  Another 3800sc swap.... (Page 1)
Another 3800sc swap.... by sco77
Started on: 09-03-2012 08:53 PM
Replies: 72 (4158 views)
Last post by: Lou and Blue on 05-31-2015 09:21 PM
sco77
Report this Post09-03-2012 08:53 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
I figured I would start a thread, even though I don't expect to update it very often due to lack of time and money. I will be doing this part by part over the winter on my days off (very few) and maybe even through next year. So needless to say this thread will probably be around for awhile.
Last weekend I picked up an L67 for $300 at local pull yard to go into my 95k 86GT... Build plans: VS Cam, #105 springs, 3.4" Pulley, Headers with stock looking exhaust, Stock 4spd muncie (for now), possible 88 cradle upgrade, lots of polish and paint.
Car that's receiving the swap (black):
Engine when I got it home and on the stand:
(needs some cleaning)
About 2-3 hours into polishing supercharger, this could take months and 100s of hours......
86 Fiero GT 4spd - Stock (new to me)
98 GTP - CAI, ZZP 304 3" DP, 304 PLOG, 3.5", Overkill PCM, PRJ wires, Autolite 605s, 180*, STB, Alt rewire, Projectors, 6000k HID, 12" Brakes, GMPP
Reallybig
Report this Post09-04-2012 12:01 AM Click Here to See the Profile for ReallybigSend a Private Message to ReallybigEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes it will and you'll be happy you did it when it's done!
Oh yeah, Nice looking Fiero!
[This message has been edited by Reallybig (edited 09-04-2012).]
hercimer01
Report this Post09-04-2012 01:04 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thats how i did mine, little by little over the course of a year. Congrats for getting started, the hardest part about doing anything is thinking about it. Have fun.
88 Coupe under construction.
Sourmug
Total ratings: 144
Report this Post09-04-2012 01:11 AM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm going to have to hire you to do the polishing on my next Fiero
sco77
Report this Post09-04-2012 07:21 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
Started breaking down the harness, going to make it custom lengths to be as neatly routed as possible.. To be revisited near the end of the build.
sco77
Report this Post09-09-2012 07:22 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
Almost having second thoughts but really want to 3800sc.. what to do?
86 Fiero GT 4spd - (pending L67 swap)
[This message has been edited by sco77 (edited 09-09-2012).]
sco77
Report this Post05-28-2013 08:06 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well it's been a long time since I started this thread, shortly after starting this thread things have been put on hold but the last few months I was really busy but forgot about this thread, so I will post some things that I got done to bring this thread upto speed....
Installed Deatschwerks DW200 fuel pump and relay rewire, with slight modificatios:
Engine is just about fully assembled, just need a few brackets finished and the supercharger, clutch and misc. Specs: VS Cam, 105# Crow Cam springs, Modified retainers, new (LS7) lifters, Lucas 42.5# injectors, N* w/ GenV:
Polished the GenV blower housing myself, but sent out the snout to have polished and rebuilt by someone else, awaiting snout so I can assemble:
N* throttle body I will be using, got the MAF, wiring and everything to it:
Tapped the EGR hole to use for my brake booster, also blocked coolant passages (maybe an SSIC is in the future...):
MAP sensor location, T off will goto a low mount cut up stock FPR near the fuel filter area:
I did the wiring harness myself, very custom made with correct connectors for my N* MAF/IAT and TPS, etc... Will get better pics of entire harness later in the swap, here is a picture of my injector connectors:
Headers are in process of being built, I pulled the trigger and went with WCF Stainless Headers, going to have a shop mandrel bend 3" back to a Flowtech muffler in stock location, and will exit through these tips:
I will now try to update this thread as I go, this swap will be happening over the summer, I am really motivated to get this done now so it may start coming together more quickly soon. I ordered SPEC Stage3+ clutch late last week so I am still waiting for that along with the headers, about to order engine mounts within the next week and also send out my PCM to sinister performance to get a baseline tune sometime within the next couple weeks.
86 Fiero GT 4spd - (pending L67 swap: VS cam, GenV)
98 GTP - Some mods
[This message has been edited by sco77 (edited 05-28-2013).]
sco77
Report this Post05-28-2013 08:16 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
sco77
Member since Nov 2011
Today I went to put the oil pressure sender on and it was interfering with my low mount alternator, so I had to put a 90* fitting on it, anyone else have that issue with their low mounts?
