  low dollar 3800 turbo project (Page 6)
This topic is 13 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13
low dollar 3800 turbo project by darkhorizon
Started on: 09-17-2009 09:43 PM
Replies: 507 (39674 views)
Last post by: Will on 07-01-2019 08:40 AM
Justinbart
Total ratings: 119
Report this Post08-18-2011 01:53 AM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fixed the trans -> https://www.fiero.nl/forum/Forum2/HTML/117920.html
Cleaned the clutch up good and its holding anything I can throw at it. I'm kinda glad it broke, it forced me to fix the contamination.
I was able to get a PBOX 60-130 reading tonight. Did two runs at 7.7s and one at 7.6s. At night ~71*F
I have more motivation now to get to the drag strip now that my clutch is working. Hopefully in a month or so. Going to shoot for 10's or bust!
Turbo 3800 E85 5spd spec5
11.53@126.7
Justinbart
Total ratings: 119
Report this Post08-23-2011 02:50 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://www.fiero.nl/forum/Forum1/HTML/086699.html
Some picture I found that were interesting.
11.53@126.7
Justinbart
Total ratings: 119
Report this Post11-19-2011 10:43 AM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heading to Lapeer dragway today. Wish me luck. Its 45*F and cloudy, might get a little sloppy out there.
My goal is 10.9@134 (...might be a stretch,lol)
11.53@126.7
nosrac
Total ratings: 50
Report this Post11-19-2011 02:28 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good luck, and don't break anything besides your PB.
Justinbart
Total ratings: 119
Report this Post11-19-2011 07:32 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Warning - excuses follow!
Well... I didn't do as good as I hoped. The first run was basically a shake down run. I took it easy in 1st and 2nd, hit it hard in 3rd and it slipped in 4th. Sometimes the clutch needs to get a little warm for it to hold. I hot lapped it, went right back to the staging lanes. I did a nice easy launch in 1st, easy shift into 2nd gradually pushing the gas pedal down to max, then full out in 3rd and 4th. Ran 11.54@132.68. I was pretty pumped about running that good.
I waited around and talked to some people. I wanted to wait to launch it till the end of the day in case I put oil down on the track from an explode trans. After a few hours I went back out there and tried to cut a better 60'. I made way too much boost in first spun and wheel hoped. Shifted into 2nd early. spun for a hundred feet hit 3rd and 4th, let off a bit short on the line. Went 11.77@129.33. I was racing a grand national so I might have been a little amped, haha.
Went right back around to the starting line again, so did the GN. Tried to be a little easier in 1st. I made way too much boost again and wheel hopped even worse. Broke the passenger side axle inside the tripot on the trans side. Haven't pulled it out yet, the boot clamp flung off and pulled back some. I think it broke where the axle shaft meets the 3 roller bearing things. I should have taken a picture of first 60' of track. It's really bumpy. I could see my tracks from the run before it was like 2' squares of tread lines. Lapeer isn't the best track around but it was the only one open this time of year.
Scott followed me to the track with the trailer and I really didn't have any intention on driving it home, unless I met my goal. I wish I had a little more self control to let out when it was hopping at the start. Overall It was a good time. I am happy to get my 130+mph trap. I always figured It would do it but I hate throwing around numbers without proof. I really think there is a 10 second slip in there if I can get a good smooth launch. Especially if you compare the 1/8 miles of my old slip!
I ran the car the same way as I drive on the street, right down to the tire pressure, except I removed my air filter. (if that makes sense)
There should be some in car video and some from the stands coming.
11.53@126.7
[This message has been edited by Justinbart (edited 11-20-2011).]
MstangsBware
Total ratings: 459
Report this Post11-19-2011 09:21 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
NICE.....................Atleast it was just an axle..Guessing the same axles you have been running all this time...
Justinbart
Total ratings: 119
Report this Post11-19-2011 09:36 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, this is my first broken axle.
I wanted to try a run starting in 2nd gear.
ugg, should have let off....
11.54@132.7
MstangsBware
Total ratings: 459
Report this Post11-19-2011 09:48 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sucks to being the tracks up there will be closing soon.....
nosrac
Total ratings: 50
Report this Post11-19-2011 10:15 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
How are you making too much boost? Wastegate + Boost controler not doing its job properly? Do you just randomly overboost or can you do it at will? I need to know these thinks so when I go turbo this spring I can learn from your mistakes and beat you to the 10's.
Lets see that Video. You did beat the GNX right?
