
Bump
Xanth
Total ratings: 174
Report this Post05-30-2008 08:10 PM Click Here to See the Profile for XanthSend a Private Message to XanthEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe you're right about the screws, I tried to do that on mine but the resistor was still far enough off I wasn't able to compensate for it with the screws alone.
I'll probably take the unit out again and see if I can get it closer. I originally thought the range was 0-100, so I stopped once I got 100ohms of range.
BMTFIERO
Report this Post05-31-2008 03:26 AM Click Here to See the Profile for BMTFIEROSend a Private Message to BMTFIEROEdit/Delete MessageReply w/QuoteDirect Link to This Post
THank you for taking the time to post this because I really needed this info.
josef644
Total ratings: 103
Report this Post05-31-2008 02:05 PM Click Here to See the Profile for josef644Send a Private Message to josef644Edit/Delete MessageReply w/QuoteDirect Link to This Post
I also did this to my coupe, to repair a non working guage. I might add that I also cleaned the wiper on the float arm also before I re assembeled the sending unit. I just followed these same simple steps. I had a fit trying to find a new o-ring for the tank. I ended up getting a new one from the local GM dealer. It was very pricey as I remember.
Great writte up
Joe Crawford
Texas
sjmaye
Report this Post06-01-2008 03:08 AM Click Here to See the Profile for sjmayeSend a Private Message to sjmayeEdit/Delete MessageReply w/QuoteDirect Link to This Post
BUMP
sjmaye
Report this Post06-18-2008 04:07 AM Click Here to See the Profile for sjmayeSend a Private Message to sjmayeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am going to pull my tank for De-Rusting (my favorite pass time). Even though everything was working with the pump and fuel gauge is there something I should do or check while the tank is out?
PaulJK
Total ratings: 237
Report this Post06-18-2008 04:41 AM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
Xanth, Very Nice write-up :0 . Have you seen the 2 threads about increasing the capacity of the tank ? One involves re-locating the vent tube to a higher position on the tank (cutting required) and the other involves adding a bent piece of tubing to the vent tube INSIDE the tank effectively raising the tube. Maybe it's something you wanna try since you have the tank out.
I was looking through the Summit catalog and saw that Auto Meter makes a "programmable" gas gauge - anybody have any experince with anything like this ?
http://store.summitracing.c...700+115&autoview=sku
[This message has been edited by PaulJK (edited 06-18-2008).]
Toddster
Total ratings: 504
Report this Post06-18-2008 02:06 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've done this before and adjusting the top end to 90 ohms is not too hard but you will never get zero ohms on the bottom end. The closest I ever got was 1.7 ohms...close enough for par though.
Alex4mula
Report this Post06-18-2008 03:07 PM Click Here to See the Profile for Alex4mulaSend a Private Message to Alex4mulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
This should be a stickie. We should have a stickie section of good common repair threads like this. That way we don't have to pull hair trying to search. Plus to you
Fiero Owner
Report this Post06-18-2008 04:06 PM Click Here to See the Profile for Fiero OwnerSend a Private Message to Fiero OwnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great writeup, I'm going to do this when I drop my tank to change the fuel pump here soon.
Xanth
Total ratings: 174
Report this Post06-18-2008 05:04 PM Click Here to See the Profile for XanthSend a Private Message to XanthEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did read through at least one of those threads, looks tempting but it will probably be awhile before I attempt that.
Once I have a moment I'll have this article available on my site along with the others
Xerces_Blackthorne
Total ratings: 160
Report this Post06-18-2008 06:01 PM Click Here to See the Profile for Xerces_BlackthorneSend a Private Message to Xerces_BlackthorneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heh, you aren't the only one...I was on my way to cash my paycheck and ran out of gas 3 miles away at 1/4 on the tank....
Looks like I will be doing this soon too, thanks for the write up WITH pics... All the other tech articles I have found online were sans pics, making it harder...
FieroBobo
Report this Post06-18-2008 07:30 PM Click Here to See the Profile for FieroBoboSend a Private Message to FieroBoboEdit/Delete MessageReply w/QuoteDirect Link to This Post
Xanth
Thanks for a great write-up. The photo documentation is really great. As they say 1 picture is worth a thousand words. (And its especially helpful to those of us who are visual learners.)
