  Poly Suspension Upgrade (all pics) (Page 3)
Poly Suspension Upgrade (all pics) by MulletproofMonk
Started on: 09-04-2008 09:56 AM
Replies: 153 (24971 views)
Last post by: pmbrunelle on 05-27-2024 05:43 PM
MadDanceSkillz
Total ratings: 88
Report this Post03-09-2010 10:08 PM Click Here to See the Profile for MadDanceSkillzSend a Private Message to MadDanceSkillzEdit/Delete MessageReply w/QuoteDirect Link to This Post
After 8 hours of not knowing whether my hands were covered in my blood or the red Mobil 1 synthetic suspension grease I am using, side one is done. I replaced the outer Tie rod and tie rod end, upper and lower ball joints, wheel bearings and races, all rubber bushings have been converted to poly, a new high performance shock has been installed along with an Eibach lowering spring, and everything has been blasted with about 3 cans of brake parts cleaner and painted. Whew!
As for shortcuts, I really found none. The worst part of the entire job was probably reattaching the lower control arm. What a pain! Stick one side in, get the bolt in, and get the other side into position. I had to use the spare tire prybar to align the hole on the other side. Speaking of, you DO have to cut down those caps considerably. Mine had to be cut down to literally half of their previous size and they barely squeezed in. I actually had to grease the sockets for the arms.
Thanks for all the pictures, Brian. Pretty much everything was self explanatory but if it were not for your pictures I would have installed several of the poly bushings the wrong way around. The only thing left on this side is the end link for the sway bar (Mine was in very bad shape and it will need replaced rather than reinstalled).
Let me say this to everyone thinking about this swap...it does not require much specific knowledge, but it is NOT for the faint of heart. Just make sure you have the right tools, a lot of time, and a mindset that this isn't getting done in 3 hours. Take your time, do it right, and try not to bang up your hands and arms s much as I did. There's blood caked on the metal surrounding the rotor as I never removed the rotor...haha. I'll post again once the passenger side is done.
And once again, thanks, Brian. It would have been terrible to get this far and realize I installed bushings backwards only to take the entire thing apart again!
86GT Modded 3.4l Pushrod V6 with Trueleo
1972 Honda CB350 Motorcycle
PM Me if you need:
Interior/Exterior Parts
Stock Switches/Bezels
Gauge Clusters
Body Panels
Fiero Rotor Hubs for Brake Swaps
Or custom fabricated parts! My prices are very low.
randye
Total ratings: 204
Report this Post03-09-2010 11:36 PM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm going to both *agree* and *disagree* with those who said don't use the poly dust boot covers.
The fact is, you *can* use them, but you must modify them slightly by using a small knife or an xacto blade and open the small end of the poly cover up enough to fit
OVER the stock rubber dust boot.
I don't fault anyone for using the nifty red polyurethane dust boots, they look great, and I used them on my 87 GT specifically because they look good.
Only difference is I used them with the rubber OEM style boots under them. They fit just fine.
MadDanceSkillz
Total ratings: 88
Report this Post03-10-2010 01:00 AM Click Here to See the Profile for MadDanceSkillzSend a Private Message to MadDanceSkillzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Randye,
I did the same thing. MORE sealing power that way and better looks.
I don't know about other kits, but the Prothane boots are very soft, almost as soft as rubber. I think they would actually seal well on their own. I just used both at once since mine were in good shape anyway....well, at least some of them were!
The whole dust booth thing is a bot ridiculous, I think. Your car is unlikely to explode or fall apart if you -properly- use poly dust boots. And I haven't heard of any poly dust boot related engine fires yet.
MadDanceSkillz
Total ratings: 88
Report this Post03-10-2010 12:45 PM Click Here to See the Profile for MadDanceSkillzSend a Private Message to MadDanceSkillzEdit/Delete MessageReply w/QuoteDirect Link to This Post
MadDanceSkillz
Member since Jan 2009
Round two begins...my rubber was really trashed. That explains the subpar handling...