Justinbart
Total ratings: 119
Report this Post11-19-2011 10:28 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
what I mean is...I was trying to ease the power on the launch. I kept spooling too fast, making too much power, overcoming tire traction. Some kind of progressive boost controller would take the guess work out. I just love all the people that think you wont make any power out of the hole with a turbo
I wish I would have got another run so I could try to launch in 2nd. I would think the boost would come in a little slower and smoother, not as violent.
[This message has been edited by Justinbart (edited 11-19-2011).]
nosrac
Total ratings: 50
Report this Post11-19-2011 11:03 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tune out the power and get some larger diameter wheels. Don't you have a DHP powrtuner?
nosrac
Total ratings: 50
Report this Post11-19-2011 11:06 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
nosrac
Member since Jan 2005
So what does the bust mean since you didn't run in the 10's? You going Auto?
Justinbart
Total ratings: 119
Report this Post11-19-2011 11:10 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
It means i'm not driving the car home until I get a 10.
11.54@132.7
darkhorizon
Total ratings: 451
Report this Post11-20-2011 09:51 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
The sad thing is we have an adjustable spool controller on this.... we could probably try adjusting the VGT actuation to react slower at low engine loads...
I have videos all over, ill work on getting them uploaded here eventually.
Was pretty funny pulling onto the track with the trailer ready to go within 2 minutes of the axle going.
Justinbart
Total ratings: 119
Report this Post11-20-2011 10:55 AM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I never even thought of that. I should have just disconnected the actuator and left the vgt rack wide open. I have some things to think about for the next time we go to the track.
11.54@132.7
nosrac
Total ratings: 50
Report this Post11-20-2011 01:38 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm going with a dual stage boost controler along with some fine tuning. Low boost off the line and high boost once I get going.
2002z28ssconv
Total ratings: 51
Report this Post11-20-2011 08:04 PM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like fun! At least you spanked the GN on the previous run.
So has anybody made it to the tens yet? Is there still a 1/4 mile time thread? The only one I found seemed to be pretty old.
LFiero67
Report this Post11-20-2011 08:53 PM Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Current 1/4 mile list:
https://www.fiero.nl/forum/Forum1/HTML/070670.html
The real question is who will be first to 9's, next year should be interesting.
11.425 @115.60
Best 60' 1.543 seconds
3800 S/C 4T65E
New combo : Billet 6262 Precision turbo, PT1001 intercooler, ST1 cam, 130lb springs, comp pushrods, HV3, otherwise stock L36.
nosrac
Total ratings: 50
Report this Post11-20-2011 11:31 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure if I really want to go that fast....Well maybe but not if I will be breaking stuff... LOL
I plan on being in the mid 10's... I hope. Taking notes and doing my homework now.
I am coping what works, and adding in what I learned.
nosrac
Total ratings: 50
Report this Post11-20-2011 11:34 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
nosrac
Any pics of your setup?
LFiero67
Report this Post11-21-2011 12:40 AM Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Right now it looks like a turbo on a bench, a engine on an engine stand, and a transmission with a broken 4340 input shaft sittIng on the floor, all in front of my car in the garage. I could take pics, but it wouldn't be that interesting I don't think.
11.425 @115.60
3800 S/C 4T65E
nosrac
Total ratings: 50
Report this Post11-21-2011 02:39 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just wanted to see how you mounted your IC.
LFiero67
Report this Post11-21-2011 06:17 PM Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Probably changing the mounting method, but it basically sits sideways just beneath where the flat of the upper trunk is. Inlet and outlet point to drivers side, aluminum cast 90 from turbo into Intercooler top inlet, aluminum tubing leaves the bottom outlet of Intercooler, with bov mounted there, then up and through rear firewall, and into MAF, then into northstar TB.
11.425 @115.60
3800 S/C 4T65E
Justinbart
Total ratings: 119
Report this Post11-21-2011 09:17 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I swapped out axles today. I was wrong about which side. The drivers side hub end was what broke. The passenger side CV boot clamp broke and the boot pulled back. It all looks fine so I just put a new clamp on the boot.
11.54@132.7
[This message has been edited by Justinbart (edited 11-21-2011).]
nosrac
Total ratings: 50
Report this Post11-21-2011 09:18 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thax, but I need to see a pic, I just can't "see" it.
darkhorizon
Total ratings: 451
Report this Post11-21-2011 09:35 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
HAHAHA what a crap idea lol. You will never need to make less power at the line trust me.
Dont actually make me go outside and bolt the rest of my parts onto my car.... I was SO lazy this year I never wanted to actually get my single digit slip.. I dont know why..
