  low dollar 3800 turbo project (Page 10)
This topic is 13 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13
low dollar 3800 turbo project by darkhorizon
Started on: 09-17-2009 09:43 PM
Replies: 507 (39260 views)
Last post by: Will on 07-01-2019 08:40 AM
Total ratings: 237
Report this Post04-02-2013 10:26 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Justinbart:
The clutch disk doesn't appear to have worn much. As for the flywheel and pressure plate.... I need to get a feeler gauge in there.
I measured .022" for the flyweel wear and .035" for the pressure plate. The pressure plate mostly tapers down towards the outside. Yeah, this clutch is a little harsh.
Did you check your new pressure plate for flatness?
My Centerforce clutches both showed up that much out of flat NIB. I called and asked and was told they do that deliberately so that thermal expansion causes it to flatten out when it's being abused and getting hot.
Jncomutt
Total ratings: 221
Report this Post04-02-2013 10:35 PM Click Here to See the Profile for JncomuttSend a Private Message to JncomuttEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those bolts should be 5/16"
Justinbart
Total ratings: 119
Report this Post04-02-2013 10:45 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Will:
Are those 8mm bolts or 10mm bolts?
If they're 8's, what's the part number?
Thanks!
The flywheel bolts?
ARP Bulk Hardware(ea)-5/16-18-1.000 bolt
SKU: ARP-3AG10005CL
They were a bit too long. I had 1" bolts before but also used a lock washer and it worked. I used a hack saw to take about 1/8" off without getting it hot. Next size down is 0.750"
Turbo 3800 E85 F23 5spd spec5
11.17@132.6
Justinbart
Total ratings: 119
Report this Post04-02-2013 10:51 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Justinbart
Member since Sep 2009
No, didn't even think about it.
Jncomutt, did your super clamp pressure plate also look like that?
11.17@132.6
Jncomutt
Total ratings: 221
Report this Post04-03-2013 09:12 AM Click Here to See the Profile for JncomuttSend a Private Message to JncomuttEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll check tonight.
Total ratings: 237
Report this Post04-03-2013 09:59 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
The flywheel bolts?
SKU: ARP-3AG10005CL
Oh yeah, I remember going around that mulberry bush now...
Crazy GM using engrish bolts on a metric-era engine.
I'd like to get specific flywheel bolts for the Northstar. I've been using class 12.9 hex heads with the stock TTY procedure. I've been thinking about drilling out the holes in my new crankshaft so I can have reusable 10mm (or 3/8) bolts.
It's been a few years since I talked to ARP about 8mm flywheel bolts... maybe they have something now.
Jncomutt
Total ratings: 221
Report this Post04-03-2013 06:26 PM Click Here to See the Profile for JncomuttSend a Private Message to JncomuttEdit/Delete MessageReply w/QuoteDirect Link to This Post
Justin, it appears my pressure plate is the same.
Will, I too would love to drill out this damn crank and go to a larger bolt. The ecotec guys have a 10mm x 1.0 flywheel bolt and they can get away using the ARP bolts for a modular ford 4.6 or 5.4, yet here we are with this high torque 3800 and tiny 5/16".
ericjon262
Total ratings: 67
Report this Post04-03-2013 06:34 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
Even my 3500 uses 10mm bolts... ? WTF GM?
[This message has been edited by ericjon262 (edited 04-03-2013).]
Justinbart
Total ratings: 119
Report this Post04-03-2013 06:48 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
This clutch is much more like an on/off switch that the last one. Hopefully I'll get used to it.
Stalled it twice tonight!
11.17@132.6
[This message has been edited by Justinbart (edited 04-03-2013).]
Jncomutt
Total ratings: 221
Report this Post04-05-2013 08:38 AM Click Here to See the Profile for JncomuttSend a Private Message to JncomuttEdit/Delete MessageReply w/QuoteDirect Link to This Post
Autoplicity wants $45 to ship 10 of those ARP bolts, wtf are they smoking?
Justinbart
Total ratings: 119
Report this Post04-05-2013 10:39 AM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, Something is screwed up there. Either live chat or email them.
11.17@132.6
Total ratings: 237
Report this Post04-08-2013 09:50 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do sintered iron clutches break in the way ceramics and kevlar units do?
Justinbart
Total ratings: 119
Report this Post05-02-2013 07:54 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I put a new F23 in. Details in the "F23" thread.
