  Tapered roller bearing 88 front wheel bearings project (Page 7)
Tapered roller bearing 88 front wheel bearings project by Rodney
Started on: 12-02-2011 09:26 AM
Replies: 246 (12578 views)
Last post by: 0z on 01-28-2019 09:56 PM
Rodney
Total ratings: 267
Report this Post05-20-2015 05:53 AM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Adding the gear oil seems to be working well. I have a set on a 88 that a guy auto crosses, road races etc. He made some clamp things to keep the covers on as they will loosen when used on track cars. He also installed vents on the covers so the internal air pressure remains neutral. He has seen no wear or any mechanical problems. I have been adding this Mobil One gear oil to every hub I have been selling and sealing the cover on with Locktite bearing retainer. The seal inside is made to keep things out, not keep oil in. So over time there may be a slight amount of this oil that may push past the seal from internal pressure when the hub gets warm when driving. With normal driving that should be a very small amount. In time I will see if that is too much and if it is I'll look to install some type of vent on them.
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
pokeyfiero
Total ratings: 309
Report this Post01-28-2016 11:23 PM Click Here to See the Profile for pokeyfieroClick Here to visit pokeyfiero's HomePageSend a Private Message to pokeyfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rodney , I couldn't find them on your site.
The Restored GT I sold My friend is in need and I have a few OE hubs in crates I thought he would be better off with the new ones he makes.
It will never see a track so I'm sure they will last his lifetime.
Can you direct me?
0z
Report this Post01-26-2019 12:08 AM Click Here to See the Profile for 0zSend a Private Message to 0zEdit/Delete MessageReply w/QuoteDirect Link to This Post
Resurrected from the dead.
So, all of these years later, how are these bearings holding up?
PO says he installed 1st Gen Rodney Dickman bearings in 2016, 1,500 miles ago. The right one is growling.
I have a set of Chinese bearing and a set of the original OE bearing. I could just use those, or...
I can get these
http://rodneydickman.com/ca....php?products_id=427
[This message has been edited by 0z (edited 01-26-2019).]
Total ratings: 328
Report this Post01-28-2019 04:18 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
[/b]
[B]Originally posted by 0z:
I can get these
Rodney may no longer be selling the 88 front hubs. One guy had an incident with them where the shaft snapped while racing. Then Rodney put a caveat on the parts saying "not for racing use". To avoid possible litigation the hubs may no longer be available but that's up to Mr Dickman..
msweldon
Report this Post01-28-2019 05:24 PM Click Here to See the Profile for msweldonSend a Private Message to msweldonEdit/Delete MessageReply w/QuoteDirect Link to This Post
There's still hope.... I've been working with a racing vendor who had two former PFF members work with them to create a spindle/hub setup and then dropped it. I picked it back up with the vendor, worked out the remaining dimensions, volunteered to be a guinea pig, and have a set installed on an 88 crossmember waiting to go in. My fiero is currently getting some body work done so I have zero test time with them although the design provided was pulled from their similar Corvette and Camaro solutions with many many race miles put on them. I've been asked by the Vendor to test them out first before they allow begin selling.
The only downside to these thus far is that the spindle snout is quite long and robust and the hub snout will "not" fit stock rims. I had to hog out about 2mm from the lip that holds the wheel cap in place within the pilot bore on my front aftermarket wheels.
[This message has been edited by msweldon (edited 01-28-2019).]
fierogt28
Report this Post01-28-2019 07:52 PM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
[b][/b] Rodney may no longer be selling the 88 front hubs. One guy had an incident with them where the shaft snapped while racing. Then Rodney put a caveat on the parts saying "not for racing use". To avoid possible litigation the hubs may no longer be available but that's up to Mr Dickman..
PM sent...
0z
Report this Post01-28-2019 09:56 PM Click Here to See the Profile for 0zSend a Private Message to 0zEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like he is still selling hubs.
