  Lightweight fiero 101: 2300 pound curb weight is my goal (Page 1)
Lightweight fiero 101: 2300 pound curb weight is my goal by sunofjustice
Started on: 11-25-2010 04:43 PM
Replies: 445 (29310 views)
Last post by: Francis T on 08-02-2017 08:11 AM
sunofjustice
Report this Post11-25-2010 04:43 PM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
As the title states,
just looking to make my vehicle more competiative,
and more fun to drive WITHOUT spending alot of bread.
"Lean and mean, for less green.."
Since weight reduction is a time honored, hotrodder
and racing prerequisite....
(every 100 pounds is equivalent to ten horsepower,
not sure how much, but more MPG is anticipated as well)
....my goal of a 2300 pound curb weight SHOULD be doable.
The test subject is an '86 gt, engine is a 2.8 with 20,000 miles
with simple hi-po mods. hogged out TB, bigger injectors,
ported heads,r.rockers, headers ...........Blah blah.
Heres some previous "before" shots.....
For those who have already seen these pix,
my apologies for the rehash.
Just giving a visual baseline for future comparisons.
Also, I am NOT an authority on weight reduction.
This ongoing project is a learning curve of sorts
since a LARGE amount of weight has to be removed,
OR replaced with lightweight components.
But, an eye must be kept on retaining a decent
level of style whilst shedding pounds.
Already spent most of the summer on a "quick
and simple" (yeah, right) replacement for my gutted interior.
Will be posting uber metric tons of photos (if I can find all of 'em).
I mainly, started this thread because no one posts PICTURES
of their weight reduced fiero!!!
Maybe I'm not searching hard enough, but most posts are all
words and no examples. IMO
Also, if you have photos...please post them here for others to see
and provide inspiration.
RWDPLZ
Total ratings: 306
Report this Post11-25-2010 04:55 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Gut the interior, everything, even that, um, 'antique' stereo
Lose the warm air intakes
remove headlight assemblies
remove spare tire and jack
remove any AC equipment (compressor, condenser, underdash box, lines)
Shedding weight on a Fiero is NOT easy. The reason you don't see a lot of examples is because few people have dedicated track cars, which is the only thing you'd want to lose the weight on. No interior and AC for a gain of 20HP isn't worth it to most people.
HTXtremes
Report this Post11-25-2010 05:12 PM Click Here to See the Profile for HTXtremesSend a Private Message to HTXtremesEdit/Delete MessageReply w/QuoteDirect Link to This Post
You need the book "High Performance Fieros" it has lots of weights of stock parts on fieros.
TopNotch
Total ratings: 60
Report this Post11-25-2010 05:55 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
Remove door guard beams, replace starter with a smaller gear-reduction type.
pmbrunelle
Total ratings: 63
Report this Post11-25-2010 05:58 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 3.4L aluminium block would be a good place to start.
RotrexFiero
Report this Post11-25-2010 06:16 PM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Use the search feature, since I remember this being covered.
It's a nice idea but feel that you are moving to a dedicated track car and may render your Fiero very uncomfortable.
sunofjustice
Report this Post11-25-2010 06:41 PM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Due to monthly payments to "uncle scam",and
midland funding llc....
the benefits of moving to a cheaper apt. is moot.
Thus said, I had to cut corners and ditch the full
aluminum decklids, plus wing concept.
Thanks to a previous member (sorry, dont remember
who.....but I thankyou for the idea)I decided to gut the front,rear decklids to remove weight.
before continuing, I should give a list of what is CURRENTLY
removed/ and or replaced.
Headlights / headlight doors/motors related brackets/wires
(Bozo went through redlight, knocked front fascia off,
only one light could pop up so I nixed 'em )
Pop up lights are like air brakes anyway.
removed spare tire/ jack, front spare fiberglass tub,
front decklid prop rod, gutted front hood /pulled brackets/
hood hinges (replaced with lighter LOWES hinges)
A/C compressor/ brackets/ linesaccumalator, evaporator
HVAC case /motors/ blower fan/ relay/ duct work/
heatercore will be replaced with aluminum version.
Cruise control servos, cables,wires
\Emergancy brake handle/ cables/ (system liked to drag,
or lock up and not release when I had to go to work.)
