  The Turbo 3500 F23 swap (Page 2)
This topic is 20 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20
The Turbo 3500 F23 swap by ericjon262
Started on: 10-03-2011 11:26 PM
Replies: 788 (30872 views)
Last post by: ericjon262 on 02-26-2025 05:33 PM
ericjon262
Total ratings: 67
Report this Post06-30-2012 11:43 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by ericjon262 (edited 03-31-2020).]
ericjon262
Total ratings: 67
Report this Post07-03-2012 08:44 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post07-06-2012 06:31 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post07-08-2012 11:16 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
carbon
Total ratings: 132
Report this Post07-11-2012 12:10 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Aww... don't say that.. I follow your threads..
stickboy
Report this Post07-11-2012 12:38 PM Click Here to See the Profile for stickboySend a Private Message to stickboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm reading the thread too
ericjon262
Total ratings: 67
Report this Post07-23-2012 01:09 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post08-03-2012 08:01 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post08-04-2012 03:06 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post08-04-2012 03:08 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Member since Jan 2010
ericjon262
Total ratings: 67
Report this Post08-05-2012 02:01 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fieromotion
Report this Post08-05-2012 03:19 PM Click Here to See the Profile for FieromotionSend a Private Message to FieromotionEdit/Delete MessageReply w/QuoteDirect Link to This Post
Doing the same transmission swap and I´m interested in you clutch. What make is it?
ericjon262
Total ratings: 67
Report this Post08-05-2012 03:49 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post08-05-2012 10:37 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
ericjon262
Total ratings: 67
Report this Post08-10-2012 12:18 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
carbon
Total ratings: 132
Report this Post08-10-2012 09:42 AM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
So did your clutch fit and spin freely or is the tranny still just bolted to the engine with nothing inbetween?
ericjon262
Total ratings: 67
Report this Post08-10-2012 10:41 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post08-12-2012 05:17 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post08-17-2012 12:05 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
Joseph Upson
Total ratings: 88
Report this Post08-17-2012 05:14 AM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by ericjon262:
I'm working on a set of better lifters for the 60*, so I took 3 lifters apart today,
1 3400 lifter
1 "LS7" lifter
and
1 Comp Magnum SBC Lifter.
The Comp and the LS7 were nearly identical. I also found that if you machined the piston on the V8 lifters down a little bit, you could install them in the 60* and turn them into solid lifters.
Pics tomorrow
What's purportedly wrong with the stock roller lifters? Joshua tried the lifter modification provided by the 60 degree V6 store and had trouble with it. You may want to check with him about it.
ericjon262
Total ratings: 67
Report this Post08-17-2012 04:27 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
Joseph Upson
Total ratings: 88
Report this Post08-17-2012 05:30 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
to say the spring in the stock lifters are weak would be an understatement, retro-fitting the LS7 springs should allow me to get close to 7000 RPMs, without any issues.
I believe It's going to take a bit more than that to make it safe and solid for the 3500 to do 7k rpm routinely. Superdave on 60 degree took out rod bearings at least twice in his 3500 from what I recall and according to their lit.., GM did an enormous amount of work in flow, weight reduction and part strength from what I read to get the LS7 to do 7000 rpm. Keep in mind an LS7 lifter has to do more work weight and ratio wise (1.8:1) rockers than the 3500 lifters relatively speaking.
Just be sure you investigate this thoroughly as lifter spring strength also varies relative to the valve spring strength used not to mention how lifter pump up will affect/support the lifter spring. Just don't take any chances that can create problems is all I'm suggesting.
ericjon262
Total ratings: 67
Report this Post08-23-2012 10:44 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post08-29-2012 10:16 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
BV MotorSports
Total ratings: 189
Report this Post08-29-2012 11:53 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good luck with yoru build man! I love to see turbo Fieros! Since you are in Pcola, do you ever go to the swamp meet @ the Boardwalk in Oakaloosa? Maybe we could have a little run, eh?
blander66
Report this Post08-30-2012 09:14 AM Click Here to See the Profile for blander66Send a Private Message to blander66Edit/Delete MessageReply w/QuoteDirect Link to This Post
well guys, not much to report, I've been making a diligent effort to get the wiring sorted out. I'm also waiting on parts... I did get the injectors installed, along with the 3400 fuel rail/regulator. I've also found a location for the ECM, but I'll need to make a splash guard for it. I also destroyed my lifters that I was going to modify in an attempt to clean them. so it looks as though the real deal will be on my 3500's lifters.
Where are you going to mount your ECM? Thats one of the few things I still have to do on my 3400 swap
ericjon262
Total ratings: 67
Report this Post08-30-2012 12:25 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
KurtAKX
Total ratings: 128
Report this Post08-31-2012 12:20 AM Click Here to See the Profile for KurtAKXSend a Private Message to KurtAKXEdit/Delete MessageReply w/QuoteDirect Link to This Post
You may have covered this already, but what are you doing to make up for the fact that you are turning your power steering pump backwards?
ericjon262
Total ratings: 67
Report this Post08-31-2012 01:29 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
it's a standard rotation pump, with a reverse rotation pulley.
ericjon262
Total ratings: 67
Report this Post09-02-2012 01:28 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post09-02-2012 11:00 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Fieromotion
Report this Post09-06-2012 04:15 AM Click Here to See the Profile for FieromotionSend a Private Message to FieromotionEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice job.
Fieromotion
Report this Post09-06-2012 04:47 AM Click Here to See the Profile for FieromotionSend a Private Message to FieromotionEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fieromotion
Member since Apr 2012
Forgot to ask you about the clutch. You have a Centerforce dual friction clutch. Is it for Cavalier or something else? Did you have any clearance issues? I´m doing F23 and 3,4 DOHC swap and used Ram HD clutch for Fiero and had clearance issue which solved by taking a slight amount off from the transmission and three corners of the clutch. Planning also to add about 1 mm aluminum between the trans and engine. There is no touch at the moment but on operating temperature it could toch and this 1 mm could avoid it.
Do you still have the Thelin rear trans mount. I´m willing to buy it from you.
Keep on the good work and let us know the results.
ericjon262
Total ratings: 67
Report this Post09-06-2012 12:39 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post09-09-2012 10:03 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post09-11-2012 11:28 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post09-13-2012 11:25 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post09-13-2012 11:35 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
ericjon262
Total ratings: 67
Report this Post09-16-2012 12:22 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post09-18-2012 01:54 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
