  Keen V-8 Fiero, the build (Page 1)
Keen V-8 Fiero, the build by Archie
Started on: 10-23-2010 11:31 PM
Replies: 287 (14500 views)
Last post by: streetstockSS83 on 07-27-2013 08:34 AM
Archie
Total ratings: 547
Report this Post10-23-2010 11:31 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is the build thread for the V-8 Fiero we're doing for CommanderKeen
CommanderKeen has been serving in Afghanistan for the last year & upoin his return home from his service, he found his Fiero had been stolen. You can read about it at https://www.fiero.nl/forum/Forum1/HTML/082229.html
This new thread is about the build of his Fiero.
He has plans to do a lot of things to this Fiero. We are installing an Injected ZZ4 Crate engine. We're also putting on a set of our Integrated Rocker panels & one of our GT Hatchbacks. He ha plans for a lot of other work when we are done. So he plans to take this thread all the way to the completion of the cat.
Here's what it looked like when it got to our place.
The car had been ragged on pretty good
It had 3 wheels on it that looked like aftermarket wheels for another car that had the correct bolt pattern but the wrong offset.
The car had been driven several thousand miles while in the possession of the car thief.
Someone had done an extreme lowering job on the car & the car was finally found abandoned along the hwy.
The engine was wasted. We didn't really care about the engine but we felt it would be nice to know if the trans. & the A/C were in operable condition. So we filled the cooling system with water, hooked up a battery & git it started. The head gaskets were shot & water ran out as fast as we could put it in. But we kept it running long enough to find that the trans & A/C system were still working.
Then we started on the V-8 swap...
As soon as we had the cradle out, the rear suspension was looked at.
When I talked to him on the phone about the suspension he was saying the suspension was still stock & I knew it wasn't. We finally realized that the thief had modified the suspension while they had it.
These pics explain the rear suspension....
Here's the front suspension....
Archie
Total ratings: 547
Report this Post10-23-2010 11:57 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
While decisions were being made about the suspension, the V-8 swap continued...
We has to do some rust repair in the area where the battery used to be. Other than that the chassis was in reaL good shape.
We worked at installing the V-8 onto the engine cradle.
As a gift, I had the engine cradle powdercoated & the CC90 headers ceramic coated.
We prepped the engine compartment.
And installed the engine
It was decided that the front & rear suspensions would be replaced with stock Fiero suspension pcs.
It the rear, that was easy, we just found a set of good springs & the upper hardware. Since the original struts were worn out, we bought a new set of struts & put them together with some poly bushings.
Here you see the car back on the floor with the rear susp. finished & the front suspension yet to do.
To return the front suspension to stock, we had to take off the front crossmember from a donor car.
It was then cleaned, new poly bushings were installed
Looks a little better...
Archie
mcaanda
Total ratings: 129
Report this Post10-24-2010 09:39 AM Click Here to See the Profile for mcaandaSend a Private Message to mcaandaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow - thief's that swapped out the suspension components for something aftermarket; albeit very half assed and incorrect. Unreal...
They really thought they were going to keep the car for sure and not get caught.
Is this where I insert something witty?
jasonfox
Report this Post10-24-2010 10:14 AM Click Here to See the Profile for jasonfoxSend a Private Message to jasonfoxEdit/Delete MessageReply w/QuoteDirect Link to This Post
I appreciate you helping out a fellow soldier Archie.
Archie
Total ratings: 547
Report this Post10-24-2010 01:02 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, Typically, when I know that someone is a veteran or active service member, I try to give them a bit of a discount on the V-8 kit parts. Also, when I do a turnkey install, I try to give them something extra that they didn't expect.
I'll be posting up some more pics to bring this build up to day later today.
Archie
2farnorth
Total ratings: 81
Report this Post10-24-2010 01:53 PM Click Here to See the Profile for 2farnorthSend a Private Message to 2farnorthEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie
Outstanding.. Thanks from another vet
Archie
Total ratings: 547
Report this Post10-24-2010 10:22 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
To bring this up to date.....
We built the 2.5" exhaust on the car then took it off for High temp paint.
We put in the new trunk floor....
Here we're mocking up the location of the hatchback Kit
Notice how it will be sitting right down on the original trunk seal.
The rocker panel install was just like dozens of other sets we've installed.
[This message has been edited by Archie (edited 10-24-2010).]
Archie
Total ratings: 547
Report this Post10-24-2010 10:32 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie
Member since Dec 1999
We then put the vents in the hatch .......
Then the 350Z rear window gets installed.....
After installing the new wheels, it's just about done here....
