  Poly Suspension Upgrade (all pics) (Page 4)
Poly Suspension Upgrade (all pics) by MulletproofMonk
Started on: 09-04-2008 09:56 AM
Replies: 153 (24977 views)
Last post by: pmbrunelle on 05-27-2024 05:43 PM
Boostdreamer
Total ratings: 98
Report this Post09-01-2013 09:37 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
To remove rubber bushings without special tools or burning them out, check page 4 of my second link.
Jonathan
My '85 L67 Build Thread
Total ratings: 463
Report this Post09-02-2013 06:26 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by benoitmalenfant:
SM might be wrong though.
It's been discussed before. The manual is wrong.
The rear hubs (similar design and bolt size) I see are 62 lb.ft. I think that's what was decided on for the fronts.
(For comparison, my Trailblazer uses similar, although obviously larger hub/bearing assemblies. It specs at 77 lb. ft.)
You can try to tighten the fronts to 220 if you want, but I think they'll break long before that.
benoitmalenfant
Report this Post09-02-2013 08:10 PM Click Here to See the Profile for benoitmalenfantSend a Private Message to benoitmalenfantEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, another thing I just noticed. The conversion from NM to Lb/Ft is wrong as well:
260nm (Newton Meter) = roughly 191 lb/ft (not 220 lb/ft)
obviously someone read AND converted wrong back in 87 :
Ben
87 GT / 88 GT
84 Indy #1863
benoitmalenfant
Report this Post09-02-2013 08:27 PM Click Here to See the Profile for benoitmalenfantSend a Private Message to benoitmalenfantEdit/Delete MessageReply w/QuoteDirect Link to This Post
benoitmalenfant
Member since Sep 2011
I just tried "untorquing" one of mine with my torque wrench (I know, I'm not supposed to do that, but I did it for the cause ) and at around 70 it started unscrewing.
So I guess 62ish is the right amount
Total ratings: 463
Report this Post09-02-2013 11:11 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry. Hope I didn't come off sounding like an azz.
I just remember seeing this before. Thinking that they got the measurement confused with the one for the rear axle nut.
THAT one is ~200 lb.ft.
benoitmalenfant
Report this Post09-03-2013 09:26 PM Click Here to See the Profile for benoitmalenfantSend a Private Message to benoitmalenfantEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not at all buddy, we're just discussing, it's all good and I think it's good someone points out the mistake in the book, will save the next guy from breaking a bolt while putting it back together!
A member of my local club thought they might have taken the measurement off a front wheel-drive assembly (cardan) where it would need to be torqued at around 200lb/ft.
Anyhow, 60-70 is what makes sense.
[This message has been edited by benoitmalenfant (edited 09-03-2013).]
PerKr
Report this Post03-08-2014 04:48 PM Click Here to See the Profile for PerKrClick Here to visit PerKr's HomePageSend a Private Message to PerKrEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm putting my front end back together and didn't note which bolt went where. Having put it back together it didn't look right, I had the long bolt at the rear and the short at the front. So corrected that, long bolt up front, short in the rear. Still doesn't look right. I'm slightly puzzled.
I like to use washers at both ends to help avoid scratching any protective coating when tightening. Plus the zinc coated washers act as sacrificial anodes just in case. Anyway, with the long bolt up front, there's quite a bit of the bolt sticking out past the nut. Plus its tip is pointy just like the short one shown previously in this thread. I'm not very fond of having that pointy end as close to the rubber boot on the steering rack as it currently is. I could probably come up with a way of putting a plastic or rubber cap on it but still...
For the short bolt I feel it is a bit short. It's short enough that I chose not to have a washer at the bolt head but only at the nut just to make sure that all the threads would engage. Also, this bolt looks more like the long bolt shown previously. This wouldn't be much of a problem if I could find washers half as thick as the ones I have now (which are about 2.5mm, or 0.097-0.1 inch) but as it is I'm not really digging it.
any thoughts?
*edit: just measured the rear bolt (front is a bit harder to get to once it's in place) and it's about 3.4 inch. Did the length vary over the years? I wouldn't find it hard to believe that the bolts were installed without washers from the factory so the rear bolt was just long enough and the front bolt was installed the other way around so the length really didn't matter when building the car.
[This message has been edited by PerKr (edited 03-08-2014).]
MulletproofMonk
Total ratings: 78
Report this Post03-30-2014 11:54 AM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by PerKr:
any thoughts?
Just saw your post. I don't think that the bolts varied by years. You could always buy new bolts to replace them if you are careful enough to get the right grade bolt.
84-87 LOWER CONTROL ARM BOLTS & NUTS
darbysan
Report this Post07-13-2015 01:11 PM Click Here to See the Profile for darbysanSend a Private Message to darbysanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great Write-up. Doing mine now, and this is very handy.
