  Longitudinal BMW V12 in a Stock Fiero Engine Compartment - 25th Anniversary Countach (Page 7)
Longitudinal BMW V12 in a Stock Fiero Engine Compartment - 25th Anniversary Countach by 88lambo
Started on: 04-11-2010 01:54 AM
Replies: 312 (60487 views)
Last post by: Will on 09-03-2021 03:12 PM
gmctyphoon1992
Report this Post06-14-2012 07:34 PM Click Here to See the Profile for gmctyphoon1992Send a Private Message to gmctyphoon1992Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by 88lambo:
Here you go...Not my engine but same model and year as mine, Video is from Choice Auto Wiring http://www.choiceautowiring.com/ (they made my engine management system) as soon as I get mine started I will post a video...
You mean this Carbon? or with an exhaust
carbon
Total ratings: 132
Report this Post06-14-2012 07:44 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
With the exhaust... the video above doesn't really do anything for me...
Christine
Total ratings: 58
Report this Post08-04-2012 12:28 AM Click Here to See the Profile for ChristineSend a Private Message to ChristineEdit/Delete MessageReply w/QuoteDirect Link to This Post
Update?
jaredmurray88
Report this Post08-04-2012 03:07 AM Click Here to See the Profile for jaredmurray88Send a Private Message to jaredmurray88Edit/Delete MessageReply w/QuoteDirect Link to This Post
somebody has a death wish lets watch lol! NEED INPUT!
88lambo
Report this Post08-09-2012 12:12 AM Click Here to See the Profile for 88lamboSend a Private Message to 88lamboEdit/Delete MessageReply w/QuoteDirect Link to This Post
quick update....
slow going in summer, weather in ontario canada has been hot an dry all summer (level 2 drought) so spending a lot of time at camp and boating
I have mocked up the coolant system, i used plastic electrical conduit, size is close to size of tubing i am planing to use and easy to work with. now i need to fabricate the metal tubes.
hoping to get started on fuel system soon....
photos to follow...
88lambo
Report this Post10-25-2012 12:10 AM Click Here to See the Profile for 88lamboSend a Private Message to 88lamboEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm Back.... been a tuff few months my father got sick and passed away.
slowly getting back into car, have the radiators mounted and plumbing figured out, just have to braze it together...
bubbajoexxx
Total ratings: 112
Report this Post10-25-2012 12:32 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
you can run the rads in series and get better cooling with a lot less plumbing than running them in parallel I did duel rear rads in series with the northstar build i did and got twice the cooling as the first rad pre cools second final cools lowering the return temp buy 100 degres
[This message has been edited by bubbajoexxx (edited 10-25-2012).]
fieroall
Report this Post10-25-2012 01:14 PM Click Here to See the Profile for fieroallSend a Private Message to fieroallEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just an FYI. Those Honda Ebay rads you're using are not very good at dissipating heat. I was using one on my 4 cylinder 2.2l Turbo Dodge Omni and the car would overheat constantly.
Here's a pick of it installed in the Omni. Same unit.
[This message has been edited by fieroall (edited 10-25-2012).]
88lambo
Report this Post10-26-2012 12:40 AM Click Here to See the Profile for 88lamboSend a Private Message to 88lamboEdit/Delete MessageReply w/QuoteDirect Link to This Post
I made rads parallel because I have only found dual rads setup this way in production cars, makes you wonder why, but may be some done in series but i haven't found them yet...
Countach Rad setup - Parallel
Murcielago Rad Setup Parallel
ltlfrari
Total ratings: 127
Report this Post10-26-2012 08:10 AM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is that copper tube? I always thought copper and cars don't mix because the vibration causes it to work harden and fracture.
