  The Turbo 3500 F23 swap (Page 3)
This topic is 20 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20
The Turbo 3500 F23 swap by ericjon262
Started on: 10-03-2011 11:26 PM
Replies: 788 (30872 views)
Last post by: ericjon262 on 02-26-2025 05:33 PM
ericjon262
Total ratings: 67
Report this Post09-19-2012 01:24 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by ericjon262 (edited 09-11-2022).]
Joseph Upson
Total ratings: 88
Report this Post09-19-2012 08:11 AM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by ericjon262:
rebuilt my shifter today, but I have a new problem. Rodney's shift cables have the ball stud already pressed in, and it doesn't look as though it is easily removed without destroying the cable end, and the F23's ball is welded to the link... time for more welding, and re working... it'll let me kill two birds with one stone though, because the bracket holding my select cable in was too close to the ball, and made it hard to get into fifth and reverse. I'll post pictures tomorrow of how I fix it.
I'd need to see a picture of what you're talking about for it to be clearer. I purchased my cables from The Fiero Store and they appeared to be just like Rodney's. I was pointing out at the time how nice they were because they were not only adjustable at the mount sleeve, they were also adjustable at the cup socket at the tranny end of the table. The OE cables are not adjustable at all except at the tranny.
Someone expressed desent about that ability in the cable suggesting it was inferior somehow, but when you're dealing with a custom application that characteristic is a plus.
There are two ball sizes at the Fiero tranny lever depending on what tranny you are using and from what I recall the Muncie 4 speed used both, one of each for the levers and the gate select on the Getrag the small cup which the F40 requires. I could be partly wrong about that but I know the cable with the end for the small cup comes in two different lengths and the one for the 5 spd is the longest.
ericjon262
Total ratings: 67
Report this Post09-19-2012 12:37 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post09-20-2012 12:49 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
shifter is pretty much done, DLC is wired in, and the car is sitting on 4 wheels for the first time in over a year...
BV MotorSports
Total ratings: 189
Report this Post09-20-2012 03:21 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Couldnt you order the F23 cables from California push pull? They are fully adjustable.
ericjon262
Total ratings: 67
Report this Post09-20-2012 03:35 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
gtxbullet
Report this Post09-20-2012 05:50 PM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
you sir, are my hero
keep the pics and updates coming.
I have a direct link to this thread on my desktop!!
ericjon262
Total ratings: 67
Report this Post09-21-2012 12:36 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post09-23-2012 02:13 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post09-26-2012 12:54 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
the harness is probably about 90% complete, I'd like to try to finish it tomorrow, but we'll see...
ericjon262
Total ratings: 67
Report this Post09-26-2012 11:29 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Member since Jan 2010
ericjon262
Total ratings: 67
Report this Post09-28-2012 12:42 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
carbon
Total ratings: 132
Report this Post09-28-2012 08:31 AM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
What's in the groove... is it staying?
ericjon262
Total ratings: 67
Report this Post09-28-2012 04:02 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post09-28-2012 07:42 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Joseph Upson
Total ratings: 88
Report this Post09-29-2012 07:02 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
well guys, I keep looking at the manifolds I have, and thinking about how they are a really poor match for my engines potential, and I've made the decision to continue onto making a custom set of headers. 1.5" 16ga mild steel, 3/8" flanges, and 3-1 collectors(1.5" in, 2.25 out) I'll probably reduce the 2.25 to 2.00 out of the collector for better velocity going into the turbo, but we'll see once I get come pipe in my hands.
