Check to make sure you even have a cold start injector... a previous owner may have removed it altogether because either it failed or he lived in a warmer climate and felt he didn't need it. The injector plumbing is located as per this photo but the injector is on the hidden end of the small tube:
Also, since there are a lot of temperature sensors at the front end of the engine, here's a guide to be sure you're looking at the right one for the CTS switch:
If that all checks out, then the wire for the switch comes out of the same bundle as the other temperature sensor wires... it should have two wires, a ppl/wht one and a tan one. Good pictures of the installed connector are very hard to get because it's buried under all the vacuum lines.