Dave
www.ltlfrari.com
bubbajoexxx
Total ratings: 112
Report this Post10-26-2012 07:48 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
check out my tread here in the forum and see the setup it works fantastic https://www.fiero.nl/forum/Forum3/HTML/000007.html
bubbajoexxx
Total ratings: 112
Report this Post10-26-2012 07:50 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bubbajoexxx
Member since Aug 2003
yes i have to agree as i have had copper fail thats why i used stainless steel
Total ratings: 259
Report this Post10-26-2012 08:32 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
One of the issues might be a coolant flow resistance issue. In parallel 1/2 the coolant passes through each radiator at 1/2 the flow rate. While in series the 100% of the coolant must pass through both radiators at the full flow rate.
aaronkoch
Report this Post10-26-2012 11:36 PM Click Here to See the Profile for aaronkochSend a Private Message to aaronkochEdit/Delete MessageReply w/QuoteDirect Link to This Post
From an engineering standpoint, the radiator will work better in a parallel configuration. Heat transfers quicker when the delta T is highest. In a series setup, the first radiator gets full temp coolant, but after the first one, it's cooled significantly, making the second one much less effective at transferring heat.
Tusch
Report this Post01-05-2013 01:09 PM Click Here to See the Profile for TuschSend a Private Message to TuschEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump?
PRO4674
Report this Post12-30-2013 12:31 PM Click Here to See the Profile for PRO4674Send a Private Message to PRO4674Edit/Delete MessageReply w/QuoteDirect Link to This Post
[/color[color=#FF0000]] WHATS NEW--WHATS NEW
88lambo
Report this Post01-08-2014 01:05 AM Click Here to See the Profile for 88lamboSend a Private Message to 88lamboEdit/Delete MessageReply w/QuoteDirect Link to This Post
Been bad year haven't done much on car, my wife has been sick for 11 months and raising a 7 year old has cut into car time.
Dropped the drivers floor pan 2 inches to get my fat head into the car. All sensors and wiring harness is on engine. Engine and cradle are out to finished frame work and secure cooling system piping. I have bought all components for fuel, brakes and cooling systems (oil cooler, tranny cooler and engine ) now Xmas is done hoping to poke at car bit more.
BrittB
Report this Post01-12-2014 09:08 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Life and family are more important than a car project. That being said, this is one cool project!
PRO4674
Report this Post01-19-2014 01:39 PM Click Here to See the Profile for PRO4674Send a Private Message to PRO4674Edit/Delete MessageReply w/QuoteDirect Link to This Post
FAMILY FIRST -BEST WISHES
Neils88
Total ratings: 56
Report this Post01-19-2014 11:20 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just caught onto this thread since someone bumped it. I'll be watching it closely, since I'm just beginning a Murcielago build...definitely nowhere near as in depth as your build, but I'm loving the detail your putting in to yours. I decided to start with the engine swap on mine (just a simple 4.9) before moving to the stretch and the body kit. Hoping to have the swap completed by the spring, iron out the bugs, then tackle the stretch and body kit starting this fall. (That way I can enjoy it for the summer and keep the enthusiasm ). It's nice to see someone else in the Ottawa area doing a build. Hopefully you'll give me a chance to drop by to take a look sometime!
88lambo
Report this Post05-20-2014 07:35 PM Click Here to See the Profile for 88lamboSend a Private Message to 88lamboEdit/Delete MessageReply w/QuoteDirect Link to This Post
On April 5th my wife passed away after a major setback during surgery. we were together 30 years and September would have been our 25th anniversary.
Starting to work on car again, "car therapy" when my 7 year old daughter goes to bed at 8 I head out to garage. Find it very hard to be alone in house...life is very different now.
I'll post when I think of it...
85 SE VIN 9
Report this Post05-20-2014 08:20 PM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
That's a terrible blow! You have our deepest sympathy. What can we do to help?
deezil
Report this Post05-20-2014 08:25 PM Click Here to See the Profile for deezilSend a Private Message to deezilEdit/Delete MessageReply w/QuoteDirect Link to This Post
My Word.. My Condolences.....
Report this Post05-20-2014 08:26 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Very sorry to read this....My sympathies to you.