Speaking from experience, keep it simple, a nice blended log design like fingers merging into a pipe is still good. if you're going to build headers with mild steel you better do 14 Ga and shield it as opposed to heat wrapping, I can promise you the mild steel will not hold up well to the heat if you wrap it. It'll last for a while but unless relief points are built in they will warp and flake under the wrap. Leaks are hard to find with the wrap and will result in intermittent poor, or sluggish performance intermittently making the problem hard to resolve. It's very discouraging to have very good performance one day and noticeably less the next with no idea as to why.
ericjon262
Total ratings: 67
Report this Post09-29-2012 07:56 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
Joseph Upson
Total ratings: 88
Report this Post09-29-2012 08:07 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
they will be built right, I'm going to design them/tack them together, and then have them professionally welded.
on a side note, do you know where I can get 14 ga mandrel bent tubing? 1.5" or 1.625"
http://www.stans-headers.com/parts.htm
You will not likely have a problem with the welds, it's just mild steel and it will see higher temps for a longer duration with a turbo and that will take its toll regardless of who welds it up. Cast iron can absorb more heat because of the increased wall thickness and as long as it is not wrapped you are less likely to have a problem with it. One source for turbo manifold building is weld elbows. Try McMaster Carr for those.
ericjon262
Total ratings: 67
Report this Post09-29-2012 08:11 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post09-29-2012 11:27 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Joseph Upson
Total ratings: 88
Report this Post09-30-2012 07:06 AM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ladies and gentlemen, with the exception of the grounds, maf /iat sensor connector, and final taping, the powertrain harness is complete!
Not until you spend another 45 min to an hour back probing the PCM plug pins against the sensor plug pins and grounds to make sure you didn't cross any by accident. Good job, can't wait to hear about the results when its up and running.
ericjon262
Total ratings: 67
Report this Post09-30-2012 12:51 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post10-07-2012 12:18 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
woo hoo! I'm getting a set of forged pistons and H beam rods for the car now! this should be good!
there's a Group on 60degreeV6.com for us 660 Fiero owners!
Fiero Owner's group on 60degreeV6.com
I know these lines Look crooked on paper, but I swear I've got them straight in my head.
ericjon262
Total ratings: 67
Report this Post10-12-2012 11:16 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post10-19-2012 08:47 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post10-26-2012 10:42 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post11-02-2012 11:14 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post11-03-2012 06:26 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post11-03-2012 08:16 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
BV MotorSports
Total ratings: 189
Report this Post11-03-2012 09:12 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking good! The swap, that is.
ericjon262
Total ratings: 67
Report this Post11-03-2012 09:40 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
BV MotorSports
Total ratings: 189
Report this Post11-04-2012 05:41 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks! I like putting the time into making it myself, I keep digging deeper holes for myself though... turbos cams, pistons....
LOL I am in the same boat with the 3.4TDC car. It was supposed to be an R&R, clutch and service. Now its MegaSquirt MS3, ING-6, All new wiring, battery relocation, exhaust, CAI, tune, suspension work etc etc.
ericjon262
Total ratings: 67
Report this Post11-04-2012 05:49 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post11-04-2012 10:59 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
ericjon262
Total ratings: 67
Report this Post11-10-2012 10:51 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
Joseph Upson
Total ratings: 88
Report this Post11-11-2012 07:12 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I never added the fan and don't feel there is a significant benefit to it considering it would only be effective when the car is stopped at a light. The water heats up so slowly during this time that long before the temp increase becomes significant you'll be moving again to cool it back down. In bumper to bumper traffic you can't go fast enough to need the benefit anyway. Without the intercooler at operating temps, the hot turbo added about 30 deg to the inlet temps and I recall cruise temps in the 130s during the Summer. The intercooler kept temps below 100. usually at about 10 deg above ambient and if you have at least a 2 gal coolant capacity you'll have no problem maintaining that considering I'm still running ~1 gal.
The temp stability (I setup a history table for it in Tunerpro) is amazing. Since you don't have impedence from a GT bumper I'd expect your heat transfer to be a little better than mine.
ericjon262
Total ratings: 67
Report this Post11-16-2012 08:09 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post11-18-2012 12:14 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
Joseph Upson
Total ratings: 88
Report this Post11-18-2012 06:33 AM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's a nice tank. It's obvious it's going to get some ice at some point so here's something you should consider in place of a cooling fan on the exchanger, an electric heater bypass valve to help get the most out of an ice bath. You don't want ice cold coolant going through the heat exchanger and getting warmed up toward ambient temps.
ericjon262
Total ratings: 67
Report this Post11-18-2012 10:35 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