Now I know how to fix the gas gauge on my favorite vehicle.
Thanks again, on a job well done.
~Bob
"Its nice to be important.
Its more important to be nice."
Xanth
Total ratings: 174
Report this Post06-20-2008 10:43 PM Click Here to See the Profile for XanthSend a Private Message to XanthEdit/Delete MessageReply w/QuoteDirect Link to This Post
The article is now up on FieroDomain
http://fierodomain.com/content/view/300/100/
AndrewZ
Report this Post06-21-2008 08:04 AM Click Here to See the Profile for AndrewZSend a Private Message to AndrewZEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am going to remember you site (http://fierodomain.com/content/category/8/37/100/) for reference and check there first instead of coming here and asking "How do I do this and I want a real nice write up with lots of pic" Good job. A plus for your how-to articles.
Andrew
americasfuture2k
Total ratings: 105
Report this Post07-18-2008 04:31 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
bumping to add to favorites.
1987 Fiero GT built by my brother, merlot566jka, 3500 LX9 from 06 Malibu, WOT-TECH.com 1280 grind stage 3 cam, LS6 valve springs, 1227730 ECM conversion, Darrel Morse solid aluminum cradle mounts, Truleo headers modified to fit the 3500, 36# inectors, 70mm 4.3 throttle body adapted to 3500 intake, ported heads, upper and lower intakes, lightly polished, tcemotorsports.com crank trigger wheel, CenterForce dual friction clutch, Flowtech Afterburner muffler, 2.5" piping, cat deleted, EGR deleted, SinisterPerformance tuning, C6 Corvette exhaust tips. projected to be 35 MPG with a guesstimate of 250 hp to the wheels
vortecfiero
Total ratings: 57
Report this Post07-19-2008 09:40 AM Click Here to See the Profile for vortecfieroClick Here to visit vortecfiero's HomePageSend a Private Message to vortecfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great "How to"
working on these things isnt all cold air intakes and exhaust tips lol
nice to see a "plain old fix whats not working" by testing and finding
the real problem rather than replacing almost everything
87 Fiero GT 5sp with Vortec L35 4300 Turbocharged V6
Bully Stage 2 clutch
Syclone intake manifold and engine management with Moates adapter and chip burner
Air/water intercooler and Devil's Own progressive water/alky injection
50lb injectors, 3 bar map sensor, Walboro fuel pump and Jabasco Intercooler pump
LM1 wideband on custom manifolds and 3" stainless exhaust system
T31/T04B H3 turbo and a S10 caliper conversion.
Murphy's Constant Matter will be damaged in direct proportion to its value
Murphy's Law of Thermodynamics Things get worse under pressure.
Arthur C. Clarke "Any significantly advanced technology is indistinguishable from magic"
Saxman
Total ratings: 114
Report this Post09-24-2008 04:17 PM Click Here to See the Profile for SaxmanClick Here to visit Saxman's HomePageSend a Private Message to SaxmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cheers to you!
I went to do this on the '84 Fino and the sensor is different. It's a curved pickup inside a different housing. Thanks for still getting me to check the inside for corrosion. All is good.
Now - on to the Formula sender! Thanks, X!
Dizzixx
Report this Post09-24-2008 04:31 PM Click Here to See the Profile for DizzixxSend a Private Message to DizzixxEdit/Delete MessageReply w/QuoteDirect Link to This Post
With that type of housing I used JB weld and moved the outside cover when the metal tabs holding it inplace broke, while the JB wel was setting I adjusted the cover in relation to the rest of it and then clamped it in plavce when I got it to 2ohm and 96ish, not perfect but easy and it is much better than before.
Saxman
Total ratings: 114
Report this Post09-24-2008 04:44 PM Click Here to See the Profile for SaxmanClick Here to visit Saxman's HomePageSend a Private Message to SaxmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
All my tabs were intact so I just bent them back over the cover. I don't know if I'd trust JB Weld constantly sitting in gas. Does JB hold up in a tank? I'd hate to have it break up inside the tank.
BMTFIERO
Report this Post11-18-2009 01:36 AM Click Here to See the Profile for BMTFIEROSend a Private Message to BMTFIEROEdit/Delete MessageReply w/QuoteDirect Link to This Post
"A keeping it fresh" BUMP
