  Lightweight fiero 101: 2300 pound curb weight is my goal (Page 6)
Lightweight fiero 101: 2300 pound curb weight is my goal by sunofjustice
Started on: 11-25-2010 04:43 PM
Replies: 445 (29310 views)
Last post by: Francis T on 08-02-2017 08:11 AM
baldlobo
Report this Post12-09-2010 04:19 AM Click Here to See the Profile for baldloboSend a Private Message to baldloboEdit/Delete MessageReply w/QuoteDirect Link to This Post
and while i feel agitated; the weight center line for the fiero isn't that somewhere around where the seats mount considering it's 43/57 front/rear
it does surprise me that you have coil overs infront, though
RotrexFiero
Report this Post12-09-2010 08:14 AM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I respect what you are doing and your goal I think is to make a faster car, but with all the work you are doing and sacrifices you are making it would be easier to just legitimately upgrade the engine HP some how. Just adding a turbo would give you what you want without all the work. Seriously, I know you are against the added weight but, seriously again, you would have your cake and be able to eat it also.
SCCAFiero
Report this Post12-09-2010 08:58 AM Click Here to See the Profile for SCCAFieroSend a Private Message to SCCAFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by timgray:
I did actual testing on air filters, I have real numbers, my numbers match those from Car and Driver and other real car writers. K&N filters do absolutely nothing at all. there is a ZERO pressure difference between the inside and outside of a paper filter. in fact a very dirty one showed only a 0.1psi drop.. PSI drop = loss in air flow.
I disagree they do nothing. They allow the vehicle to shed a few pounds and can still function when they get wet.
We agree the filtration/performance is not the issue here. I will agree with you even further and say that any street car does not NEED that level of performance to get from point A to point B. You may have missed the point of my post. The stock system has several ducts, brackets, clamps, water separator and parts that all add up to a lot more weight than an aftermarket setup. I am curious what that total weight is including a dirty element. Not to mention if you get a K&N filter wet, they still work. How long will a paper element last when it is getting rained on? The purpose of this thread is weight loss for performance gains. I have a short section of sheet metal duct about 4-6 inches long, connecting the throttle body to a cleanable cone filter mounted directly below the left side grille. I race in the rain, yes the filter gets wet and no I have never felt a performance difference because we can't go as fast in the rain anyway. I don't have to deal with snow where I live. How well do paper filters work when they are soaking wet?
As far as not doing anything, they also take up less space under the hood which means I can replace my slave cylinder, check shift linkages, check for loose bolts and generally have a lot more working space around that side of the engine. Some people have them because they think they look cool. Since you brought it up, I have had the same cleanable element for 5 years now. I am not an environmental extremist, (my car gets about 6-8 mpg on track) but not throwing one away every few months, times millions of vehicles, would make a pretty big dent in landfills, and corporate profits. I see no reason to continue to pay for paper filters when i can use that same money for other things.
It's just a friendly discussion.
baldlobo
Report this Post12-09-2010 12:35 PM Click Here to See the Profile for baldloboSend a Private Message to baldloboEdit/Delete MessageReply w/QuoteDirect Link to This Post
scca
they are soaked with oil to stop dirt from entering the engine; not that they filter air at all, here's a neat experiment hold one up to a light see all the holes.
people who run those filters are causing their engine more wear(i can bring in pics from another forum if you want); lets just say the intake tube from the filter back was caked with dust
Report this Post12-09-2010 12:53 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure if this was mentioned yet, but your seat covers and steering wheel cover might be adding some weight.
SCCAFiero
Report this Post12-09-2010 01:15 PM Click Here to See the Profile for SCCAFieroSend a Private Message to SCCAFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by baldlobo:
scca
I don't disagree. In addition, some people don't oil them and I have also seen people rig up different adapters that leak more air past the filter than they think.
I shift my built 2.8 around 7k rpm in relatively clean environments, and my oil is frequently changed. The dust particles that get past the filter are the least of my worries.
Everything is a compromise. I have dropped the cradle out of my car in 38 minutes, because ALL the excess stuff is gone. Another advantage of using it.
Again, the topic is weight loss, not practicality, or maximizing engine life.
Report this Post12-09-2010 01:42 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Are plastic racing seats lighter?
Are you doung this as low budget as possible, or could stuff like that be on the table?
Lexan windows?
