Thread Closed  Topic Closed
  Audi A8 My Fiero (Page 3)
Post New Topic
Printable Version
This topic is 52 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52
Audi A8 My Fiero by engine man
Started on: 06-10-2012 12:09 PM
Replies: 2041 (94738 views)
Last post by: engine man on 08-27-2019 09:51 AM
Total ratings: 236
Report this Post07-30-2012 03:39 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's easier to unplug the harness from the ECM and pull it through the firewall than it is to unplug it from everything on the engine.
Also not necessary to remove the intake manifold to remove the engine.
engine man
Report this Post07-30-2012 04:13 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
i was trying to sell the intake thats why i took it off, the harness would have been easier to do like you said but the engine is out now
engine man
Report this Post07-31-2012 12:11 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
Let me say one thing YOU CAN NEVER USE TO MUCH NEVER SEEZ gosh dam it it would have been better if he never took it apart and put the red Polly bushings in the back i think he use salt water to put it back together
[This message has been edited by engine man (edited 07-31-2012).]
Total ratings: 236
Report this Post07-31-2012 02:06 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
I find it amusing that I use anti-seize when reassembling things that GM assembled with Loctite.
FieroWannaBe
Report this Post07-31-2012 02:41 PM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
From my experience, especially in WI, even loctite allows for the possiblity joint seperation, but the use of penetrating oil usually leaves the joint so dry after evaperation they joint just rusts together. Especially when reusing bolts, as subsequent uses slowly remove the zinc plating.
engine man
Report this Post07-31-2012 08:10 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
well i can start doing some work to put the Audi on the cradle tomorrow but need to work on the house also so do a Little hear and a Little there
engine man
Report this Post08-02-2012 07:18 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
I dint get as much done as i wanted but this is the position on the cradle as far as front to back and it shows the angle of my axles i could go more if i want to cut the fire wall . i still need to work on the back cross member so the transmission sits right
[This message has been edited by engine man (edited 08-02-2012).]
seajai
Total ratings: 51
Report this Post08-03-2012 09:40 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is the measurement from the transmission bell housing to the center-line of the axle? Curious to see if it matched the 7.87" you had found in your previous thread https://www.fiero.nl/forum/Forum2/HTML/122938.html . How far back from the wheel center-line is the axle center-line?
[This message has been edited by seajai (edited 08-03-2012).]
motoracer838
Total ratings: 83
Report this Post08-03-2012 09:53 AM Click Here to See the Profile for motoracer838Send a Private Message to motoracer838Edit/Delete MessageReply w/QuoteDirect Link to This Post
Starting near the bottom of page one, see how I dealt with modifying the cradle to get the transaxle down where it needed to be and solve a matinence problem. tour axle angle looks very much where I wound up.
https://www.fiero.nl/forum/Forum1/HTML/086876.html
Cheers Beers n Gearz. Joe
engine man
Report this Post08-03-2012 11:33 AM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
if i remember correctly the axle centerline to bellhousing face is about 6.75 on the 012 transmission and 7.87 on the 016 i have the 012 transmission seajai. thanks for the help motoracer838
engine man
Report this Post08-04-2012 08:20 AM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
034 motorsports flywheel insert and a F1 ceramic clutch disk no springs
engine man
Report this Post08-05-2012 10:10 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has any one used these VEMS ecu it seems all the audi guys use them http://www.vems.us/
engine man
Report this Post08-07-2012 03:08 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
just posting a picture of a newer Audi A4 transmission i would love to have it has the axle moved forward a whole bunch as you can see i found this one on the UK ebay it is a 6 speed standard
[This message has been edited by engine man (edited 08-07-2012).]
FieroWannaBe
Report this Post08-07-2012 03:53 PM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
What year audi was this transaxle from?
northeastfiero
Report this Post08-07-2012 05:06 PM Click Here to See the Profile for northeastfieroSend a Private Message to northeastfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is from an A4 A5 2.0 Tdi around the 150bhp mark.
engine man
Report this Post08-07-2012 07:25 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
diesel right so higher torque
engine man
Report this Post08-07-2012 07:38 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
engine man
Member since Mar 2006
well i just went and looked it up and that engine makes like 280 FT lbs of torque so i would think the transmission would be rated some where in the 300 ft lbs torque range but i will try to find that info to i think they are Getrag transmissions
CowsPatoot
Total ratings: 84
Report this Post08-08-2012 02:07 AM Click Here to See the Profile for CowsPatootClick Here to visit CowsPatoot's HomePageSend a Private Message to CowsPatootEdit/Delete MessageReply w/QuoteDirect Link to This Post
My first thought was that if it was made for a diesel engine, it might be geared a bit low for the engine you are using...but after research, the ratios are:
Final: 3.693
1st: 3.778
2nd: 2.050
3rd: 1.321
4th: 0.970
5th: 0.757
6th: 0.625
Outside of 4th gear being a tad quicker, those are almost identical to the 2006 F40...but with a 3.693 final rather than the F40's 3.55. The only other question is...what rpm is that transmission rated to spin to? Although you can probably get away with over-revving the tranny some, the engine it came with gets it's peak power at 4200rpm as opposed to your engine's 6500rpm.
Reallybig
Report this Post08-08-2012 03:58 AM Click Here to See the Profile for ReallybigSend a Private Message to ReallybigEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does your engine have the same bellhousing bolt pattern as the newer transmission?