Floor mats (heavy)/ inner door covers(heavy)/ armrests/
brackets underneath/ (replaced doorhandles with aluminum
flat bar stock)
Map pocket in main dash
pulled old worn out carpet / insulation
Radio / radio speakers/ wire/ antenna
Plans are to convert to ALL ipod system.
(total target weight 10 onces) speaker covers will be
deleted in front and rear.
Computer cover/ arm rest / shifter surround (all of it)/ radio surround/
(all of it, only kept the gauge pod. Which weighs a pound and some!)
Gutted skeleton, to make room for a USABLE ,lightweight storage
compartment.
Will create entire dash out of foam,vinyl, and aluminum this spring.
Still havent replaced sun roof glass, and back window with polycarbonate yet.
Removed rear window defrost switch/ decklid switch/ decklid solinoid/
and wire harness.
Gutted rear decklid (underneath), stratigically removed "panels"
from the area above the tail lights, and BEHIND tailights/ will remove steel
louvers on both decklids and replace with aluminum flat bar stock.
(already did the front, will post pics )
removed torque rod for deck lid (scary crap), brackets and bolts.
(Still have to create new rear hinges.) They are REALLY heavy.
Removed engine hoist brackets , secondary dog bone strut bracket
(the bar that hids behind the A/C bracket) PITA alert!
EGR /bracket (3 pounds!!!!!!)/egr line,
rear inner mud flaps (only drive the fiero in the dry only)
strategic wheelwell trimming.
Front and rear suspension has already been replaced with LIGHTER
RCC components. No stock pieces left. (front is adjustable coilover
rear has anti bump steer kit/ tubular a arm.
removed front rear bumper nomenclature (15 pounds each)
replaced with aluminum bar stock.
removed upper radiator support with aluminum brackets.
No cat, just glass pack and 5" dual megs. Hate to do it,
but i need to make those out of aluminum or get something else
Was going to get a ducktail since no one makes a wing that
looks EXACTLY like ours but with LESS weight.
Not sure which ducktail to get yet, and since money is tight.....
I gutted the underside of the wing to lose some pounds.
Only got three pounds off.....heres a sneak peek.
During this process, the spoiler ultimalely got lowered,
and positioned further back by three inchs.
Used some 1" aluminum bars to mount the hollowed out spoiler, and
added aluminum sheet (1/6th gauge) to fill in the holes.
sunofjustice
Report this Post11-25-2010 07:02 PM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
sunofjustice
Member since Jun 2009
BTW,
thank you for your input everyone.....
I am definently going to a lighter starter eventually.
Especially if my current one goes south. Knock on wood.
When spring comes, hopefully the fiero will
get a 15 pound dry cell battery, (versus 40pds)
I read somewhere the optima brand was better
than the "bat", since its supposed to be a rebadged
version of an optima anyway.
The fiero is on drive when weathers willing status,
just trying to protect the investment as long as possible.
Please bear with me on the pix,
I just got the PIP working today,just a bit rusty using it.
Again, thank you for you input.
One question, anyone use mars resistant poly carb for windows yet???
If so, please post a pic here. They have alot of COLOR choices.
Some even look stock.
Hockaday
Report this Post11-25-2010 07:41 PM Click Here to See the Profile for HockadaySend a Private Message to HockadayEdit/Delete MessageReply w/QuoteDirect Link to This Post
biggest thing i can think of is redoing all the body panels in aluminum or CF
Chris Hodson
Total ratings: 54
Report this Post11-25-2010 08:16 PM Click Here to See the Profile for Chris HodsonSend a Private Message to Chris HodsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Take the panels off You dont need them to be legal lol.
nitroheadz28
Total ratings: 94
Report this Post11-25-2010 08:27 PM Click Here to See the Profile for nitroheadz28Send a Private Message to nitroheadz28Edit/Delete MessageReply w/QuoteDirect Link to This Post
They are already plastic.. Doesn't that seem unnecessary? I'd understand if they were steel of course.
86FieroSEv6
Report this Post11-25-2010 09:03 PM Click Here to See the Profile for 86FieroSEv6Send a Private Message to 86FieroSEv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Can you shed any weight from the tire/wheel package?
