  The Turbo 3500 F23 swap (Page 7)
This topic is 20 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20
The Turbo 3500 F23 swap by ericjon262
Started on: 10-03-2011 11:26 PM
Replies: 788 (30921 views)
Last post by: ericjon262 on 02-26-2025 05:33 PM
ericjon262
Total ratings: 67
Report this Post04-19-2013 10:47 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by ericjon262 (edited 09-11-2022).]
BV MotorSports
Total ratings: 189
Report this Post04-20-2013 01:06 AM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
All part of the fun.. one step forward, two steps back.
ericjon262
Total ratings: 67
Report this Post04-23-2013 12:00 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
Total ratings: 237
Report this Post04-23-2013 07:03 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by ericjon262:
not sure why, but every time I had made a harness, I had started at the sensors and worked my way to the PCM, it hit me as I was working on the harness last night, I'd be way better off doing the opposite. It's much easier to make 3-4 wires even and neat in one spot then it is to do 60+.
I work in bundles from each connection point to the PCM. If you put several neat bundles together, it should be minimal effort to keep the resulting trunk neat and tidy.
ericjon262
Total ratings: 67
Report this Post04-23-2013 08:25 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post04-23-2013 03:48 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Member since Jan 2010
ericjon262
Total ratings: 67
Report this Post04-23-2013 08:28 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
ericjon262
Total ratings: 67
Report this Post04-24-2013 06:42 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
BV MotorSports
Total ratings: 189
Report this Post04-24-2013 07:47 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Excellent. I am happy for you. You'll be doing that 1st start really soon. Ah, nothing like it in the world...
ericjon262
Total ratings: 67
Report this Post04-24-2013 09:30 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post04-24-2013 09:35 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
sleevePAPA
Report this Post04-24-2013 10:33 PM Click Here to See the Profile for sleevePAPASend a Private Message to sleevePAPAEdit/Delete MessageReply w/QuoteDirect Link to This Post
aerochamber, nice!
ericjon262
Total ratings: 67
Report this Post04-24-2013 11:02 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
sleevePAPA
Report this Post04-24-2013 11:27 PM Click Here to See the Profile for sleevePAPASend a Private Message to sleevePAPAEdit/Delete MessageReply w/QuoteDirect Link to This Post
yeah, I'm hoping it sounds as good as it looks...
well you have a turbo to quiet down the exhaust, assuming youre only running one tip?
heres what true duals sound like on a 3.4, with the aerochambers.
http://www.streetfire.net/v...4-blazer_2289596.htm
ericjon262
Total ratings: 67
Report this Post04-24-2013 11:30 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
carbon
Total ratings: 132
Report this Post04-26-2013 04:04 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know I'm a one trick pony, but did you ever get that clutch checked out?
ericjon262
Total ratings: 67
Report this Post04-26-2013 07:08 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post04-26-2013 10:07 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
ericjon262
Total ratings: 67
Report this Post04-28-2013 12:15 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post04-29-2013 02:41 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post04-30-2013 11:33 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post05-21-2013 03:07 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
carbon
Total ratings: 132
Report this Post05-21-2013 08:35 AM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did it over-extend or just plain defective? Why do you need a new clutch? Just because? Or did the hydraulic fluid contaminate the disc?
Sorry you ran out of time...
ericjon262
Total ratings: 67
Report this Post05-21-2013 09:50 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
fieroaddicted
Report this Post05-21-2013 05:23 PM Click Here to See the Profile for fieroaddictedSend a Private Message to fieroaddictedEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think it was just plain defective, I haven't had a chance to take it apart to look, but it never really even firmed up before I noticed the dripping, and I imagine if it was over extended, it would have gotten firm, and then "popped"
once I got the turbo build rolling I realized the centerforce would be stretched to it's limits, I tried selling it to fund a new one, but no-body would buy it, so I figured I'd run it and if it held it held, if not then I'll have to fix it.
the car will still get done, there will just be a 9ish week delay. hopefully I'll get a few days off after boot camp/before school that I can use to get this thing fixed.
Man that sucks bad. Sorry to hear that. I am hoping i don't end up with the same issue. I am trying to figure out where to get an HTOB spacer for mine. I heard that spec sells them, but i went on their web site and could not see anything.
troy
ericjon262
Total ratings: 67
Report this Post05-21-2013 08:15 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
carbon
Total ratings: 132
Report this Post05-22-2013 08:41 AM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tomorrow starts the real fun...
Good luck man! Much respect!
ericjon262
Total ratings: 67
Report this Post07-23-2013 04:05 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
topcat
Total ratings: 148
Report this Post07-24-2013 03:17 AM Click Here to See the Profile for topcatSend a Private Message to topcatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to Charleston! I'd love to see the work you've done on this swap. I hope you can get it shipped.
ericjon262
Total ratings: 67
Report this Post07-24-2013 03:56 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post10-06-2013 02:56 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
zkhennings
Report this Post02-04-2014 12:14 PM Click Here to See the Profile for zkhenningsSend a Private Message to zkhenningsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any recent progress?
ericjon262
Total ratings: 67
Report this Post02-04-2014 04:34 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post06-20-2014 02:34 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
KaijuSenso
Report this Post06-20-2014 06:27 PM Click Here to See the Profile for KaijuSensoSend a Private Message to KaijuSensoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking forward to see you continue this project. Now that mine is running again, I need more persuasion to tear it down again for a turbo build.
ericjon262
Total ratings: 67
Report this Post06-20-2014 11:48 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post06-27-2014 04:17 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
well, I placed the order(acknowledged by a Spec employee via email) for my clutch 4 days ago, thinking that by now it would have left Spec and be on it's way to me,
this was 3 days ago...
They ship in 24-48 hrs..this is a busy week given we are closed all next week. If not today, probably leaves tomorrow…
seeing as I hadn't heard anything from Spec, I called them up, and they don't have anything in their system on my order at all... now how is a order supposed to ship if it doesn't exist??? Guess who just lost a $600 sale.
so now, instead of a Spec, I'll be going with a Bully stage 4 Clutch. hopefully this order works out better...
fieroaddicted
Report this Post06-27-2014 07:00 PM Click Here to See the Profile for fieroaddictedSend a Private Message to fieroaddictedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did ya ever manage to get a spacer from spec? I am going to make my own on the lathe tomorrow and see how it turns out. If i am not happy with it, I will be ordering a spacer from them myself. After a couple emails to them, someone finally got back to me with a part # and price! Part number N1774-.250 . $49.
ericjon262
Total ratings: 67
Report this Post06-27-2014 07:22 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post07-14-2014 04:17 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
