  Remove removing replacing front hardtop moonroof sunroof roof section
Remove removing replacing front hardtop moonroof sunroof roof section by MulletproofMonk
Started on: 02-10-2010 09:00 PM
Replies: 16 (7805 views)
Last post by: Ponnari on 05-19-2015 06:17 PM
MulletproofMonk
Total ratings: 78
Report this Post02-10-2010 09:00 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, since I see the question posted about how to remove the roof I tried to catch all the buzz words in the title...
Ignore what you don't have...
If you are pulling a moonroof car, you need to pull:
outside of the car
pull the window seal
pull the windshield wipers
pull that black pastic cover below the wipers (3-4 phillips screws)
remove fenders (or the 3 10mm bolts closest to the windshield)
remove the 2 10mm bolts on the front of the roof panels (runs under the front of the windshield)
inside of the car
remove the third brake light
remove the clothes hooks
remove the visors
remove the light panel
remove the outside of the moonroof bracket
unhook the moonroof and take it out
remove the interior a pillars (2 plastic clips)
remove the interior seal for the moonroof
remove the headliner (they always crack on me near the 3rd brake light)
remove either 4-6 10mm bolts inside and 2-4 10mm nuts (I can go recount tomorrow)
remove the inside of the moonroof bracket
remove the moonroof handle bolts (little tab you pry down and slide it)
pry the roof up very, very slowly. there is a black tar that holds the roof down like a mother f***er. the best way to do this is with piano wire to cut through the adhesive. you can pry it if you take your time. the place that it will most likey break is on the a pillars. also don't pry by the windshield or you could break it (I did this once).
Pics
-Brian
My 87 GT Poly Suspension Upgrade (all pics) thread https://www.fiero.nl/forum/Forum2/HTML/094633.html
[This message has been edited by MulletproofMonk (edited 07-16-2013).]
josef644
Total ratings: 103
Report this Post05-23-2010 11:55 AM Click Here to See the Profile for josef644Send a Private Message to josef644Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bump to save in favorites
notwohorns
Report this Post05-23-2010 06:56 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
excellent write up. may i add-when lifting up on the roof, put cardboard under it. that keeps the sealer from resticking. it has helped me in the past.
dw9301998
Report this Post03-06-2011 10:19 PM Click Here to See the Profile for dw9301998Send a Private Message to dw9301998Edit/Delete MessageReply w/QuoteDirect Link to This Post
do u know of a thread that has a step by step removal of the rear body parts?
fierosound
Total ratings: 286
Report this Post03-06-2011 10:41 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
This would help https://www.fiero.nl/forum/Forum2/HTML/102310.html
Marine1981
Report this Post07-14-2011 02:28 PM Click Here to See the Profile for Marine1981Click Here to visit Marine1981's HomePageSend a Private Message to Marine1981Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good info to have, I may need to do this soon...
Silicoan86
Report this Post01-06-2012 11:57 PM Click Here to See the Profile for Silicoan86Send a Private Message to Silicoan86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just noticed this thread in your signature. Great write-up, now I'll be less likely to break something during my sunroof swap!
DRWBRTq19
Report this Post05-11-2012 03:18 AM Click Here to See the Profile for DRWBRTq19Send a Private Message to DRWBRTq19Edit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome info! Told me exactly what I needed to know, + for you sir.
Ok, now a stupid question... What do you use when reattaching?
Or is the sticky stuff present enough to properly hold it down/in place.
Thanks
Drew
josef644
Total ratings: 103
Report this Post05-11-2012 04:21 PM Click Here to See the Profile for josef644Send a Private Message to josef644Edit/Delete MessageReply w/QuoteDirect Link to This Post
I used a cup of lacquer thinner, and a one inch paint brush. It made is sticky like new. I didn't add any additional. I sort of squeezed it together with my fingers to make it stand up a bit before the thinner was applied.
MulletproofMonk
Total ratings: 78
Report this Post07-16-2013 12:58 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump for hercimer01 because my pictures where dead. Fixed now.
-Brian
hercimer01
Report this Post07-16-2013 06:43 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
chrislayton
Report this Post02-16-2015 10:27 AM Click Here to See the Profile for chrislaytonSend a Private Message to chrislaytonEdit/Delete MessageReply w/QuoteDirect Link to This Post
outside of the car
inside of the car
remove the visors
Pics
What did you use to glue the roof back down? Do you have a picture of the finished car?
Report this Post02-16-2015 06:53 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Black butyl rubber caulk.
IXSLR8
Report this Post02-17-2015 01:40 AM Click Here to See the Profile for IXSLR8Send a Private Message to IXSLR8Edit/Delete MessageReply w/QuoteDirect Link to This Post
I used a hairdryer in the holes under the roof for removing the top skins. The heat loosens the glue and you can pry it up. Works good. Make sure its hot before you start prying.
Lou6t4gto
Report this Post02-18-2015 01:58 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank You !
hcforde
Report this Post05-19-2015 11:59 AM Click Here to See the Profile for hcfordeSend a Private Message to hcfordeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great giude, I will use this the next time rather than doing the hunt and peck method of finding and removing everything that buttons down the roof.
Ponnari
Report this Post05-19-2015 06:17 PM Click Here to See the Profile for PonnariSend a Private Message to PonnariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks "MulletproofMonk", I'm just getting ready to do this and I bet you have saved me a bunch of time!
"Because in a split second, It's gone"
Ayrton Senna