Bloozberry
Total ratings: 311
Report this Post05-20-2014 08:26 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow... that's a tough break. My heartfelt condolences.
jimbolaya
Total ratings: 114
Report this Post05-20-2014 08:36 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just read through this thread and was so excited, it is awesome. Then I get to this last page. Wow, I am so sorry for your loss. Take care of yourself and the family bro.
Jim
Neils88
Total ratings: 56
Report this Post05-20-2014 08:49 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
My condolences. Our thoughts are with you.
Charlie64
Report this Post05-20-2014 09:55 PM Click Here to See the Profile for Charlie64Send a Private Message to Charlie64Edit/Delete MessageReply w/QuoteDirect Link to This Post
My most sincere condolences to you for your loss.
countachmike
Report this Post11-24-2015 09:47 AM Click Here to See the Profile for countachmikeSend a Private Message to countachmikeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wonder if this ever got finished. I have read this thread over and over . Going to do the same for my car. Put the v12 in the stock engine compartment
88lambo
Report this Post05-08-2016 08:55 PM Click Here to See the Profile for 88lamboSend a Private Message to 88lamboEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm still here. Still have car. Lots happened.
Remarried and moved. Have bigger family now. Building storage shed for all the parts (now stored at my brother's place). Hoping to get back on car this fall. Have 19 year old step son has interest in cars so have helper 😉
Total ratings: 207
Report this Post05-09-2016 07:55 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great news! All the happiness to you!
Neils88
Total ratings: 56
Report this Post05-09-2016 07:44 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Let me know if you ever need any local help. My Aventador build is moving along and eventually I'll be picking your brain about the longitudinal BMW installation anyway...
Squash468
Report this Post04-21-2018 11:34 AM Click Here to See the Profile for Squash468Send a Private Message to Squash468Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just read through this entire thread. I reads like a novel. So much has happened . I apologize for reviving an old thread. I hope all is well.
88lambo
Report this Post09-15-2018 10:59 PM Click Here to See the Profile for 88lamboSend a Private Message to 88lamboEdit/Delete MessageReply w/QuoteDirect Link to This Post
Working on car again. Pulled engine out to add finishing touches to engine compartment and to wire engine.
Lambo
Engine in
Engine top view
Engine 3/4 view
[This message has been edited by 88lambo (edited 09-15-2018).]
hercimer01
Report this Post09-16-2018 02:32 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nice work. Did you make the engine and trans adapters.
12.840@104.8 MPH Intense-Racing 1.9 rockers, 3" exhaust, 3.4 pulley, ZZP tune and 18 year old tires.
88 Coupe under construction SOLD
88 formula 3.4L 4t60 swap SOLD
88lambo
Report this Post09-16-2018 10:58 PM Click Here to See the Profile for 88lamboSend a Private Message to 88lamboEdit/Delete MessageReply w/QuoteDirect Link to This Post
I designed the adapters had machineshop make for me.
shemdogg
Report this Post09-16-2018 11:31 PM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very cool build! Sorry to hear about the rough patches. I read thru and saw the fiat x 1/9 door handles, just got a set for my kit car. Luv the v12 swap!
shem
BillS
Report this Post09-17-2018 10:44 AM Click Here to See the Profile for BillSSend a Private Message to BillSEdit/Delete MessageReply w/QuoteDirect Link to This Post
What a huge job!
I hadn't followed this thread before, but it is an interesting project. The engines sound wonderful - this is my Lambo engine, much earlier than yours. How would you like to have to tune those carbs in the chassis?
You could have gone transverse - Lamborghini did it in the Miura, but the transaxle would have been....challenging. One of my favourite living room decorator shots - a Miura power unit made into a table:
88lambo
Report this Post09-22-2018 09:32 AM Click Here to See the Profile for 88lamboSend a Private Message to 88lamboEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine isn’t real Lamborghini engine. Is BMW 5.0 V12. I just had BMW machines off and replaced it with Lamborghini logo
What car is your engine in?
Shantali
Report this Post10-09-2019 03:38 AM Click Here to See the Profile for ShantaliSend a Private Message to ShantaliEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any updates on the lambo since 2018? Inquiring minds need to know.