Chris Hodson
Total ratings: 54
Report this Post11-26-2010 12:33 AM Click Here to See the Profile for Chris HodsonSend a Private Message to Chris HodsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Take the inner lenses out of the tail lights and use red bulbs
Cut off old side marker bulb holders and hot glue some LED's in.
Drill out metal rivets used for some body panels and use plastic ones.
Install a shorter shifter.
Take out all the lost change in the shifter console.
ghost187x
Report this Post11-26-2010 12:34 AM Click Here to See the Profile for ghost187xSend a Private Message to ghost187xEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bridgetown
Report this Post11-26-2010 12:48 AM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll be watching this. I have done some weight shedding on my project as well. I would like to see how yours comes in when you weigh it. Couple items I can think of that you haven't mentioned.
- F/R crash bars are steel, could be replaced with Aluminum stock, or removed for track use.
- Side mirrors are quite heavy, I plan to use F1 style carbon fiber mirrors
- Your '86 will have a trunk fan, motor and ducts can be removed.
- Front steering damper can be removed, I didn't even notice mine was gone!
- Seats are another area there is extra weight. Got my Sparcos for $400 used
- Don't know if you are a fan of notchies or not, but the tail section weighs less then the fastbacks.
- I replaced my rubber pedal covers with grip tape.
One thing I have noticed is that it is slightly easyier to find ways to lose weight off the front end of the car, opposed to the rear. Keep your weight distribution in mind while you shed pounds. Not doing so could upset the handling. One easy way to balance out the f/r weight is to move the battery to the front.
[This message has been edited by Bridgetown (edited 11-26-2010).]
joshh44
Report this Post11-26-2010 12:53 AM Click Here to See the Profile for joshh44Send a Private Message to joshh44Edit/Delete MessageReply w/QuoteDirect Link to This Post
i heard the door beams are quite heavy. but i would keep them on for safty reasons.
you could replace the glass with lexan. you could get a lightweight flywheel. should help save weight and also less spinning mass on the engine. that should gain alittle power.
get a lightweight battery.
edited*
[This message has been edited by joshh44 (edited 11-26-2010).]
armos
Report this Post11-26-2010 02:00 AM Click Here to See the Profile for armosSend a Private Message to armosEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wouldn't do that. The lining on one of my rear wheelwells was ripped and left off by a previous owner - I found the pieces in the trunk.
Result: that side has numerous small rust spots due to rock chips in the painted frame.
Chris Hodson
Total ratings: 54
Report this Post11-26-2010 02:00 AM Click Here to See the Profile for Chris HodsonSend a Private Message to Chris HodsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
CHOP TOP with lexan windows
FFIEROFRED
Report this Post11-26-2010 07:40 AM Click Here to See the Profile for FFIEROFREDSend a Private Message to FFIEROFREDEdit/Delete MessageReply w/QuoteDirect Link to This Post
get rid of that cast iron 2.8. ecotec is alum block/head and more power. use it with a alum flywheel. the factory put a lot of work in to making it light. It would not be MY 1st pick for a engine, but if i was going to build a very light autocross car that would be the way to go. Your car sounds like it would be a fun car at a autocross.
DLCLK87GT
Report this Post11-26-2010 09:51 AM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by sunofjustice:
headlight doors
front spare fiberglass tub.
No expert but i would think that removing these items would actually hurt performance, not increase it. These items are already very light, and the weight shed by taking them off can’t be more than a few pounds, lets just say you shed 8lbs. I would think those freed up ponies that you’ll get by removing the 8lbs would be canceled out by the new openings created now causing additional drag….possibly loosing more HP than you created by shedding the weight. Just thinking out loud with my $.02
How about removing the glass and replacing with lexan? at least the door glass and all parts and pieces then just have the lexan fixed closed.
edit to say Lexan already suggested
[This message has been edited by DLCLK87GT (edited 11-26-2010).]
DLCLK87GT
Report this Post11-26-2010 09:53 AM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
DLCLK87GT
Member since Feb 2009
oops
sunofjustice
Report this Post11-26-2010 09:58 AM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for the positive feedback, mates!
