  Lightweight fiero 101: 2300 pound curb weight is my goal (Page 12)
Lightweight fiero 101: 2300 pound curb weight is my goal by sunofjustice
Started on: 11-25-2010 04:43 PM
Replies: 445 (29310 views)
Last post by: Francis T on 08-02-2017 08:11 AM
hobbywrench
Report this Post04-03-2013 08:01 PM Click Here to See the Profile for hobbywrenchSend a Private Message to hobbywrenchEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by mcguiver3:
I havent followed this thread for a while now but in reply to the Lexan Windshield.
I just replaced the one in my 88 race car for the second time.
I have a template made from cardboard and buy a piece 32"X 60 from a local distributor.
This last one (3/16") cost me $80
BTW the car is down to 2250#
Is that windshield piece unformed and just forced to follow the channel with clips or button head fasteners? What thickness? Using a vertical support a la nascar? thanks
Blacktree
Total ratings: 350
Report this Post04-04-2013 12:15 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the Fidanza aluminum flywheel in my Fiero. It weighs 8 lb, exactly half as much as the stock flywheel.
mcguiver3
Report this Post04-04-2013 12:13 PM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Lexan is unformed.
It accepts the shape very well with no distortion.
I use a thick glazing tape on the metal flange.
The flange has been drilled and Rivnuts installed every 6" at the perimeter.
The Lexan drills clean (use a dull bit) and don't torque the screws too much
I don't seal it in because I need to replace it every 3 years.
Remember, this is a race car....
hobbywrench
Report this Post04-05-2013 08:50 PM Click Here to See the Profile for hobbywrenchSend a Private Message to hobbywrenchEdit/Delete MessageReply w/QuoteDirect Link to This Post
mcguiver3, roger, I have an NX 2000 with rear hatch in plex, 54"x 39." It's a street setup. It also is unformed , 3/16" and sealed with a special adhesive. The seal is perfect, but the drain channel is a bit problematic . The plex is not solid bolted, rather in clips with the advesive giving 3/8" movement over temp extremes. My fiero has the makrolon rear window also in clips.
ITALGT
Report this Post03-04-2015 07:58 PM Click Here to See the Profile for ITALGTSend a Private Message to ITALGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
BuMp... because threads like this should never die.
Francis T
Total ratings: 119
Report this Post08-02-2017 08:11 AM Click Here to See the Profile for Francis TClick Here to visit Francis T's HomePageSend a Private Message to Francis TEdit/Delete MessageReply w/QuoteDirect Link to This Post
This an old thread but still interesting. Do you still race the car and have you made any more mods to the engine?