MadDanceSkillz
Total ratings: 88
Report this Post03-10-2010 12:49 PM Click Here to See the Profile for MadDanceSkillzSend a Private Message to MadDanceSkillzEdit/Delete MessageReply w/QuoteDirect Link to This Post
MadDanceSkillz
Forgot to mention a useful tip...buy 4 or 5 cans of brake cleaner if you're like me and don't have an air ratchet. These bolts have been in for 25 years and believe me, they don't want to come out. Spraying break parts cleaner on the bolts and the threads on the other side of what they are bolted to makes removal MUCH easier.
Edit for another good tip:
The upper A-Arm or control arm or whatever you want to call it uses two thick washers. It is nearly impossible to fir both of them back in once you do the poly, the trick is to pound the poly back out a bit so the washers fit in and then use the force of tightening down the big long bolt to push the poly back in. Some tapping may be required to get it to seat all the way in again. This will save you at least 20 minutes of frustration.
Yet another suggestion: Replace the upper ball joints and steering stabilizer while you do this. The lower ball joints are, as always, a pain in the ass, but the uppers are extremely easy and you have to almost remove them anyway.
[This message has been edited by MadDanceSkillz (edited 03-10-2010).]
Brembo-Fiero
Report this Post03-10-2010 07:40 PM Click Here to See the Profile for Brembo-FieroSend a Private Message to Brembo-FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
How sore are your hands and the forearms?
Don´t forget to align the suspension after all that hard work.
Do you have some pictures?
Jürgen Martin
white GT 87
Germany
MadDanceSkillz
Total ratings: 88
Report this Post03-10-2010 09:06 PM Click Here to See the Profile for MadDanceSkillzSend a Private Message to MadDanceSkillzEdit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't take pictures because Brian already did a great job of that. Mine looks a lot like his just with new ball joints, tie rods/ends etc and blue sway bar end links instead of red.
And yes, I'm very, very sore. Hopefully my girlfriend will help out with that with a back/shoulder rub. She's reading this as I type it. Hint, hint
MadDanceSkillz
Total ratings: 88
Report this Post03-11-2010 11:30 AM Click Here to See the Profile for MadDanceSkillzSend a Private Message to MadDanceSkillzEdit/Delete MessageReply w/QuoteDirect Link to This Post
After around 21 hours of work my front suspension has been completely rebuilt. My hands and arms are bloodied and scarred and I don't know if the grease will ever wash out, but it's done. Now I just have to do the struts and limp it into down for an alignment.
Thanks for the thread, Brian.
Wickedlilpleasures
Report this Post07-01-2010 12:58 PM Click Here to See the Profile for WickedlilpleasuresSend a Private Message to WickedlilpleasuresEdit/Delete MessageReply w/QuoteDirect Link to This Post
Damn GReAT WORK~!.. Im taking notes love it very neat
PerKr
Report this Post07-01-2010 03:21 PM Click Here to See the Profile for PerKrClick Here to visit PerKr's HomePageSend a Private Message to PerKrEdit/Delete MessageReply w/QuoteDirect Link to This Post
these threads are so great to have when you're working on stuff like this
when I disassembled my front suspension I noted that the front and rear bushings/pivots of the lower control arms don't line up. has anyone noticed any excessive wear due to this?
I also feel that while the upper control arm bushings were easy to press out, I have to recommend the fire process for the (front) lower control arms. I managed to deform the left LCA trying to press the rubber out of its sleeve (managed to get it somewhat proper with a hammer, but I have a lot of measuring, hammering and brazing to do before I can even think of putting new bushings in there)
edit to add a question: do you re-use the old bushing inner tubes or do the poly bushings come with new ones?
[This message has been edited by PerKr (edited 07-01-2010).]
pmbrunelle
Total ratings: 63
Report this Post07-02-2010 05:37 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
The front lower arm pivot bushings are non-collinear by design. I don't know the reason for it being that way, but it's normal.
The bushing kits come with new inner sleeves.
MulletproofMonk
Total ratings: 78
Report this Post07-02-2010 10:36 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dang, my thread rises from the dead...
The bushings came with new inner sleaves.