A couple of comments: I buy the SuperLube in tubes for extra lubrication. Look for PTFE. I bought a second grease gun just for this grease ( use it for my 4-link arms in my other car).
The Front LOWER A-arm bolt was giving me fits as well, hitting the rubber sleeve on the steering rack. I finally thought " what happens if I turn the steering wheel all the way to the right ( for the driver's side bolt)", and YES, it worked. Moved the boot totally out of the way. Don't know yet if the same trick is going to work for the passenger side or not.
Edit: yes, moving the steering to the other side gave me room on the passenger side, enough room to even use an impact wrench!
For getting the bushings out, I use a 1/8" drill bit. I drill down into the rubber next to the inner bushing, and then try and rotate the drill around the bushing while it is running. Usually it will "walk" it's way around the inner bushing and pull it right out. Once the inner is out, do the same thing around the outer edge of the bushing. I might use a slightly larger drill bit size here. I did 4 yesterday, and 3.5 came out OK. One of the bushings was really "stuck" to the housing, so I had to use more extreme measures to get that one completely out.
Edit: after I read this thread a second time, I saw that someone else had also posted this idea. Sorry for repeating something that was already available.
'87 GT in process, including GA / Seville brakes, Poly Suspension, '95 3800 Series 1 SC ( 225 hp ) T460e.
[This message has been edited by darbysan (edited 07-13-2015).]
MulletproofMonk
Total ratings: 78
Report this Post11-10-2015 02:46 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just ordered more grease from Summit.
I got stupid and bought the big tube since I was doing way too many poly installs... My intent was to install zerg fittings, but never did.
http://www.summitracing.com/parts/ptp-19-1751
But you can get a couple of the small tubes.
http://www.summitracing.com/parts/ptp-19-1750
cebix
Report this Post09-21-2016 03:39 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Resurrecting this old thread with some questions.
How does the installation hold up? Any wear on the poly?
I'm also replacing all my ball joints and tie rod ends with Rodney's. Is it wiser to just leave them as the came or to put those poly boots over the rubber ones too? Will the poly rub on the rubber boot?
MulletproofMonk
Total ratings: 78
Report this Post09-23-2016 10:57 AM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
The poly has held up well for me, 2 years on the car. I didn't really corner hard in the car though. My buddy Matt corners hard in the LeMon/ChumpCar and it needed replaced within a year I think.
Use the rubber boots that came with the ball joints, they seal better. You can put the poly over top if you want, but it might compress the boot...
-Brian
Removing the roof panel
My HUD install thread
Modified stock air canister and base to 3.5 inch for 3800na
cebix
Report this Post09-23-2016 05:51 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the reply!
I'm doing it on a daily driver. Did the whole front today, going to do the rear in a few days. Drives pretty hard after installing the poly bushings but it's good! Very, very tight. Only used the rubber caps, threw away all the poly ones.
RPYRAZOO
Report this Post09-24-2016 08:33 PM Click Here to See the Profile for RPYRAZOOClick Here to visit RPYRAZOO's HomePageSend a Private Message to RPYRAZOOEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm told by my mechanic that I should replace most of the front suspension. If I have poly installed with the new parts would it have a negative effect with the non-poly rear end suspension parts. Not quite sure which way to go with this, any advice appreciated.
Thanks,
Rich
Jason88Notchie
Report this Post09-25-2016 12:20 AM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks,
Rich
My opinion is don't use poly at all. Just adds noise and creaks with no added performance benefits.
RPYRAZOO
Report this Post09-30-2016 07:29 PM Click Here to See the Profile for RPYRAZOOClick Here to visit RPYRAZOO's HomePageSend a Private Message to RPYRAZOOEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jason: What about all the positive aspects I hear about.. tighter, better cornering etc. that OEM bushings don't seem to offer. I'm still trying to decide which ones to have installed.
By the way, thanks for the input.
Rich
cebix
Report this Post10-01-2016 06:36 AM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh the car is very tight, feels like a modern suspension to me now at least in the city/hway daily driver way. Not doing any racing though.
Report this Post10-02-2016 08:40 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have poly bushings in most places on my car as well. I have noticed a harsher ride but with more road control. Friends that have used these bushing have told me that they wear much faster than the rubber. Good for a show/hobby car but probably not the best for a regular street driven car.
pmbrunelle
Total ratings: 63
Report this Post05-12-2024 12:13 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I'm installing Prothane polyurethane bushings in the rear of my 85 Fiero, and there is a gap between the shoulder of the bushings and the control arm:
The control arm is able to slide (with a prybar) back and forth on the polyurethane bushings.
What is going on here?
I was thinking of making washer-like spacers to fill the gaps and hence keep the control arm from moving back and forth. Opinions?
In these two photos, it looks like there is also a gap between the bushing and the control arm:
Originally posted by MulletproofMonk:
Originally posted by randye:
jelly2m8
Total ratings: 242
Report this Post05-12-2024 01:45 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'd say that control arm may be bent.
