  IMSA widebody recycle (Page 2)
IMSA widebody recycle by ccfiero350
Started on: 02-01-2009 10:49 PM
Replies: 53 (4629 views)
Last post by: exoticse on 10-04-2016 04:24 AM
ccfiero350
Report this Post02-22-2011 09:22 AM Click Here to See the Profile for ccfiero350Send a Private Message to ccfiero350Edit/Delete MessageReply w/QuoteDirect Link to This Post
The hardest part of making the sideburns is matching the left side to the right side.
Again I got the base blend first and added a skim coat of filler, then added the foam blob to start the lower rocker detail.
The shaping went pretty good, did not have to re-foam anything.
After much sanding and filling I think they are ready for glassing. I've been trying to decide to make a splash mold now or after I get it glassed and smooth again.
yellow 88 GT, not stock
white 88 notchie, 4 banger
ccfiero350
Report this Post03-20-2011 07:41 PM Click Here to See the Profile for ccfiero350Send a Private Message to ccfiero350Edit/Delete MessageReply w/QuoteDirect Link to This Post
While I have been putting a layer on the sideburns I started in on fixing the many cracks from the shipping damage on the front clip.
One of the largest damaged area is the pivot bar area. There were 2, 6 inch rips where the nose took a hit. After grinding away at glass to prep it for repair found it was really thin in a place were high stress occurs at the hinge. it looks to be about 1/8 of glass and then the polyester bulker, then a thin mat or chop spray on top. Added about 1/4" of mat to the effected ripped areas.
I still have to do the outside cracks.
I will be building up the front fenders with foam to make IMSA style fenders, in preperation I sanded the 3/8 to 1/4 thick bondo off the fenders untill I found fiberglass. It looks like they uses a thin wood strip to form the wheel arch.
More to come.
BlackEmrald
Report this Post03-20-2011 11:41 PM Click Here to See the Profile for BlackEmraldSend a Private Message to BlackEmraldEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very cool! Props from a fellow Houstonian!
BlackEmrald
Report this Post03-21-2011 06:30 AM Click Here to See the Profile for BlackEmraldSend a Private Message to BlackEmraldEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by BlackEmrald (edited 03-21-2011).]
ccfiero350
Report this Post04-03-2011 10:32 AM Click Here to See the Profile for ccfiero350Send a Private Message to ccfiero350Edit/Delete MessageReply w/QuoteDirect Link to This Post
Work continues on repairing the cracks.
Digging out the delaminated glass with a rotary tool from the back side.
Around the light bezels.
The last big one on the nose, about 7 inches long.
I need a little more arch in the front wheel well.
I also need some more width to cover the front tires.
At this point the front track is wider then the stock fiero by about 6 inches. I need to finish up the sideburns and get them installed before start on the fender flares.
exoticse
Total ratings: 108
Report this Post07-04-2011 03:04 AM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
CC check your PM.
madcurl
Total ratings: 314
Report this Post04-08-2012 02:01 AM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
exoticse
Total ratings: 108
Report this Post01-09-2014 04:29 AM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
any of you texas guys know ccfiero ??
revin
Total ratings: 234
Report this Post01-09-2014 09:06 AM Click Here to See the Profile for revinSend a Private Message to revinEdit/Delete MessageReply w/QuoteDirect Link to This Post
yep
Us TEXAS IMSA guys stick together.
exoticse
Total ratings: 108
Report this Post01-09-2014 04:29 PM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
revin any update on this project ?? new pics ??
ccfiero350
Report this Post01-09-2014 05:58 PM Click Here to See the Profile for ccfiero350Send a Private Message to ccfiero350Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nothing new yet to post other then its not dead, just paused while I recovered from spinal surgery. As any fiero fanatic knows you spend a lot of time bent over working on these things.
While it's still cool here I'm itching to finish on the foam and glass work.
BV MotorSports
Total ratings: 189
Report this Post01-09-2014 07:43 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Literally!
revin
Total ratings: 234
Report this Post01-09-2014 07:49 PM Click Here to See the Profile for revinSend a Private Message to revinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well there it is from him!
Hard to keep a Texan down!
exoticse
Total ratings: 108
Report this Post10-04-2016 04:24 AM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any update ?