-Brian
Removing the roof panel
MulletproofMonk
Total ratings: 78
Report this Post09-30-2010 02:56 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just wanted to post that the seller ilikeike1 is who I used on eBay to get my bushings the first time and have used him everytime since. He has been fast to ship and I have never had any issues with him. I have also purchased dogbone bushings and cradle bushings from him.
-Brian
kkavmann69
Report this Post10-02-2010 06:59 PM Click Here to See the Profile for kkavmann69Send a Private Message to kkavmann69Edit/Delete MessageReply w/QuoteDirect Link to This Post
A+ for you. Great write up. I'll be saving this one for when I'm ready to do mine.
redraif
Report this Post09-20-2011 11:03 AM Click Here to See the Profile for redraifSend a Private Message to redraifEdit/Delete MessageReply w/QuoteDirect Link to This Post
a bump to keep a great thread alive! I found it just in time to start my front poly install.
Thank you all for the informative posts! And kudos to the OP for taking and posting informative pics for all to follow! You have made me much more confident going in!
MulletproofMonk
Total ratings: 78
Report this Post10-11-2011 05:46 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow, 8710 views as of 9-20-2011. Nice to hear it is helping people out.
-Brian
Edit to say that I noticed my garage shoes in the picture from 2008... and I'm still using them today...
[This message has been edited by MulletproofMonk (edited 10-11-2011).]
rager87gt
Report this Post10-11-2011 06:48 PM Click Here to See the Profile for rager87gtSend a Private Message to rager87gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
This IS a great thread, espessially as I too am doing this project right now! Only one corner done so far though.
If any of you guys do the aluminum cradle bolts, please post alot of pictures!!!
Particuarly if you are not removing the cradel!
Thanks again for a very good visual thread!!!!
Later,
Mike.
redraif
Report this Post10-11-2011 06:53 PM Click Here to See the Profile for redraifSend a Private Message to redraifEdit/Delete MessageReply w/QuoteDirect Link to This Post
Working on my fronts now... still in the disassembly stage.... so far so good
tehmaxfactr
Report this Post10-12-2011 11:27 AM Click Here to See the Profile for tehmaxfactrSend a Private Message to tehmaxfactrEdit/Delete MessageReply w/QuoteDirect Link to This Post
How much different is this process from an 88. I want to replace all my brushing this winter mine are cracked up.
redraif
Report this Post10-17-2011 01:38 PM Click Here to See the Profile for redraifSend a Private Message to redraifEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got through it, but the darn front lower control arms are a beast... the bushing were really in there. I tried to drill them... burning I think is the ticket! Also, it does not show here, I can back for referance... the front most bolt on the front LCA... is it supposed to be oriented with the nut to the rear of the car. I had a bear of a time pulling the bolt out from under the steering rack boot. It was hitting horribly... Did anyone else have this issue?
MulletproofMonk
Total ratings: 78
Report this Post10-17-2011 02:33 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok is this normal? Why would GM do this? Did the Previous owner take it apart and put it back backwards?
I'm getting total interferance from the rubber boot on the steering rack while trying to remove the bolt from the front most leg on the lower control arm. I had to pry on the rubber boot to even try to get it out and it did not work. Surely GM did not intend for us to remove the rack to remove the LCA's. Yes it's the same on both sides... I even pushed the tierod up hoping the joint would move it further out of the way... nope...
Is the nut supposed to go on this side instead?
So here was what I had to do to get the darn thing out...
So I got them both out, but I don't see how on earth I could ever line it back up to get it back in this way, esp get it back in straight. The next question is, do I put is back together like this? or reverse it and put the nut to the front instead? What did you do?
Thank you!
So, I saw your other thread and brought your pictures over here. Yes, my bolt did the exact same thing. I think that one 87 was more of a PITA then the other. Sorry that I didn't capture that, I did the best that I could. When you are making progress, sometimes you just want to plow through and get it done...
-Brian
[This message has been edited by MulletproofMonk (edited 05-21-2013).]
MulletproofMonk
Total ratings: 78
Report this Post02-29-2012 08:43 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
9587 views. Not too shabby.