(I dont feel alone in my "madness")
86 fiero sev6,
the rims are 16" aluminum craggar SS.
Tires are 16" 225 55 falkens
(hate 'em, damn drift style tire)
Road feel/ grip is LAME.
(Another reason for LIMITED driving duty)
Initially, I wanted WIDER tires on the rear (255 's 50 series).
But, the "motown diet plan" for the fiero dictates LESS is more.
Wider tires would ADD more weight.
sunofjustice
Report this Post11-26-2010 10:14 AM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
sunofjustice
Chris Hodson,
Already weighed the stock 86 gt tail lights
when gutting the rear bodywork.
(5pds per taillight assembly!)
Planning to mod them suckers when I
find some individual lights that are frugal,
light, and look good.
LED s ARE very light, brighter, and use less
energy. Still trying to get over the toy
"light bright" look when I see late model cars
with them. No offense.IMO
Already bought short shifter, I should look
for a billet aluminum and graft it in.
(If possible)
Oh, and I DID take out the change....2 pounds worth!
(Use to keep alot of quarters for carwashing)
dobey
Total ratings: 371
Report this Post11-26-2010 10:28 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
(If possible)
FieroStore sells an aluminum short shifter. I have it in my car. Works ok, but it's pretty bulky. Not sure what the exact weight is on it though. And when I do my LS4/F40 swap, I'll be making a custom short shifter out of carbon fiber anyway, and using a newer style shifting mechanism instead of the bulky 80s one.
sunofjustice
Report this Post11-26-2010 11:07 AM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ghost 187X,
mucho thanx for the reference.
Bridgetown,
Nice photo!
Already pulled BOTH "crash bars" (10pds each)
and BOTH "waffle" energy absorbers (5 pounds each).
Side markers, most of em got broken off from
idiots, and drunks hitting my ride.
I give praise to God for still being able to drive her!
The steering dampner (3 pounds), I took off two weeks ago.
Faster steering at LOW speed, alittle twitchy at HIGHER speeds.
Sorry, forgot to mention removal of trunk fan/ trunk tubes/
(threw away years ago dont know weight, anyone know?)
Theres a bracket welded in that held the fan, its a PITA
if you DONT have a garage with an electrical outlet.
Got it out though, (3.5 ounces)
Seats, I'm gonna make some from scratch.
Really, really want 6 pound seats (versus 38pds each).
I'm really looking to get them under 12 pounds MAX.
Materials will be aluminum bar stock (frame),
two grades of foam (one memory foam),
thought about using bungee cords like in a suspension seat.
But, those might add too much weight, and they COULD
cause body aches due to PRESSURE POINTS.
(I'm not a spring chicken like I used to be.)
The prices for seats annoy me, (handling frees)
you have to buy THEIR brackets to mount them
(could work,maybe not.)
I want to be able to monitor, weigh, and make
any adjustments on the "fly" instead of taking
what they give me.
The seat mounts will be perforated flat steel bars.
Seat will be fixed where I want it
(all the way back,slight incline)
Dont really store anything behind seats,
will make an aluminum rod linch pin
to tilt the seat if need be.
Took out BOTH seat recliner mechanisms
and added aluminum bracket to reinforce.
Works great! I dont fumble to move the seat at all.
Move it, set it back.
Was thinking of taking OFF stock gas pedal,
and replace with aluminum after market pedal cover.
Add some aluminum for backing, and add a mount
to bolt it on.
To bad the original clutch levers had BENDING problems.
Bridgetown,
I feel you on that weight bias concern.
Very concerned when I was removimg stuff,
Most of the weight WAS from the front,
or from the interior.
Will eventually move battery to front,
its just I use hood pin locks up front.
Plus, battery cables arent that light either.
Would be nice to place battery in interior.
A $700. five pound battery MIGHT fit,
but that idea is not feasible.
Regardless, I appreciate your input!
sunofjustice
Report this Post11-26-2010 11:19 AM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
sunofjustice
Dobey,
Sounds good.
Will have to check that sucker out.
Joshh 44,
I plan to do the doors next year.
Just hiesitant of how much to take off
just to get to them! Yikes.
Plus, I'll probably need MORE cordless
drill batteries.