98 GTP - Some mods
sco77
Report this Post05-30-2013 10:48 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone know if there is a better muffler than the Flowtech Afterburner that fits in stock location without modifying trunk?
86 Fiero GT 4spd - (pending L67 swap: VS cam, GenV) Build Progress
98 GTP - Some mods
FIEROFLYER
Total ratings: 180
Report this Post05-31-2013 09:44 AM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
magnaflow part #12158 fits it is tight but does fit dual 2.5 out single 2.5 in
sco77
Report this Post06-01-2013 04:25 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
So pissed at Fedex, my clutch was suppose to arrive yesterday, I was home and didn't hear a knock... same exact thing happen today and they now can't deliver until Tuesday! which is a day that I WONT be home. I always hated Fedex.
98 GTP - Some mods
darkhorizon
Total ratings: 451
Report this Post06-01-2013 07:05 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Someone has been paying attention, very nice!
sco77
Report this Post06-02-2013 05:07 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
My alternator bracket is a little hack, but it works.. Without even adding the back side bracket yet it already will practically hold my body weight without budging.
98 GTP - Some mods
[This message has been edited by sco77 (edited 06-02-2013).]
1fast2m4
Report this Post06-02-2013 10:03 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Very clean swap, looks like you really took your time & did it right.
1986 SE 3800SC/4t65eHD (12.871@104.96)
1985 GT 3800SC (swap in progress)
sco77
Report this Post06-04-2013 07:05 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
Received 2 more parts today:
98 GTP - Some mods
1fast2m4
Report this Post06-04-2013 08:32 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
What headers are those?
hookdonspeed
Total ratings: 131
Report this Post06-05-2013 01:16 AM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
looking good, keep it up! if you need to use it, i have a DHP tuner, just send me a msg, wouldnt mind getting to see the swap first hand
kooljess
Report this Post06-14-2013 11:12 PM Click Here to See the Profile for kooljessSend a Private Message to kooljessEdit/Delete MessageReply w/QuoteDirect Link to This Post
Please correct me if I am wrong. But, this looks like Steve's (Tennessee's) work of art!!!
sco77
Report this Post06-14-2013 11:31 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
No they are actually WCF headers believe it or not.
86 Fiero GT 4spd - (pending L67 swap: VS cam, GenV) Build Progress eta: 8/13
98 GTP - Some mods
sco77
Report this Post06-25-2013 08:25 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got a lot done today with stripping out the engine bay. Sucks not having a garage (or even pavement), and such very little cramped working space that gets unorganized.. But despite this I had to prove it can be done!
98 GTP - Some mods
1fast2m4
Report this Post06-25-2013 08:33 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Once you get that bad boy road worthy, if you have any issues let me know I have a fully equipped shop in Frederick, MD. Lift and all.
1986 SE 3800SC/4t65eHD (12.871@104.96) I'll Sell it if you like
hookdonspeed
Total ratings: 131
Report this Post06-26-2013 06:29 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
hey 1fast, wana let me lift my 88 to get a good look under it? feels alittle loose at times when turning, and has a squeeky in the front end, only have the street to work in
1fast2m4
Report this Post06-26-2013 06:31 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yea shure, my shop is in Frederick, MD about 30-40min west of Baltimore on I-70 PM if you wanna bring it over.
sco77
Report this Post06-26-2013 10:52 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
Started doing some insulation tonight... Anyone know where I can get a square grommet that will fit or can be made to fit the firewall hole?
98 GTP - Some mods
hookdonspeed
Total ratings: 131
Report this Post06-28-2013 05:01 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
btw sco, if you decide on anything magnaflow let me know, my work is direct with them and not far from you, can probably beat any online price.... (hope we can anyway lol)
Total ratings: 290
Report this Post06-28-2013 10:32 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wack the wires off on both sides of your existing firewall bulkhead fitting. Take it and boil it in a coffee can filled with water. Then pluck it out and separate it. After your harness is finished assemble it around your wires and fill it with a high temp sealant.
[This message has been edited by phonedawgz (edited 06-28-2013).]