Archie
mcaanda
Total ratings: 129
Report this Post10-24-2010 11:13 PM Click Here to See the Profile for mcaandaSend a Private Message to mcaandaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie -
You ever happen to have a customer ask to install a wing on the new rear window piece? The more I see that thing the more I really like the looks of it.
nosrac
Total ratings: 51
Report this Post10-25-2010 10:56 AM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie
A Wide Body kit and a Chop would finish that off pretty nicely...me thinks! And I almost forgot a 1" lowering kit too.. But other than that it still looks pretty good. I guess there is always something more to mod.
CommanderKeen
Report this Post10-25-2010 01:14 PM Click Here to See the Profile for CommanderKeenSend a Private Message to CommanderKeenEdit/Delete MessageReply w/QuoteDirect Link to This Post
I originally planned to do a widebody, however when my house was burglarized I lost everything of value I had. I'm sure anyone who's been a victim of major theft can tell you, even fully insured you still end up in the hole The Vehicle was the only thing recovered, it was abandoned about an hours drive from where I live. It had stolen or borrowed plates from another fiero on it. Some dick-head auto-engineering student had some of his stuff in the car, and claimed he bought the vehicle from someone and forgot to register it. Or whatever.
Anyway, the vehicle is going to Mr Norm at Norms Fiberglass for a front end, then will be coming back out to WA state. I plan on building a dash/console for it over the winter. In the Spring I will get it painted. I am thinking BMW Alpine White.
dratts
Total ratings: 118
Report this Post10-25-2010 03:01 PM Click Here to See the Profile for drattsSend a Private Message to drattsEdit/Delete MessageReply w/QuoteDirect Link to This Post
So is that as far as the police go? He was in possesion of stolen property. Doesn't he have to reveal who he supposedly bought it from? Maybe he really did buy it from the thief.
CommanderKeen
Report this Post10-25-2010 04:53 PM Click Here to See the Profile for CommanderKeenSend a Private Message to CommanderKeenEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got a couple updates from the police, the were following up on the car thing to try to maybe find all of my other stuff. Last time I talked to them I pretty much got the "found nothing out, moving on to other stuff" attitude. I had alot more pressing stuff going on though, like replacing and fixing everything that was messed up. At least I had the prudence to pay some movers to take my gun safe to a friends house, so thats about 30k in dangerous crap not floating around out there.
Archie
Total ratings: 547
Report this Post10-25-2010 07:31 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
CommanderKeen
You have a PM
CommanderKeen
Report this Post10-26-2010 12:19 AM Click Here to See the Profile for CommanderKeenSend a Private Message to CommanderKeenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by mcaanda:
Archie -
I thought about it, but I wanted to shoot for as much rear visibility as would be possible with the addition of the hatchback and the removal of the rear q panel windows.
gt88norm
Report this Post10-26-2010 01:32 AM Click Here to See the Profile for gt88normSend a Private Message to gt88normEdit/Delete MessageReply w/QuoteDirect Link to This Post
"Anyway, the vehicle is going to Mr Norm at Norms Fiberglass for a front end, then will be coming back out to WA state."
JBFLM? . . . Uh, . . . bring your rain gear, and get in touch after ya muster in.
Norm
Ooops, I see your already here.
[This message has been edited by gt88norm (edited 10-26-2010).]
NullHead
Report this Post10-26-2010 07:52 AM Click Here to See the Profile for NullHeadSend a Private Message to NullHeadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow that's awesome! First hatch back Fiero I've ever seen aside from the '90s concept.
Could we get a picture of the under side of the hatch, and from the rear of the car with the hatch up?
gt88norm
Report this Post10-26-2010 01:19 PM Click Here to See the Profile for gt88normSend a Private Message to gt88normEdit/Delete MessageReply w/QuoteDirect Link to This Post
Look up BubbaJoe(sp?), I think he had a hatchback project.
Also look @ Archie's site, as he is offering it for public consumption I believe.
The '90 concept car wasn't really a hatch, just separate engine and trunk covers. Still had the "flying buttresses".
And a DOHC!
Norm
carbon
Total ratings: 132
Report this Post10-26-2010 02:29 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Never saw this one?
Archie
Total ratings: 547
Report this Post10-26-2010 08:13 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here's the thread that includes the designing of the Hatchback kit. https://www.fiero.nl/forum/Forum3/HTML/000085.html
& here's the info on my web site http://www.v8archie.com/v8Archie/Kit5.htm
Archie
JPH87
Report this Post10-27-2010 01:36 AM Click Here to See the Profile for JPH87Send a Private Message to JPH87Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have an Archie hatch on my car and the quality is top notch
darkhorizon
Total ratings: 451
Report this Post10-27-2010 09:07 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I thought they were only for fastbacks?