HausFiero
Report this Post12-09-2010 10:35 PM Click Here to See the Profile for HausFieroSend a Private Message to HausFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
He has already stated that he is on a tight budget. Although shedding weight is a strenuous PITA way to gain performance, it is also the cheapest (removing parts doesn't cost money) way
sunofjustice
Report this Post12-10-2010 11:29 AM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
To all those concerned,
Due to having to respond to so many OFF TOPIC inquiries,
(many of which were spiteful and just plain mean)
additional pictures , plus the REAR weight loss list,
COULD'NT be posted.
In an attempt to MOVE ON and possibly show more
interesting work that was done on the car,
( which ISNT DONE yet.)
I admit to truncating my responses somewhat,
because I was IMPATIENT and wanted to start
posting my pix relatively IN ORDER.
Curiosity about a project is fine, but when I have to
DEFEND myself at EVERY turn, you can hopefully understand
it gets very aggravating, very fast.
(I have SURPRISES on the back burner,
and I did'nt want to say TOO MUCH.)
Even if my comments were "common knowlege",
were'nt in enough detail, were'nt technical enough,
seemed half-baked, or did'nt make sense.........
( I'm musing sometimes)
regardless, they were ( to me) DECENT answers to
questions that were INCREASINGLY OFF TOPIC.
I'm NOT a mechanic, an engineer, or well off,
and I admit my communication skills are whack
at times.......BUT I have PASSION for the fiero and
wish to contribute my own version of it WITHOUT
any unnecessary animosity.
P.S. x three:
The car ISNT DONE YET, alot of issues are still under evaluation.
(what grade of aluminum, what shape, is this thick enough, will this
fit, will this hold, this part is too heavy, but necessary, should I
add an additional bracket, this over here COULD be drilled, how much
money is actually needed, if I use lexan, how about......ETC., ETC.
The aero dynamics questions/ and horsepower tips were just a diversion,
AND a "peace offering" (which obviously DID'NT work),
so I could MOVE ON and eventually start posting ON TOPIC
nomenclature again.
I apologize if this mislead people into thinking I did'nt care about what
I was doing, or intend to do in the future.
Again, the car ISNT DONE, I'm just showing WHAT was done SO FAR.
SCCAFiero
Report this Post12-10-2010 11:58 AM Click Here to See the Profile for SCCAFieroSend a Private Message to SCCAFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Relax.
We have all been there in one form or another. I have broken my share of stuff trying to figure out what works, just like most on here.
We would be wrong if we did not try to pass on some of our mistakes and triumphs so you can learn faster and maybe make fewer mistakes.
Some of us pass that information on more eloquently than others.
sunofjustice
Report this Post12-10-2010 12:17 PM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
To those concerned,
I spent a few hours last night looking over
OFF TOPIC info to have a proper defense,
as well as a point blank OFFENSE to
your various comments.
( I got some pretty good, thermal nuke
rebuttal info too.)
But, this horde of tangents
is NOT PRODUCTIVE.
So, I'm throwing away the TWO pages of notes
acquired. ( Maybe. Knowledge IS power.)
Also,
about the OFF TOPIC matter of adding a turbo
on a STOCK 2.8 .......
YES, it CAN and has been done without failure.
Buttttt, if you dont get your fuel mapping (.bin file),
injectors enlarged,2 bar map sensor, 80's buick knock
sensor or stock ecm reprogrammed to accept the 2 bar map,
OR use the T bird T3 super 60 trim......PLUS
incorparate a turbo timer as cheap insurance,
you WILL break the engine.
( I might have left some things out, but I'm NOT
really interested in a turbo. YET.)
So, PLEASE dont ask me about this anymore.
On the mea culpa about the early year fieros
having a drag coefficent of .41 (or CX to 0.417),
I was in a RUSH to finish replying to an OFF TOPIC
inquiry.
The info I got from the brooklands "road test books"
series titled " PONTIAC FIERO 1984-1988",
page 8, lower left under the diagram.
The CX to 0.417 was the number given when the 84's
HEADLIGHTS were UP.
I'm NOT picking on the early year fieros.
I was trying to prove a point that aerodynamics are compromised
on a STOCK fiero and not just on a modified car like mine.
(Again, I'm not being passive agressive or anything,
but lift figures for the same car were at 120 lb at 100 mph.)
The 86 gt probably has some STOCK lift numbers too,
but I dont wanna kept dwelling on this matter anymore
anyway.
Baldlobo,
even though we got off on the wrong foot,
I appreciate your input.
Best way to sum it up,
"Steel sharpens steel".
With this said, I'm interested in posting pix again.