14 volt or higher. (Apartment handicap)
Ffierofred,
Engines still NEW.
Aluminum heads would help.
On another site some suggested SHAVING
UNUSED bolt bosses.
Interesting, but I dont want to hit "water".
Will have to pass on that one.
sunofjustice
Report this Post11-26-2010 11:29 AM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
sunofjustice
Have to go to work soon,
LONG shift.
Will post pix soon.
Sorry,
had to FIND lost disc, plus organize shots.
Fieroseverywhere
Total ratings: 89
Report this Post11-26-2010 11:34 AM Click Here to See the Profile for FieroseverywhereSend a Private Message to FieroseverywhereEdit/Delete MessageReply w/QuoteDirect Link to This Post
Before you go making your own seats check out these...
http://www.summitracing.com...-Seats/?autoview=SKU
For less then $150 (including shipping, ect) you could swap in a pair of these plastic racing seats. I'm not sure the exact weight but it is quite significant over the stock seats. Give summit a call and they will toss them on a scale for you if you ask. Just toss on a set of cheap seat covers and your down 50+ lbs. Just a thought...
And of course, often the most significant loss is always with the driver. Shed a few pounds off yourself and the car loses also. Cost = just your hard work.
EDIT: Oh almost forgot. Try to focus on unsprung weight. Wheels and brakes mostly (since you already have tubular suspension). Unsprung weight is equal to more then 10hp per 100lbs. Check out gramlites, Motegi track lites, ect. Stick with a wheel size only large enough to clear the brakes. Light weight alluminum calipers also shave more then you might expect. Smaller diameter tires can shed weight and make the wheels sprin faster/easier. Just keep track of what change this makes to your overall final ratio. Don't want to lose too much top end...
[This message has been edited by Fieroseverywhere (edited 11-26-2010).]
Hockaday
Report this Post11-26-2010 12:35 PM Click Here to See the Profile for HockadaySend a Private Message to HockadayEdit/Delete MessageReply w/QuoteDirect Link to This Post
fiberglass is heavy, its why its not used on high end cars as far as I know. It's all aluminum and CF.
dobey
Total ratings: 371
Report this Post11-26-2010 01:28 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
CF is pretty heavy. And simply remolding exact copies of stock panels in CF won't really net you much weight loss. Other composites maybe, but certainly not aluminum and probably not CF. And the stock panels aren't fiberglass anyway.
Tha Driver
Total ratings: 204
Report this Post11-26-2010 02:12 PM Click Here to See the Profile for Tha DriverClick Here to visit Tha Driver's HomePageSend a Private Message to Tha DriverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fiberglass & carbon fiber are NOT heavy - when done right. CF is THE thing to use on anything to save weight; what do you think Formula One cars are made of?
The reason fiberglass aftermarket kit cars (& parts) are so heavy, is they are laid up with chopper guns & have to be made REALLY thick for strength. A hand-laid part is just as strong at < half the thickness, & very light.
I'm thinking of making hoods & decklids in 'glass to save weight (& to sell). The front hood with my "Angel Vent" (& also a new version that you don't have to cut the sheetmetal), & the decklid with a hood scoop I'm working on as we speak. (or type ;-) But they won't be cheap, & shipping will be problematic at best (probably need to use Greyhound).
Of course, replacing the PLASTIC panels with fiberglass will not really save weight. Plastic is about as light as you can get, UNLESS you make very thin "race only" 'glass or CF parts to replace them.
EDIT: The stock hood, decklid, & roof pieces ARE SMC fiberglass.
~ Paul
aka "Tha Driver"
What would you be if you were attached to another object by an inclined plane wrapped helically around an axis?
Screwed.
[This message has been edited by Tha Driver (edited 11-26-2010).]
FFIEROFRED
Report this Post11-26-2010 02:47 PM Click Here to See the Profile for FFIEROFREDSend a Private Message to FFIEROFREDEdit/Delete MessageReply w/QuoteDirect Link to This Post
leave the drivers side door beam in it. **** happens, make sure it happens to the door, not you.
for the record, my 84 se sbc/4t60 fiero, on 15 inch gt wheels, big archie 4 core rad, bat in front, GA rear brakes, nothing removed is as follows;
on race track 4 corner scales
LF =608
RF=646
LR=871
RR=862
totals, F=1254,(42%) R=1733 (58%)
car=2988 !