MulletproofMonk
Total ratings: 78
Report this Post11-29-2012 10:44 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
IanT720
Report this Post11-30-2012 12:26 AM Click Here to See the Profile for IanT720Send a Private Message to IanT720Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks much! Really helped, I just redid the rear well I was doing the swap... Front will be soon!
bomluuk
Report this Post12-04-2012 12:14 PM Click Here to See the Profile for bomluukSend a Private Message to bomluukEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very nice wite up and good information. Thank you.
Also, just some polish and you could wear 'em with a tux!
-Brian
MulletproofMonk
Total ratings: 78
Report this Post05-14-2013 11:04 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Way back I said I would post some pictures of the tool I made for removing the bushings, I guess 3 years is a long enough wait... Seriously though, I hadn't done any bushings until last week.
Originally posted 06-10-2009 by MulletproofMonk:
At some point I need to post pictures of the bushing removal tool that I made to do my current car. It reduced waiting for the bushings to burn out and it only cost about $25 to make 2 (one for the large bushings and one for the small bushings). Anything that helps reduce inhaling that toxic black smoke is good...
First let me say that Rodney Dickman's Fiero Balljoint Separator Tool is awesome.
So, my bushing removal tool is just a length of pipe with a cap. The diameter should just fits over the bushing. It should be deep enough to hold the bushing that pops out. Lastly I used a lag bolt long enough to go through the pipe plus control arm and have 2 washers with a nut. I tried one washer but it bent everytime. I ended up with one washer the same size as the bushing and then a smaller washer that was thicker and higher grade.
Once you attach the tool, I heat the sleeve evenly with a propane torch. You should hear the bushing start to sizzle (and maybe see some smoke), start turning the nut with a ratchet wrench. If you start torquing it down to where the washer is pulling in at the center but the bushing doesn't move around the edges, more heat on the sleeve. If the bushing isn't ready to be released, you will pull the whole sleeve out...
You can see how the edges of the bushing gets hot and releases. Oh yeah, wear some gloves. It gets hot from the heat transfer.
Just a little residue in there, but much better than my old burn out process.
All 4 bushings from both of the lower control arms. Also a better shot of the lag bolt and washers.
Shoes still kicking!
MulletproofMonk
Total ratings: 78
Report this Post05-21-2013 10:44 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Let's do another update... And talk about more tools.
Organization. K.I.S.S. Keep It Simple Stupid. If you can misplace a bolt or thread the wrong bolt in somewhere, you probably will. While reading other peoples threads in quests of poly (and losing bolt sizes, locations, etc), I thought I would share my simple method. Wood with drilled holes, a couple of nails and a marker.
MulletproofMonk
Total ratings: 78
Report this Post05-21-2013 10:47 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
MulletproofMonk
Member since Oct 2005
I'm sure that there is a toolkit for pressing bushings in... but since the wife calls me her "Asian Hillbilly", here are my tools to press the bushings in. Piece of 2x4 with a hole cut in the center, 6" clamp and another piece of wood. Can you get a cheaper tool?
MulletproofMonk
Total ratings: 78
Report this Post05-21-2013 10:55 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
MulletproofMonk
So you misplace your bolts for the front end?
Upper Control Arm bolts and washers. There are two washer at each end.
Lower Control Arm bolts and washers.
Long Bolt goes in the front
Short Bolt goes in the rear
MulletproofMonk
Total ratings: 78
Report this Post05-23-2013 05:52 AM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
84-87 Torque Specs from Ryan's excellent site: http://www.gmtuners.com/fil...7_Fiero_TQ_Specs.pdf
Originally posted by Raydar:
The 220 ft.lbs. for the hub/bearing bolt into the knuckle is horribly wrong.
I'll have to dig for the correct value. It's more like 62 ft/lbs. (Same as the rears.)
From the 88 Service Manual
[This message has been edited by MulletproofMonk (edited 05-12-2024).]
zmcdonal
Report this Post05-23-2013 09:55 AM Click Here to See the Profile for zmcdonalSend a Private Message to zmcdonalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome! Thanks for posting all the torque specs, very helpful!