[This message has been edited by sunofjustice (edited 12-10-2010).]
sunofjustice
Report this Post12-10-2010 04:11 PM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
sunofjustice
Member since Jun 2009
Here are some more pix of the interior.
Like I mentioned before,
money is TIGHT.
(trying to pay down my debts,
credit rating IS going up though)
The quality of the vinyl is dubious,
fit and finish is quasi askewed,
but since this is my FIRST attempt
at weight reduction WITH some sort
of style incorparated, this will have
to do for now.
(Plus, it didnt help that I had to deal with
TWO civial court cases at the same time.
Filling out, and making my own interrogetories.)
Heres the aux temp. gauge pod
I WAS driving around without anything there,
and no computer cover.
The gaping hole was getting on my nerves alittle,
and people at work kept nagging, "so.......
when are you gonna finish the interior?"
An IPOD speaker system (about 9 -10 oz.
versus 12 pounds of STOCK radio whatnot),
will eventually be used thats transportable.
When not in use, the ipod stereo system (ISS)
can be hidden, OR taken out when needed.
A hidden door in the NEW aluminum dash
will be incorparated.
Here are the gas tank tunnel skirts installed,
they re mainly there to hide wire from the battery.
(aesthetics help keep the car from looking abandoned
here in Michigan, cops see NO INTERIOR.....
you can pretty much anticipate trouble.)
( When its WARM, the wrinkles smooth out.)
Some pieces of trim are still in there, (door surround,
plastic that surrounds the rear speakers, the dash,
map light surround) they' re NOT staying.
The headliner , sun roof metal surround and sun visors are history.
The sunroof, and rear window will get lexan.
baldlobo
Report this Post12-10-2010 05:35 PM Click Here to See the Profile for baldloboSend a Private Message to baldloboEdit/Delete MessageReply w/QuoteDirect Link to This Post
not to hijack your thread again but did you connect the ab aldl pins while you were trying to time the engine?
if you did your damper is loose(it's a design flaw)
sunofjustice
Report this Post12-11-2010 01:52 PM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Even though the VECI label was missing,
YES....the "A" and "B" terminals were
grounded on the ALCL connector for timing.
Looked up dampner in search,
engine was remanufactured, SHOULD'NT
be an issue.
I appreciate the heads up ,and I'll keep an eye on it.
Brian
sunofjustice
Report this Post12-11-2010 02:21 PM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
sunofjustice
I would like to switch over to the
autometer ULTRA-LITE series
gauges , since they are SUPPOSEDLY
lightweight like their namesake implys.
While surfing the net, I found these.......
Sexy, sexy.
I plan to install: water, oil, and volt gauges,
NOT these examples in particular.)
I still have to find out IF there is any real
weight reduction savings, but I'm not sweat'n it.
These were REALLY cheap, look much better
than the ones summit had for sale, and I could really
use them to clean up things gauge wise.
Blacktree
Total ratings: 350
Report this Post12-11-2010 03:21 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just FYI, a Group 51 car battery weighs about 5-6 lb less than the stock Fiero battery. The group 51 battery is top-post, which I prefer for more positive terminal connection. You may want to check for engine bay vent clearance, though. You should be able to find one at your local auto parts store.
Also, the rear clip has lots of extraneous fiberglass. You could easily trim 4-5 lb of "useless fat" from the rear clip, without affecting the appearance or structural strength (I actually trimmed 12 lb out of it, but that involved deleting the supporting structure for the stock tail lights).
And I'm sure you could give the decklid the same treatment you gave to the hood. And those black plastic triangular trim pieces above the engine bay vents... you can ditch those. Then you can trim out the supporting structure for them that's molded into the rear clip. If you decide to delete the engine bay vents (even the stock ones), you can get rid of the plastic / metal parts that support them. More pounds gone.
I actually enjoy reading your thread, even though I don't plan to get so "hard-core" with the weight reduction. Don't mind the peanut gallery. The more you respond to them, the more fervently they will come back at you.
[This message has been edited by Blacktree (edited 12-11-2010).]
sunofjustice
Report this Post12-11-2010 03:55 PM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The current after market temp. gauge
does an exemplary job, but it IS portly!
(It almost weighs as much as the
STOCK dual gauges)
The triple gauge set, with an aluminum cage,
would certainly make gauge reading more efficient
as well as lightweight.
Here are the other aftermarket gauges
The boost gauge was back when I seriously
contemplated supercharging.
An air/ fuel gauge will be substituted when
the dual throttle body project is completed.