It hooks up!
Brastic
Report this Post11-26-2010 03:58 PM Click Here to See the Profile for BrasticClick Here to visit Brastic's HomePageSend a Private Message to BrasticEdit/Delete MessageReply w/QuoteDirect Link to This Post
~ Paul
aka "Tha Driver"
Screwed.
I cannot agree more. Lately, I have been making more fiberglass parts than CF. The weight difference between them is not much and fiberglass is a lot easier to make. I cannot see replacing the plastic body panels making any real difference. The only two body panels that I would change would be the deck lid and hood. I would use a foam core composite. I would not remove anything from the door unless I replace the door all together. You can make a steel or aluminum door that would save weight and could be close in the crash protection.
I would also ditch the dash and heat exchanger box. All that you really need is the piece of metal to hold the instrument cluster.
I am also confused by you getting heavier wheels. I would focus on the unsprung weight first and then start looking around.
dobey
Total ratings: 371
Report this Post11-26-2010 04:18 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's all relative. F1 car bodies are made from CF because it's relatively cheap, lighter than fiberglass or aluminum, and there's no kitty hair involved. Not because it is the lightest material available. Granted, with what they weigh, and given their aerodynamics and power, going any lighter than CF isn't really necessary. There are lighter materials out there, but they are cost prohibitve for most things.
If one really wanted to lose a lot of weight on the Fiero, the body isn't really the best place to look. The quickest way to lose 300 lbs on a Fiero is to get a custom built aluminum frame and cradle built. Replace as many cast iron or heavier steel parts with aluminum or composites as appropriate. Convert to coil-overs. Tubular A arms. Until you start worrying about aerodynamics, the body isn't a great place to look for improving performance.
normsf
Total ratings: 57
Report this Post11-26-2010 04:41 PM Click Here to See the Profile for normsfClick Here to visit normsf's HomePageSend a Private Message to normsfEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello yes what you said is mostly correct, you can still start with the body and improve areodynamics at the same time. Here we remove some sheet metal and the front clip our tilt clip weighs about the same as the stock hood alone while overall removing almost 100Lbs Thanks Norm
sunofjustice
Report this Post11-26-2010 05:02 PM Click Here to See the Profile for sunofjusticeSend a Private Message to sunofjusticeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got an hour break from work,
so I'm gonna try and throw some
pix at ya..........
Heres when i was cleaning up some rust holes,
"natures weight reduction".
Carpet is gone!
Will probably install aluminum sheet (thin gauge)
to smooth out the "humps and lumps".
That grip tape might work, just concerned how it will look though.
Currently using smallest floor mat available (1pd each).
Have to go back to work soon, glad I got some more up.
Will post ALOT more interesting pix later.
Thanks for waiting!
dobey
Total ratings: 371
Report this Post11-26-2010 06:49 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sure, but that is not strictly body modification. You cut out a big portion of the chassis. And I'm not sure those sections of the front of the chassis are pieces I'd want removed.
pmbrunelle
Total ratings: 63
Report this Post11-26-2010 08:07 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Way to hack a car.
Good luck with crash safety.
normsf
Total ratings: 57
Report this Post11-26-2010 08:23 PM Click Here to See the Profile for normsfClick Here to visit normsf's HomePageSend a Private Message to normsfEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello you havent seen too many other body conversions then and what bothers you about the frontal crash protection. There is no structual compromise as all that is cut away is underneath the headlight assemblies which hardly offers any protection even the spare tire is in the stock position which provides the bulk of energy absorbtion. The front bumper facia is removed, but that provides little if any protection while the metal reinforcement is left in place. Thanks Norm
Same car after repair and new front clip
[This message has been edited by normsf (edited 11-26-2010).]
nitroheadz28
Total ratings: 94
Report this Post11-26-2010 08:38 PM Click Here to See the Profile for nitroheadz28Send a Private Message to nitroheadz28Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just curious... But how the hell did you guys manage to straighten that front end out so nicely? Wow... My busted fender seems like nothing.