Spadesluck
Report this Post05-12-2024 01:56 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
pmbrunelle, that's a big gap. Does the other side look like that? Maybe measure both control arms and make a comparison?
pmbrunelle
Total ratings: 63
Report this Post05-12-2024 01:56 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hmmm. The situation is exactly the same on the opposite side.
I have a spare cradle + control arms; I guess I can compare measurements with my spare parts.
jelly2m8
Total ratings: 242
Report this Post05-12-2024 02:41 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
that does make one wonder if it's the same on both sides....
I've put my fair share of poly in these things over the years, i found is normal to have the excess on the non shoulder side ( I know you know what I mean ) but I have never seen the excess as yours are.
[This message has been edited by jelly2m8 (edited 05-12-2024).]
Report this Post05-12-2024 08:39 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Perhaps the end of the control arm was squished when removing the old bushings?
MulletproofMonk
Total ratings: 78
Report this Post05-12-2024 08:44 AM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow, 16 years and people are still using this. Makes a guy proud.
Like everyone said, the control arm should have been a snug fit getting it back in the cradle. I have always had to wiggle it back and forth to get it in, and by wiggle I mean MM's of movement. If you can just pull your control arm out of the cradle without doing that, it is bent.
Just went in the garage and the control arms fit tight to the outsides, but couldn't get very good pictures because it is dirty and under the car. I have a spare cradle and some controls arms that I can get better pictures of later.
[This message has been edited by MulletproofMonk (edited 05-12-2024).]
MulletproofMonk
Total ratings: 78
Report this Post05-12-2024 10:12 AM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
MulletproofMonk
Member since Oct 2005
Got pics but it says that PIP isn't there to download. Anyone else have that issue?
-Brian
pmbrunelle
Total ratings: 63
Report this Post05-12-2024 04:37 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, I know what you mean
Originally, I used a propane torch to heat the bushing shells and eject the rubber, so no major pressing forces involved.
Now you don't need PIP anymore.
If you are logged into the forum, you can use the "Upload Media" button:
I measured some control arms like so:
Spare cradle:
RH 13-3/16"
LH 13-1/4"
My Fiero:
RH 13-1/16"
LH 13-1/16"
The pivot points of my Fiero's control arms are spaced closer together than those of my spare cradle assembly.
Maybe these were just normal production variances?
Nothing looks wrong with my Fiero's control arms, so I think I'll just use them with spacers. I ordered some Delrin plastic sheet in order to make some spacers.
The gaps were large enough that even if I used the spare control arms, there would still be gaps that I would want to fill with (thinner) spacers.
Report this Post05-12-2024 04:56 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...you don't need PIP anymore. If you are logged into the forum, you can use the "Upload Media" button:
I don't know how many times that's fooled me. I type out a post, and then go to add some images using the "Upload Media" tab... and nothing happens. No uploaded image, no error message, no nothing. Yes, I understand what the issue is... but it's enough to totally bamboozle anyone who's unfamiliar with the forum.
MulletproofMonk
Total ratings: 78
Report this Post05-12-2024 08:15 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
So this first picture I put my bushing presser on and pushed the busing all the way in
here is the front rear bushing
here is the CA and you can see it doesn't fit, so I had to shift that bushing back out a little to where it was and then it went in with a gently tap from a rubber mallet
Once it is in, you can see that rear bushing had to move a little. I would assume this CA is tweaked a little bit.
-Brian
MulletproofMonk
Total ratings: 78
Report this Post05-12-2024 08:19 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
MulletproofMonk
thanks pmbrunelle and Patrick for the uploading image fix. guess I haven't had to post a pic in years...
pmbrunelle
Total ratings: 63
Report this Post05-13-2024 06:53 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
The movement doesn't only happen once during installation.
I took my Fiero for a quick spin (with the gaps), and when I returned from my ride, the control arms shifted relative to the bushings.
Report this Post05-13-2024 09:17 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
It looks like the ends of the control arms have been distorted (squished).
Spread them back out and they should be fine.
Yellow-88
Report this Post05-27-2024 12:18 PM Click Here to See the Profile for Yellow-88Send a Private Message to Yellow-88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi
You should be aware that with stiffer bushings, factory alignment specs will be "uncomfortable". The setting that you really "feel" is "toe". The factory settings allow for the fact that "rolling forces" tend to push the wheels to "toe out". With factory bushings, toe is set to "toe in". With stiffer bushings that will feel overly sensitive or "hooky" as my wife calls it. I always recommend zero toe, zero camber, and "factory" positive caster as a starting point.
Yellow-88
pmbrunelle
Total ratings: 63
Report this Post05-27-2024 05:43 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
My control arms didn't appear damaged, so I just went with Delrin spacers.
-----for information, suggested spacer dimensions-----
Inside diameter: 1.63"
Outside diameter: 2.16"