[This message has been edited by sunofjustice (edited 12-11-2010).]
sunofjustice
Report this Post12-11-2010 04:10 PM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
sunofjustice
Blacktree,
funny that you mentioned the REAR deck
weight reduction........................
( WARNING: kids, dont try this at home)
I removed material from behind the tail lights too,
I'll have to post it tomorrow though.
Almost time to go to work.
(I owe, I owe, so off to work I go"...)
joshh44
Report this Post12-11-2010 08:49 PM Click Here to See the Profile for joshh44Send a Private Message to joshh44Edit/Delete MessageReply w/QuoteDirect Link to This Post
sometimes you have to gain alittle extra weight to be faster.
adding an extra 20 or so lbs in turbo gear and such (no idea how much a turbo weights, im just guessing) to gain an extra 20 - 30+ hp will be alot easyer then trying to remove 200 to 300 lbs off the car.
you could do an engine swap to a smaller higher output engine, or bigger engine :P
from what i been reading. the 4.9V8 engine weighs about the same as a 2.8. with 60 more hp and about 100 more tq.
with a 2300 curb weight with good powerful engine. you would be one quick little sucker!
i would do a what you would be doing but im starting to get alittle older. and im starting to lean towards more a quieter ride :P
by the way. i kinda skipped abit of your thread cuz alot of it seemed to be alot of bashing towards you with how you are doing things. how much weight did you loose by cutting up the rear deck?
just had an idea. hood pins on your deck lid. totaly cut it up for even more weight savings. and just use hood pins on your deck lid to keep it in put. if you had to pop the deck lid to work on it. it would be fairly light to take off. and lean it up agaist the car.
joshh44
Report this Post12-11-2010 08:52 PM Click Here to See the Profile for joshh44Send a Private Message to joshh44Edit/Delete MessageReply w/QuoteDirect Link to This Post
joshh44
Member since Aug 2007
i thought about removing the carpet afew years ago and spraying the botton of the floor with expandable foam on the edges and smooth it out once it got hard. and then buying some thin fabric like a bed sheet or something along thos lines and spray clue all over the floor and just laying out. it would cover the uglyness of the floor while being lightweight
sunofjustice
Report this Post12-12-2010 04:00 AM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Blacktree, Joshh44,
Mucho thanks for the ideas!
no offense,
but I still wanna get a 15 pound DRY CELL battery.
(My current battery weighs roughly 38 pounds,
the dry-cell would shave off 23 pounds!)
Blacktree,
I certainly appreciate the sail panel
weight reduction mod.
The rear vent mounts are already scuttled.
Pix of the area behind the tail lights will be posted soon.
I'll remove the over roof scoops AFTER
new aluminum vents are made.
Hopefully, IF the weather is cooperative,
I'll have some CLEAN, NICE LOOKING
vents done by this Sunday.
(Or, at least ONE of them.)
Joshh44,
Thank you for posting.
I have'nt totally dismissed the turbo idea,
the 3.4, OR the northstar.
All of these ideas arent bad.
But, The turbo is RISKY,
and the other two require MORE money,
which I DONT HAVE right now.
(Plus, I would have to PAY someone
to install the engine, as well as pay
for the engine itself.)
I realize the dual throttlebody idea
wont make as much power as a turbo,
or a BIGGER engine.
But, if everything goes well,
I SHOULD get at least 15-20 hp.
(After getting a chip burned for the application
of course.)
gambler85
Report this Post12-12-2010 02:10 PM Click Here to See the Profile for gambler85Send a Private Message to gambler85Edit/Delete MessageReply w/QuoteDirect Link to This Post
i know this might be off subject but do you still have those intakes, and if you do are you willing to sell them?
sunofjustice
Report this Post12-12-2010 02:38 PM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Before posting more "carnage" pix,
I wanted to share some info on lightweight,
race oriented batteries.
I'm certain someone else
has already done so, but thought this
would be interesting.
https://p10.secure.hostingprod.com/@www.voltphreaks.com/ssl/catalog/product_info.php?cPath=1_5&products_id=81
(Not sure about posting links, hope this worked)
sunofjustice
Report this Post12-12-2010 02:42 PM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
sunofjustice
Did'nt work, @#$%!!
sunofjustice
Report this Post12-12-2010 03:01 PM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
sunofjustice
Gambler85,
Sorry,
I'm not interested in selling them just yet.
(They're coming off for the initial weight loss,
and future TESTING of aero drag.)
I'd like to have some lighter, more svelt, wind-cheating
over roof scoops welded up to replace them.
THEN, I'd probably sell them.