LFiero67
Report this Post11-21-2011 11:03 PM Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well hopefully the competition between you a FieroX will push you both to get it done. I want to see it happen next year.
engine man
Report this Post11-22-2011 01:17 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
darkhorizon this is a great thread it has good info . I don't know if that 351VE will work for my engine but i sure hope it will due to the 3.4 dohc are not known for low end but if it would spool up that low in the rpm i think it would help out big time keep up the good work
Justinbart
Total ratings: 119
Report this Post11-22-2011 02:41 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nosrac might since he does that street style racing at TMS on an unprepped surface.
11.54@132.7
[This message has been edited by Justinbart (edited 11-22-2011).]
Chris Hodson
Total ratings: 53
Report this Post11-22-2011 03:37 PM Click Here to See the Profile for Chris HodsonSend a Private Message to Chris HodsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Holy crap.
darkhorizon
Total ratings: 451
Report this Post11-22-2011 06:12 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ugg, I know right!
I just need to man up and turn wrenches on my car for a few hours... ugg! I street raced way way too much this year and ended up breaking it just before track days.
I suppose if you need to run a wussy tire... I still struggle to spin stuff down low with the slicks on even on the street. I can control my boost ramp via how much I brake stall it pretty easily.
[This message has been edited by darkhorizon (edited 11-22-2011).]
Jncomutt
Total ratings: 221
Report this Post11-22-2011 06:14 PM Click Here to See the Profile for JncomuttSend a Private Message to JncomuttEdit/Delete MessageReply w/QuoteDirect Link to This Post
Axle looks exactly like mine that used to break...
engine man
Report this Post11-22-2011 09:08 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got a idea how to actuate the VGT it's not all my idea but this is how it would work .
so when just cruising on the high way you don't see any boost but when you tromp on it boost will be instant .
first you need a dual port actuator for the internal wastegate type turbo hook both sides to the manifold through a 4 port solenoid one side you will hook up so it See's vacuum only and the other side See's boost only to the actuator and solenoid is triggered by a vacuum switch so either side will of the actuator will get vented to the air and the other side will see manifold boost or vacuum . now how i think it would work is while cruising the vacuum pulls the VGT open so no boost but when you slam your foot in it the vacuum drops and the solenoid is closed to the vacuum side and opend to the boost side and the vacuum side is then vented to the air the VGT closes and then as boost builds it now activates the boost side of the actuator to start opening the VGT until you get to the boost you set with a manual boost controller that hooked to the boost side
when setting up you would need to figure out where to set the VGT with out any boost or vacuum
would that work ?
would that work ?
[This message has been edited by engine man (edited 11-23-2011).]
nosrac
Total ratings: 50
Report this Post11-22-2011 10:20 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Trust, I think I'll pass on this one.
nosrac
Total ratings: 50
Report this Post11-22-2011 10:22 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
nosrac
I like my wussy Street tires and don't want to break my Stock Fiero Axle on launch. 1.74 60' and getting faster.
[This message has been edited by nosrac (edited 11-22-2011).]
Justinbart
Total ratings: 119
Report this Post11-22-2011 10:47 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
You will end up getting a good drag radial once you start getting loosey-goosey, even above 60mph.
11.54@132.7
nosrac
Total ratings: 50
Report this Post11-22-2011 11:19 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
U running Drags? What is your best 60' with them? Was that a stock Fiero Axle that you broke?
If I can launch at my same ole 1.7 and trap 130 then I am guessing 10.8. I'm good.
I currently don't have any loosey-goosey even @ 112. But then again I have some $$$ in my suspension.
Justinbart
Total ratings: 119
Report this Post11-22-2011 11:33 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes nt555r.
I was running 1.7's with some other dr's. First time I've had these on the track.
OEM fiero axle.
I was referring to breaking traction at 60+mph might fill your shorts if you are not expecting it.
I blame the wheel hopping on a shitty track breaking my axle. I've never wheel hoped with drag radials at Milan, which is a top notch drag strip.
You will see soon enough what an extra 200hp will do
11.54@132.7
nosrac
Total ratings: 50
Report this Post11-22-2011 11:51 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Agreed and that is why I going for the Dual Stage Boost controler as I really don't want all that power off the line. But right after I pass the 60' mark...(Rocket Switch)
darkhorizon
Total ratings: 451
Report this Post11-24-2011 03:51 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wheel hop broke that axle.. you can easily do this with a very low power supercharged swap.
Justin and I both have to run a serious compound tire to keep these things on the ground. His 17 inch drag radials are pretty crappy under 40mph..
I am running a much laggier setup and a 15 inch slick that will hook anything. If you went with a 10.5 wide drag radial on a 15 inch wheel you will not ever have issues.