MulletproofMonk
Total ratings: 78
Report this Post05-24-2013 10:13 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
FYI 84-87 Front Swaybar has two different ends...
Round goes to the passenger side, Oddball goes to the drivers side.
[This message has been edited by MulletproofMonk (edited 05-29-2013).]
MulletproofMonk
Total ratings: 78
Report this Post05-30-2013 12:07 AM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
So, I keep hearing about the front spring jumping out and biting you or giving you rabies or laying its eggs under your skin or some other pile of hot garbage. This hasn't happened to me (yet). So, I decide that I want to see what all this brouhaha is about. As all good internet videos start out, "Hey Y'All, Watch This!"
http://www.youtube.com/watc...tfY&feature=youtu.be
BTW, the spring is sitting 4 feet from the lower control arm and only stopped because of the rolling mechanic chair I had my phone on. I have seen the light, use something to secure that spring before you pop it loose...
BE SAFE
[This message has been edited by MulletproofMonk (edited 05-30-2013).]
sniper69
Report this Post06-18-2013 07:10 PM Click Here to See the Profile for sniper69Send a Private Message to sniper69Edit/Delete MessageReply w/QuoteDirect Link to This Post
Could the old bushings be pressed out with a hydraulic press?
MulletproofMonk
Total ratings: 78
Report this Post07-16-2013 11:40 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
If I had a press...
So... While I was sitting around pissed off because I tore another steering rack boot getting the control arm bolts out... and I noticed this in the service manual... It shows putting the front bolt in forward so you don't hit the boot. I can only assume that they installed the bolts one way at the factory and changed it in the service manual. I haven't seen one Fiero with the bolts going forward yet. Of course mine do now...
benoitmalenfant
Report this Post08-31-2013 07:47 PM Click Here to See the Profile for benoitmalenfantSend a Private Message to benoitmalenfantEdit/Delete MessageReply w/QuoteDirect Link to This Post
UPDATE link on 5/23/13
Install that =http://hhttps://www.fiero.nl/forum/Forum2/HTML/094633-2.html#p43]Dodgerunner belt tensioner while the control arm is out to give you more room to work.
FYI the above link in this post on page 1 doesn't work, the "http://" part is messed up as you can see in the quote (I removed the URL tag so you could see where the problem is).
Great tutorial btw.
[This message has been edited by benoitmalenfant (edited 08-31-2013).]
Total ratings: 463
Report this Post08-31-2013 11:56 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hell of a writeup. I'm surprised I've never seen it before.
Thanks for taking the time!
[This message has been edited by Raydar (edited 09-02-2013).]
MulletproofMonk
Total ratings: 78
Report this Post09-01-2013 10:44 AM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great tutorial btw.
Fixed and thanks for the compliment. It has been a long process and gets updated if I find something new (or easier) doing another upgrade. Hope to post some pictures of the 88 cradle when I get the time...
benoitmalenfant
Report this Post09-01-2013 01:15 PM Click Here to See the Profile for benoitmalenfantSend a Private Message to benoitmalenfantEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll have to dig for the correct value. It's more like 35-45 ft/lbs. (Same size bolt as the caliper, IIRC.)
Well, according to the 88 SM:
Front Suspension (Page 3C-5)
5. (Tighten) Three bolts attaching hub and bearing assembly. Torque to 260NM (220 lb. ft)
SM might be wrong though.
[This message has been edited by benoitmalenfant (edited 09-01-2013).]
benoitmalenfant
Report this Post09-01-2013 01:49 PM Click Here to See the Profile for benoitmalenfantSend a Private Message to benoitmalenfantEdit/Delete MessageReply w/QuoteDirect Link to This Post
benoitmalenfant
Member since Sep 2011
Front Suspension Torque Specs cheat sheets from the Service Manual (87 and 88):
1987 SM:
1988 SM:
Sorry for the double-post (sort of) but I thought the cheat sheets were a bit more clear than simply the text I posted earlier.