Again, thank you for inquiring.
Brian
Blacktree
Total ratings: 350
Report this Post12-12-2010 03:30 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Funky link, but this one works: www.voltphreaks.com/ssl/cat...h=1_5&products_id=81
Cool batteries, but OMG expensive!
sunofjustice
Report this Post12-12-2010 04:02 PM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since the link did'nt work,
and the pics are'nt allowed here
due to size, I'll just give some
quick names and specs of the
VOLTPHREAKS: VPH 750 (5.5 lbs)
700/390 CA/CCA
Ideal for 4, 6, and 8 cyl.
Lithium Iron new battery chemistry
found in hybrids and electrical vehicles.
COMPLETE battery system designed to
AUTO SHUT OFF to guarantee FULL start,
alarm, and settings.
Price.......(drum roll please)........
$ 1299.00
It sounds REALLY wonderbah untill the bill comes.
(Dine and dash!)
Good gravy, for THAT much it should drive the car
for you too. Yikes.
BRAILE: B129 (9.5 lbs)
813 "pulse amps"(?)
Price....... $155.00
(Sounds ALOT better than the first one.)
BRAILE: B106 (6.6 lbs)
527 "pulse amps"
Price........ $148.00
(I may have to look at these a bit more. Hmmm.)
The HAWKER PC680 WAS my first choice,
but I've been reading ALOT of negative
COLD WEATHER commentary on this one today.
(The PC925 might be better for winter,
even though it weighs roughly 26 lbs.)
Great, more homework to do.....
[This message has been edited by sunofjustice (edited 12-27-2010).]
sunofjustice
Report this Post12-12-2010 04:07 PM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
sunofjustice
Blacktree beat me to the punch, DOH!
Blacktree
Total ratings: 350
Report this Post12-12-2010 04:41 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
BTW, Summit Racing sells the Braille batteries. Looks like the prices are a little lower, too (unless the prices you quoted include shipping).
Check it out:
http://www.summitracing.com/parts/BRL-B106/
http://www.summitracing.com/parts/BRL-B129/
I would personally go with the B129, because the CA rating on the B106 would be "iffy" for an automobile engine.
sunofjustice
Report this Post12-12-2010 04:58 PM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Blacktree,
Surprisingly enough,the braile battery specs
on the summit site did'nt quite match my written notes.
(Damn chicken scratch.....)
I reiterate, the Braile 129 DOES look like a winner.
[This message has been edited by sunofjustice (edited 12-12-2010).]
sunofjustice
Report this Post12-12-2010 06:40 PM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
sunofjustice
Anywho,
heres the pix of the rear as promised,
I had to go back out into our glorious
Michigan weather to get 'em.
The area above the brake lights was supposed
to be resealed with .16 gauge aluminum.
But after days of cutting, with drill battery packs
running out (no garage), and one battery died on me....
I got a little burnt out.
Eventually,
the aluminum patch panels will be shaped
into shallow, rectangular boxes that will
be able to TEMPORARILY hold tools
and such when working on the engine.
The rear vent mounts are already out.
Both brackets combined weighed 1lb/ 9.5 oz.
(Roughly 2 pounds.)
Small aluminum brackets will be swapped in
to replace them.
A tally for all the weight removed from the rear
decklid, engine, and rear bumper will be posted next.
HausFiero
Report this Post12-12-2010 07:29 PM Click Here to See the Profile for HausFieroSend a Private Message to HausFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
A notchback conversion would definitely be a good way for u to save weight lol
SCCAFiero
Report this Post12-12-2010 08:28 PM Click Here to See the Profile for SCCAFieroSend a Private Message to SCCAFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
This got my attention.
Do the notch back clips have that much excess on them as well? I have been debating on removing mine just to see if there was any worthwhile gain. Now that I see this, it looks like that will be my next project. Do you have any photos of what you removed. Any cracking or reassembly issues, or did you just remove whatever you saw without removing the clip.
Anyone have a photo of the bottom side of a notch back clip so I can plan ahead?
Blacktree
Total ratings: 350
Report this Post12-12-2010 10:32 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
My Fiero is a notchie. So yeah, there's weight to be shed there. It depends on how radical you want to get with the body mods. I did some pretty radical stuff, but shed about 20-25 lb off the rear end in the process.
You can read all about it here: https://www.fiero.nl/forum/Forum3/HTML/000049.html
dobey
Total ratings: 371
Report this Post12-12-2010 10:54 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
If one is only concerned with losing weight, and not so much with function, the whole body could just be removed. Should get you a nice couple hundred pounds lost easily.
sunofjustice
Report this Post12-13-2010 07:42 AM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am NOT only concerned with weight.
