  Question about Rodney's Rear Frame Floating Cradle Nut Kit
Question about Rodney's Rear Frame Floating Cradle Nut Kit by CowsPatoot
Started on: 09-04-2012 12:29 AM
Replies: 15 (814 views)
Last post by: TriumphFetish on 04-14-2014 11:27 AM
CowsPatoot
Total ratings: 84
Report this Post09-04-2012 12:29 AM Click Here to See the Profile for CowsPatootClick Here to visit CowsPatoot's HomePageSend a Private Message to CowsPatootEdit/Delete MessageReply w/QuoteDirect Link to This Post
So....going by the directions, it is pretty clear how to put this together, and how to drill the frame, etc...basically, it goes together like the pic below (the cigar cutters holding it up represent the frame):
The question is...it also came with four bushings...shown below (one on a bolt to show it's size). It doesn't seem to mention them anywhere in the instructions, and I don't see what their purpose is. Any thoughts before I harass Rodney on the phone again?
Rodney
Total ratings: 267
Report this Post09-04-2012 11:04 AM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
They go under the flat square washers on top of the Fiero frame (inside the opening you cut). Without them you would end up with the floating plates bolted solid to the frame. They provide the space for the floating nut plate to "float".
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
Lambo nut
Total ratings: 257
Report this Post09-04-2012 11:11 AM Click Here to See the Profile for Lambo nutSend a Private Message to Lambo nutEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wasn't following that at first, but I see that the holes in the replacement plate must be larger then the bushings themselves to allow them to move around once the outer bolts are tightened to the frame rail. Great idea really!
Kevin
CowsPatoot
Total ratings: 84
Report this Post09-04-2012 11:28 AM Click Here to See the Profile for CowsPatootClick Here to visit CowsPatoot's HomePageSend a Private Message to CowsPatootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Gotcha...that makes sense. Was wondering why you made the holes so big there. Figured that was a bit excessive to compensate for drilling imperfections. Thanx Rodney.
CowsPatoot
Total ratings: 84
Report this Post09-05-2012 01:31 PM Click Here to See the Profile for CowsPatootClick Here to visit CowsPatoot's HomePageSend a Private Message to CowsPatootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed it this morning. Wanted to add a thanks to Rodney for another wonderful product. This went far smoother than I expected. I think the hardest part was folding the flap down so I could work on it.
Now...if I mix threadlocker and anti-sieze and use it on the rear cradle bolts....then they will stay in until I want them out, then come out smoothly, right?
E.Furgal
Total ratings: 278
Report this Post09-05-2012 03:34 PM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
what is this for exactly..
NW-Fiero
Report this Post09-05-2012 05:20 PM Click Here to See the Profile for NW-FieroSend a Private Message to NW-FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
E.Furgal
Total ratings: 278
Report this Post09-05-2012 05:55 PM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by NW-Fiero:
http://rodneydickman.com/ca....php?products_id=276
thanks..
TriumphFetish
Report this Post04-11-2014 09:20 PM Click Here to See the Profile for TriumphFetishSend a Private Message to TriumphFetishEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know this thread is 2 years old but I am in need of performing this upgrade/repair. Can this be installed without removing the rear bodywork?
Thanks.
Grantman
Report this Post04-11-2014 09:40 PM Click Here to See the Profile for GrantmanSend a Private Message to GrantmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I removed the wheel well since I was removing the cradle but didn't have to remove anything else. they worked great, need small fingers for the inner nuts.
TriumphFetish
Report this Post04-12-2014 11:11 AM Click Here to See the Profile for TriumphFetishSend a Private Message to TriumphFetishEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the reply. Ordering them today.
hookdonspeed
Total ratings: 131
Report this Post04-12-2014 04:06 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
they work great, have them on my 86
TriumphFetish
Report this Post04-12-2014 04:24 PM Click Here to See the Profile for TriumphFetishSend a Private Message to TriumphFetishEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you find the install easy?
BrittB
Report this Post04-13-2014 01:32 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
I hope I don't ever need them but it's nice to know they are available if I ever do!
[This message has been edited by BrittB (edited 04-13-2014).]
Grantman
Report this Post04-13-2014 06:03 PM Click Here to See the Profile for GrantmanSend a Private Message to GrantmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you need this, then yes the install is easy compared to taking the old one out!!
TriumphFetish
Report this Post04-14-2014 11:27 AM Click Here to See the Profile for TriumphFetishSend a Private Message to TriumphFetishEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, I do need them. The passenger side was the only cradle bolt that didn't come out easy peasy... I'm planning on replacing all the suspension/cradle bushings, shock and struts this weekend. I was going to get a head start on the project this weekend by replacing the cradle bushings... Now I have to go through this process to get to the cradle bushings. :-)