FieroWannaBe
Report this Post08-08-2012 09:10 AM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is the clutch and differential layout as well? the differential look to be right where the clutch would normally be.
engine man
Report this Post08-08-2012 01:05 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
ya from what i could see the clutch is the problem looks like it takes some special stuff so to make it work like a small triple disk and i think it would cost so much $$$$ it wouldn't be worth it . the gearing would not be to bad since the engine stock red line is 6600 rpm and they bump that up to 7000 rpm but if i had the R8 engine it has a red line of like 8200 rpm
[This message has been edited by engine man (edited 08-08-2012).]
FieroWannaBe
Report this Post08-08-2012 01:29 PM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
With the R8 engine your looking at a "Lambourghini" AWD Transaxle, and a drivetrain value that exceeds almost any Fiero's value.
But I do wonder if the latest manual transaxle there is a dual clutch unit.
engine man
Report this Post08-09-2012 07:25 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well just gotta add 1 more pipe and finish welding and make it look prettier
ericjon262
Report this Post08-10-2012 01:01 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
whoa!? you're actually building this?
engine man
Report this Post08-10-2012 02:06 AM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes i felt it was worth doing
[This message has been edited by engine man (edited 08-10-2012).]
gmctyphoon1992
Report this Post08-10-2012 02:17 AM Click Here to See the Profile for gmctyphoon1992Send a Private Message to gmctyphoon1992Edit/Delete MessageReply w/QuoteDirect Link to This Post
Im looking forward to hear this run..probably sounds great
Austrian Import
Report this Post08-10-2012 02:20 AM Click Here to See the Profile for Austrian ImportSend a Private Message to Austrian ImportEdit/Delete MessageReply w/QuoteDirect Link to This Post
This should help with inspiration:
Here's the whole crazy long thread: 4.2l Audi V8 6speed in a Lotus Esprit
I hope this thread, as well as contacting the builder will help you complete your project.
engine man
Report this Post08-10-2012 05:52 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wanted to go work on the car but my back was killing me after work so i must wait till Monday when my buddy is open so i can finish welding it all up
seajai
Total ratings: 51
Report this Post08-10-2012 06:31 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
How did you determine forward engine placement on the cradle?
engine man
Report this Post08-10-2012 06:51 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
I measured from the top of the frame to the top of the firewall then from the top of the frame to the top of the engine so i could measure down the firewall to where the top of the engine would be . knowing that from the very top of the firewall to axle center is 20 inches i measured down to where the top of the engine would be then took a plum bob and measured how far forward the fire wall kicked forward to see how far forward i could move the engine then i measured from the front cradle mounts to the axle center line and that was 22 inches this gave me something to measure off on the cradle to position the engine. it just happen to be i could put the front pulley right even with the front cradle mount bolt hole when all said and done
seajai
Total ratings: 51
Report this Post08-10-2012 11:27 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
So what did your axle offset end up being from the trans to the hub? How tall is the Audi V8?
engine man
Report this Post08-11-2012 02:01 AM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
about 4 3/4 inches since from the from the front of the pulley to the center of the axle on the transmission was 26 3/4 inches and from the front cradle bolt hole it is 22 inches to the hub centerline so 22 from 26 3/4 = 4 3/4
engine man
Report this Post08-13-2012 03:52 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
the cradle all done ! it could be prettier but oh well
engine man
Report this Post08-13-2012 06:53 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
engine man
? is it possible to read and copy all the tables from a stock ecu and put them on a aftermarket ecu as a starting point
[This message has been edited by engine man (edited 08-13-2012).]
engine man
Report this Post08-14-2012 02:33 AM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any one use Mitchel's online auto repair manual is it any good i am going to try it for the wiring schematics http://www.eautorepair.net/...ult.asp?VID=&Count=Y
Report this Post08-14-2012 06:28 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes and no. It is possible to copy and paste the information, but there are a couple of issues.
The size/shapes of the tables might be different and require interpolating data for points you don't have or you might need to lose resolution to fit in a smaller table.
The second and more important aspect is rarely is a single or multiple table all you need. For example a stock speed density computer uses values across multiple tables to control the fueling at a given load, rpm, throttle opening, engine temp, air temp, voltage and O2 feedback (not including all the constant values). So when you swap computers, you can lose or gain additional contributing tables for the fuel/timing control which will alter the numbers in the tables across the board.
When going from one GM ecm to another GM ecm, I have copy/pasted/manipulated the tables as a closer starting point (like using the LT4 map/rpm table for my Ramjet setup), but once the tuning starts most values needed some minor tweaking anyway.
engine man
Report this Post08-14-2012 10:57 AM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks Fieroguru I am still up in the air about weather to run the stock ecu with chip and immobilizer or do the Vems V3 or meegasquirt MS3x no matter what it is $700 but with the Vems and Megasquirt i can tune and stock can be but from what i am told on this Bosch unit the chip needs to be unsolderd and burned even though it is OBD2. I just thought of 1 other thing can a ostrich emulator be used in my Bosch motronic obd2 ecu and could i copy the original maps to it modify and turn off the automatic transmission stuff ?
[This message has been edited by engine man (edited 08-14-2012).]
Total ratings: 236
Report this Post08-14-2012 08:53 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is that 1x2 rectangular tubing for the new rear crossmember?
I'm not sure that's stiff enough to take the weight + torque load from the powertrain by itself without bowing... And it's absolutely not good enough to put any kind of cornering loads on the cradle.
You need to gusset and brace the heck out of that before you start cornering hard.
engine man
Report this Post08-14-2012 08:53 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow i opened up my ecu and not a pretty site not even sure it would work but i will get some electronics cleaner and spray it down and see what it looks like
engine man
Report this Post08-14-2012 09:02 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
engine man
I suppose i could make a few gussets for it and weld them in
Post New Topic