86GTFastback
Report this Post06-30-2013 06:42 PM Click Here to See the Profile for 86GTFastbackSend a Private Message to 86GTFastbackEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lol, that would have been a great idea, I just used a torch to melt the glue stuff, it melts really easy but it took some work to melt then scrape on and on.
86GTFastback
Report this Post06-30-2013 06:49 PM Click Here to See the Profile for 86GTFastbackSend a Private Message to 86GTFastbackEdit/Delete MessageReply w/QuoteDirect Link to This Post
86GTFastback
Member since Apr 2009
I'm actually in the latter stages of my swap, I painted my blower to match the car, not polished, but dang that looks so good. I also chose the 3+ spec clutch with my muncie, and sent out my shifter bracket to be modified by WCF to work with the stock cross over then is should be able to move under its own power. You saw my thermostat question, but did my own plug wires and wiring harness so if you have any questions I might be able to help.
I'll keep an eye on this thread, anxious to see the finish product.
sco77
Report this Post06-30-2013 09:09 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ordered some brush on coating for the cradle, some new bushings and suspension stuff, am in the process of cleaning/degreasing everything for paint. Current goal is to have everything painted up by this weekend, then have everything reassembled in the car the following week/weekend.
I've opted to mount my PCM under the deck vent rather than the typical inside the console spot, already made my harness measured out for this location so I am sticking to it. Going to figure out what to do with EVAP system or just delete it and come up with a good filter vent.
98 GTP - Some mods
sco77
Report this Post06-30-2013 09:23 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
sco77
Also going with different tips..
98 GTP - Some mods
Total ratings: 290
Report this Post06-30-2013 10:37 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
From a vacuum source at the throttle body, or between the throttle body and the SC run a vacuum line to the Evap Solenoid. From the other end of the Evap Solenoid run a line to the PURGE port of the charcoal canister. Mount the Evap solenoid on the transmission or some other out of the way place. If you mount it on the firewall you might hear it click on and off.
sco77
Report this Post07-01-2013 07:58 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
7-1-13 sneak peak:
Engine wise need to finalize and bolt on my tensioner/dogbone bracket, do a my final supercharger polishing stage and just small stuff. Supercharger will actually be bolted and installed after its in the car to reduce total cradle height a few more inches.
98 GTP - Some mods
[This message has been edited by sco77 (edited 07-01-2013).]
1fast2m4
Report this Post07-01-2013 08:40 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I hope your car doesn't wind up SOOO CLEAN your afraid to drive it, because that sucker is CRAZY CLEAN!!!
sco77
Report this Post07-01-2013 09:02 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
That's funny, afraid of drive it..... wait.. I'm suppose to drive this thing?
98 GTP - Some mods
Lou6t4gto
Report this Post07-03-2013 01:34 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Go ahead & Laugh, I once built a "67 El Camino SS396 4 speed and I couldn't bring myself to "Haul "anything in it !
sco77
Report this Post07-13-2013 08:44 AM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
Work kind of screwed me, so I might not be able to get this finished before end of summer... But I'm still rolling on with things I can do, sometime over the weekend or maybe next weekend I will atleast get the engine/trans on cradle and cradle in, work on rest of the car wiring, get a few more things cleaned up, assemble what I can, etc.
Supercharger is done, except for painting the PCV cap, cutting out a block off plate for the vacuum side, and getting the PCV vacuum tube hooked to TB. And I got all the new rear suspension parts.
98 GTP - Some mods
85GT_3800SC
Report this Post07-13-2013 10:07 AM Click Here to See the Profile for 85GT_3800SCSend a Private Message to 85GT_3800SCEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is one nice looking power plant! The finish on that supercahrger is amazing.
1fast2m4
Report this Post07-13-2013 10:26 AM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I agree that's the best finish I've ever seen on any Eaton.
sco77
Report this Post07-13-2013 04:50 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know if I would say that, I've seen some very perfect looking polish jobs on GP forums, mines got quite a bit of pitting seen in the sun and some of the tight corners not great.. But I don't want it too perfect because it's going to be hard to maintain, even for a non daily driver.
98 GTP - Some mods
sco77
Report this Post07-13-2013 09:17 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
sco77
Anyone have any idea on a bar park amount the car will be worth when done? I don't mean book value, but price that these normally sell for in this condition.
98 GTP - Some mods