I have about 650 miles on the new clutch now. It squeals like a pig whenever I'm letting the clutch out. It's much more difficult to drive now. I stall often or it will catch me off guard and my car will buck like a bull. With the super clamp pressure plate it's much more like an on off switch. It has never slipped on full power where's the last one would slip unless everything was hot. Even then sometimes it wouldn't hold.
Just put on a new set of nt555r drag radials on the rear.
A month or so ago I put all new poly bushings in the 88 cradle.
I really liked how the front engine mount on "Formula's" car turned out so I added a mount to mine. Hopefully this and the bushings will help with the wheel hop.
11.17@132.6
[This message has been edited by Justinbart (edited 05-02-2013).]
Fierofreak00
Total ratings: 170
Report this Post05-02-2013 10:14 PM Click Here to See the Profile for Fierofreak00Send a Private Message to Fierofreak00Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had that squealing problem with the Spec stage 3 I used when I first put my 3800 in. I didn't have that problem initially, it just started one day and wouldn't go away and the clutch started acting like an on off switch. I couldn't slip the clutch for nothing when trying to take off from a dead stop, it just grabbed. I replaced all the hydraulics and it still didn't get any better. I finally ended up just swapping it out for a 3+ with the full face disc and that solved the problem. I wanted people to admire my car because it is unique not because it was making some gawd awful noise. -Jason
Justinbart
Total ratings: 119
Report this Post05-02-2013 10:44 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup, the squealing gets everyone's attention. It's a real head turner Buuutt, I would rather have that then it not hold the power.
11.17@132.6
darkhorizon
Total ratings: 451
Report this Post05-02-2013 11:09 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
My opinion is that clutch never breaks in...
ericjon262
Total ratings: 67
Report this Post05-02-2013 11:20 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
I want to add a mount like that to my 3500 swap, but there's nowhere to put it if I keep A/C (I'm keeping A/C!).
Built not bought... Because bolt-ons don't.
Justinbart
Total ratings: 119
Report this Post05-04-2013 01:10 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ran an evo last night. It was a pretty entertaining 3 hour conversation leading up to the race. I don't think they had any idea.
I really need to start mounting my phone facing the rear or get a gopro.
11.17@132.6
[This message has been edited by Justinbart (edited 05-04-2013).]
BV MotorSports
Total ratings: 189
Report this Post05-04-2013 05:01 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Never saw it coming! Nice!
darkhorizon
Total ratings: 451
Report this Post05-04-2013 05:04 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
They were SO mad when they lost it was funny.
Justinbart
Total ratings: 119
Report this Post06-09-2013 12:40 AM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Went to a BIG car meet/ bbq. Won a car limbo contest and got a case of Eneos full syn oil.
We figured there was at least 1250 lbs of people in and on my car.
11.17@132.6
[This message has been edited by Justinbart (edited 06-09-2013).]
NoMoreRicers
Report this Post06-09-2013 06:19 AM Click Here to See the Profile for NoMoreRicersSend a Private Message to NoMoreRicersEdit/Delete MessageReply w/QuoteDirect Link to This Post
I dig the license plate.
Between the license plate and the intercooler piping sticking down, it's probably difficult to remain a sleeper, yeah?
[This message has been edited by NoMoreRicers (edited 06-09-2013).]
darkhorizon
Total ratings: 451
Report this Post06-09-2013 10:47 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
[img]https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-prn2/964784_510662752316204_1069675712_o.jpg[/img]
Justinbart
Total ratings: 119
Report this Post06-10-2013 03:43 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did some autox'ing yesterday. Got to play with my new gopro. Very short course. (35 second)
Poor drag radials
11.17@132.6
Justinbart
Total ratings: 119
Report this Post06-10-2013 06:36 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Justinbart
Something interesting that I just thought of. I've had my car a little over 130 a few times and my head lights don't pop up anymore. I still have the snow dam I made for ice racing in. My car still has no problem keeping cool even on days in the mid 80's. The only air getting in is from the two small holes in the GT bumper. I may have to make something a little more permanent out of aluminum.
11.17@132.6
[This message has been edited by Justinbart (edited 06-10-2013).]
Total ratings: 237
Report this Post06-11-2013 03:40 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by darkhorizon:
Fixed.