NullHead
Report this Post10-27-2010 01:11 PM Click Here to See the Profile for NullHeadSend a Private Message to NullHeadEdit/Delete MessageReply w/QuoteDirect Link to This Post
wow archie that's fantastic!
I really like the look of that. Perhaps a future Fiero of mine will have to make a visit to your shop .... hmm.
10speeder
Report this Post10-27-2010 01:30 PM Click Here to See the Profile for 10speederSend a Private Message to 10speederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Howdy,
Hey that looks pretty neat! Fine job you have done there Archie!
Jay
Isolde
Total ratings: 133
Report this Post10-27-2010 08:15 PM Click Here to See the Profile for IsoldeSend a Private Message to IsoldeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I love the idea of a secondary back window to help protect the difficult-to-replace stock one. I also think the hatch looks great! Let's get a stock spoiler on Cmdr. Keen's car for the sake of a couple photos, please.
MadDanceSkillz
Total ratings: 88
Report this Post10-27-2010 08:49 PM Click Here to See the Profile for MadDanceSkillzSend a Private Message to MadDanceSkillzEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm getting one. That is just awesome! Great way to show off an engine swap.
Archie
Total ratings: 547
Report this Post10-27-2010 09:41 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys.
For the last 2 days I've been meaning to get some pics with a wing sitting on the hatch, but I keep forgetting.
Tomorrow, I'l do it.
Archie
Archie
Total ratings: 547
Report this Post10-27-2010 09:59 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie
We've got about 60 test miles on the engine swap & all is good.
We also installed the Fiero Store tail light covers that the owner ordered.
they are pretty nice.
As part of test driving, we had it up on the lift to check things over & I took a few pics.
We're pretty much done with it........ going to put about 40 more test miles on it tomorow & that's it.
Archie
GT-X
Total ratings: 106
Report this Post10-27-2010 11:06 PM Click Here to See the Profile for GT-XSend a Private Message to GT-XEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Archie,
How much modification is needed to make your hatch fit a choptop? How much more would it cost?
~Tyler
gt88norm
Report this Post10-28-2010 01:02 AM Click Here to See the Profile for gt88normSend a Private Message to gt88normEdit/Delete MessageReply w/QuoteDirect Link to This Post
The little duck tail from a Saab 99 euro just below the back window,
not the Fiero wing style, please. Similar to the one on the 900s but
understated.
Norm
[This message has been edited by gt88norm (edited 10-28-2010).]
Total ratings: 465
Report this Post10-28-2010 02:46 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ah, true duals. Love it!
madcurl
Total ratings: 314
Report this Post11-01-2010 11:25 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
What the heck! I take a nap for a few days and I've been missing all of the fun!
"Friends don't let their friends drive stock."
Frizlefrak
Total ratings: 72
Report this Post11-02-2010 01:05 AM Click Here to See the Profile for FrizlefrakSend a Private Message to FrizlefrakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great build thread Archie. And kudos for helping out folks who have served their country
Keen....sorry this happened to you, but it looks like your Fiero may be the silver lining to the cloud. Keep us posted on the progress. The Alpine White paint sounds like a good choice.
madcurl
Total ratings: 314
Report this Post11-02-2010 05:55 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is the Norm's nose on yet?
Archie
Total ratings: 547
Report this Post11-02-2010 11:59 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Norm picked her up today.
Archie
doublec4
Total ratings: 150
Report this Post11-03-2010 12:13 AM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is there a reason for not bridging the two paths of flow for "equalization" of pressure? I'm considering changing up my exhaust soon to true duals and had planned an "H" pipe design. Any adverse affects of not doing an H or X?
Check out my build!
https://www.fiero.nl/forum/Forum3/HTML/000100.html
Total ratings: 465
Report this Post11-03-2010 12:24 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hopefully we'll hear from Archie himself, but looking at the picture of his exhaust system, how would you fit the H or X "bridge" between the cats and the mufflers? It would be pretty complicated to do in that limited space.
Besides, the H or X "bridge" ruins the sound. Duals always sound meaner when each bank is completely separate.
XzotikGT
Report this Post11-03-2010 01:48 AM Click Here to See the Profile for XzotikGTClick Here to visit XzotikGT's HomePageSend a Private Message to XzotikGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice build for sure SPC Samuel P Rogers.
[This message has been edited by XzotikGT (edited 11-03-2010).]
XzotikGT
Report this Post11-03-2010 01:53 AM Click Here to See the Profile for XzotikGTClick Here to visit XzotikGT's HomePageSend a Private Message to XzotikGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
XzotikGT
Member since Mar 2004
XzotikGT
Report this Post11-03-2010 01:59 AM Click Here to See the Profile for XzotikGTClick Here to visit XzotikGT's HomePageSend a Private Message to XzotikGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
XzotikGT