Obviously, I still want a semblance of STYLE,
anyone can just STRIP a car down.
I'm trying to keep the aesthetics of a 86 GT
by losing weight, and INCREASE
acceleration/braking as a byproduct.
No offense to the notchbach crowd,
my car IS currently LIGHTER than a notchie.
sunofjustice
Report this Post12-13-2010 08:00 AM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
sunofjustice
Rear weight removed???
Rough estimate......40 pounds.
(Theres STILL "gold" in them
thar hills.)
sunofjustice
Report this Post12-13-2010 10:11 AM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
sunofjustice
OK, peeps.....
here is the REAR weight loss list.
(Still ongoing)
Metal bumper 10 lbs
Rubber bumper "waffles" 5 lbs
Bumper reflectors
(Both) 2 oz.
Fiberglass removal
(Behind /above tail lights) 3 lbs
Fiberglass removal
(Rear decklid) 10 lbs
Fiberglass removal
(Rear wing, FULL removal) 10 lbs
Fiberglass removal
(Rear wing, PARTIAL removal.
Sections+pedastles removed) 3 lbs
Decklid trunk spring
(Plus torx bolts/ pins) 5 lbs
Decklid trunk release
(solenoid) 12 1/2 oz.
(Harness) 4 oz.
Decklid torsion bar bracket supports 5 oz.
(little oval shaped bits)
Engine bay heat insulation ?
Emissions vacuum canister ?
Emissions vent pipe
(Firewall) ?
Battery tray
(Original) ?
Air intake system
(Original) ?
Engine vent screens
(Thin restrictive piece) ?
Engine vents support brackets
(Both, on strut towers) 1 lb 14 oz.
Cruise control
(Plus nomenclature) ?
Trunk fan
(Plus ugly air tubes) ?
Trunk fan mounting bracket
(with studs) 3.5 oz.
Trunk carpet 5 lbs
(Guesstimate)
Trunk carpet light 1 3/4 oz.
Emergency brake handle ?
Emergency brake cable 5 lbs
Emergency brake brackets
(On calibers) ?
(Bolts rounded off,still on car)
Stock A arms and support brackets
(Replaced with RCC tubular A arms,
anti-bumpsteer kit) ?
Exhaust heat sheilds
(Both, under bumper) 9.5 oz.
Rubber inner fender splash guards
(I Only drive when DRY.) 1 lb
Plastic inner fenders
(Trimmed just a bit off the bottoms) ?
Engine weights removed:
EGR valve
(Plus, lower bracket) 3 lbs
EGR valve to intake tube 4 oz.
EGR valve heat wrap sheath
(Factory)
(Some bozo mechanic
replaced my aftermarket
UPGRADE.) 2 oz.
PCV valve cover to airfilter tube ?
PCV intake to valve cover tube
(Plastic) 1 oz.
Power brake vacuum hose
(Rubber) 4 oz.
Various unused vacuum line
(Rubber) ?
Throttle body to thermostat "heater tubes"
(Metal) ?
Map sensor bracket 1 oz.
Coil / engine hoist bracket
(Replaced w aluminum
+added ground) 13.4 oz.
Dipstick / engine hoist bracket
(Replaced with a small
aluminum bracket) 11.5 oz.
Dogbone SECONDARY bracket
(Bolts behind the primary bracket,
also used to support A/C bracket) 1 lb 9.5 oz
Catalytic converter
(Stock) ?
Exhaust hanger springs
(Stock) ?
Starter support bracket
(Stock) ?
Muffler
(Stock, replaced with thrush
glass pack) ?
Here's another chestnut....
On the cradle, there are little "tabs"
or (hooks) that the factory used to help
hold the exhaust in place.
With a custom exhaust, these tabs really
arent needed anymore.
Every once can add up.
LOSE what you dont use or want,
so you can keep what you DO need
or want.
Quid pro quo, sort of.
Brian
[This message has been edited by sunofjustice (edited 12-13-2010).]
sunofjustice
Report this Post12-13-2010 10:29 AM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
sunofjustice
With the addition of:
an ALL aluminum decklid,
aluminum engine heat vents,
some light trunk surgery,
and a dry cell race battery..........
There is even MORE weight savings
to be had.
doublec4
Total ratings: 150
Report this Post12-13-2010 12:39 PM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
When are you going to take this thing to the weigh scales?