Justinbart
Total ratings: 119
Report this Post08-18-2013 02:29 AM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am very impressed with how the F23 is doing. I turned my boost up to ~24psi and have been driving my car very hard for the past 3 weeks.
Ran a fast GTR tonight. Launched at full boost from 40 mph in 2nd. Crazy.
11.17@132.6
NoMoreRicers
Report this Post08-18-2013 02:52 AM Click Here to See the Profile for NoMoreRicersSend a Private Message to NoMoreRicersEdit/Delete MessageReply w/QuoteDirect Link to This Post
You think that's enough to run a 10?
Are you still running the Felpro head gasket or did you put on the MLS yet?
steve308
Total ratings: 59
Report this Post08-18-2013 11:04 AM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Always a good idea to post online RACING on a public street and then show a close up of your plates a couple of post later! Might want to rethink - just sayin.
Jims88
Report this Post08-18-2013 05:54 PM Click Here to See the Profile for Jims88Send a Private Message to Jims88Edit/Delete MessageReply w/QuoteDirect Link to This Post
After watching that video I had to google a GTR.
Thats what you get for $78,000 used and $100,000 new.
Justinbart
Total ratings: 119
Report this Post08-18-2013 07:27 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
This was in Mexico so it's cool.
11.17@132.6
Formula
Total ratings: 96
Report this Post08-18-2013 07:47 PM Click Here to See the Profile for FormulaSend a Private Message to FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
As a person who has been to Mexico, I can confirm that this is in fact a video from Mexico.
nitroheadz28
Total ratings: 94
Report this Post08-18-2013 08:01 PM Click Here to See the Profile for nitroheadz28Send a Private Message to nitroheadz28Edit/Delete MessageReply w/QuoteDirect Link to This Post
This can be confirmed by the fact that only a Mexican GTR could lose to a Fiero.
Justinbart
Total ratings: 119
Report this Post08-18-2013 11:03 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did an autocross today. Fun stuff.
11.17@132.6
sco77
Report this Post08-19-2013 12:33 AM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
This thread makes me want to build another 3800 Fiero with a turbo.
86 Fiero GT 4spd - L67 swap: VS cam, GenV. Needs exhaust (ETA 9/13) Build Progress
98 GTP - Some mods
steve308
Total ratings: 59
Report this Post08-19-2013 05:29 AM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
I thought I recognized the Baldwin Road exit sign that leads to the Moon Palace resort in Cancun. What ever you do, don't use the water in the radiator - it will just explode out of the bottom of the radiator in about an hour
AL87
Report this Post08-19-2013 11:37 AM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
I dont need your backpedaling in my threads loyde, I hope you check out for good on this thread as I know you have nothing positive to offer.
My buddy did some work while I was at the track today playing with supras... Not sure how much I like the IC being so close to the turbo myself.
Wait... Is that a turbo, and a supercharger I see? I haven't seen a setup like that since lancia.
Justinbart
Total ratings: 119
Report this Post08-19-2013 12:09 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
no
11.17@132.6
nitroheadz28
Total ratings: 94
Report this Post08-19-2013 02:49 PM Click Here to See the Profile for nitroheadz28Send a Private Message to nitroheadz28Edit/Delete MessageReply w/QuoteDirect Link to This Post
You've been here how long and always post the dumbest questions imaginable that could be answered in less than a minute if you took the time to search.
But of course he's twincharged and like you goes around revving his 3800 to 7500rpm while racing civics while getting huge downforce from his scrap steel attached "drag wing".
Justinbart
Total ratings: 119
Report this Post09-05-2013 08:43 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got some new wheels today
Enkei RPF1 17x8 45mm (35mm when you add the grand am brake rotor upgrade) on the front. 17x9 45mm on the back.
I love them so far. I switched over the 245/45R17 nt555r drag radial from my 7" rim and now it's a bit stretched. I'm going to get a 275/40R17 NT05R drag radial next summer when these are toast.
I got a new pair of 235/45R17 Potenza Re-11A that went on the fronts. When I autocross i'm going to put on my old pair of wheels that has the 225/45R17 Re-11A on so i'll have 4 good autox tires. The drag radials weren't cutting it. This was the main reason for getting new set of wheels. They are also 10lbs lighter per wheel weighing in at 16lbs!. Eventually I would like to get another pair of 17x8's for when I autox or don't need the drag radials on the rear.
11.17@132.6
[This message has been edited by Justinbart (edited 09-05-2013).]
