  Headlamp lighting control wiring
Headlamp lighting control wiring by hairballrm
Started on: 09-07-2012 04:40 PM
Replies: 9 (1076 views)
Last post by: hercimer01 on 07-29-2015 08:20 PM
hairballrm
Report this Post09-07-2012 04:40 PM Click Here to See the Profile for hairballrmClick Here to visit hairballrm's HomePageSend a Private Message to hairballrmEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am starting to do some really cool stuff with headlight control and want to start a "resource thread"
This is NOT about headlight motors!
If you suggest good resource threads, I will paste them at the top of each page
Here we go!
Y adapter configuration 90mm Headlight Harness Schematic by Oreif
Marvin knows what he is talking about Conversion Headlight Information and Beam Comparison by Marvin McInnis
Know a good thread we have not found?
Post it here
Rick
"Now you too can see in the dark."
http://projectorretrofit.com/
hairballrm
Report this Post09-07-2012 08:21 PM Click Here to See the Profile for hairballrmClick Here to visit hairballrm's HomePageSend a Private Message to hairballrmEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am now adding Halos to my quad Hella lighting system and want to talk about the different ways to set it up.
What poses the challenge is that you want the halos on whenever you lights are on (or up).
This is very simple if you are running a FTL (full time low) dual relay harness.
Just tap the low beam feed at the bucket (for my stuff it will always be the yellow wire)
If you have "Y adapters" the simplest way is by tapping both high and low beam and isolating them with a pair of diodes.
More on that later.
Recently we did a car that the owner wanted to control everything independently from the dash.
We installed two headlight switches in an "over and under' fashion and it turned out really cool.
He has quad 6060 Hellas, quad halos, and FTL
here is how we did it
this is the untouched control wiring
What we did was treat the second headlight switch like two disconnects
hairballrm
Report this Post09-07-2012 08:37 PM Click Here to See the Profile for hairballrmClick Here to visit hairballrm's HomePageSend a Private Message to hairballrmEdit/Delete MessageReply w/QuoteDirect Link to This Post
hairballrm
Member since Nov 2009
All this switching is done in series.
the first switch (the upper one) turns on the running lights
and in the second (headlights on) position raises the buckets.
The lower, second switch uses the running light position for halos,
and the headlight position for the headlights.
One of the nice things about the set-up is that;
the upper switch is the master.
Flip your headlights off with the upper switch,
everything goes out irregardless of lower switch position
[This message has been edited by hairballrm (edited 09-08-2012).]
hairballrm
Report this Post09-08-2012 08:14 AM Click Here to See the Profile for hairballrmClick Here to visit hairballrm's HomePageSend a Private Message to hairballrmEdit/Delete MessageReply w/QuoteDirect Link to This Post
find the three terminal dimmer switch plug under the steering column
two yellow
two green
one tan
Pull the terminal with the yellow wires from the plug.
Cut the terminal off the two yellow wire leaving a short tail as you will reuse it.
Solder the two yellow wires and a third new one together.
Your "headlight motor up" feed now bypasses the dimmer switch.
This third yellow wire you will run up and feed the line side of the second switch
Solder a new wire onto the terminal and replace it back into the plug.
I used yellow, but in hindsight, it is better to use a different color as it is a different wire.
hairballrm
Report this Post09-10-2012 02:18 AM Click Here to See the Profile for hairballrmClick Here to visit hairballrm's HomePageSend a Private Message to hairballrmEdit/Delete MessageReply w/QuoteDirect Link to This Post
Run the "third yellow wire" to the second headlight switch.
On the connector, tie the orange and red together, solder third yellow wire here.
(a more logical place to grab this switched power is from the yellow wire on the back of the first switch. But I saved a splice by doing it this way.)
The white wire no longer has a purpose.
I bent it over an shrink tubed it.
The brown wire turns on your halos
The yellow feeds your dimmer
hairballrm
Report this Post09-15-2012 02:09 PM Click Here to See the Profile for hairballrmClick Here to visit hairballrm's HomePageSend a Private Message to hairballrmEdit/Delete MessageReply w/QuoteDirect Link to This Post
There was a thread where we were talking about relay harnesses.
I know the search button is my friend, but........I can't seem to find it.
Anyone remember it's title?
[This message has been edited by hairballrm (edited 09-15-2012).]
Asterix
Report this Post10-09-2012 12:24 AM Click Here to See the Profile for AsterixClick Here to visit Asterix's HomePageSend a Private Message to AsterixEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is a thread with more info about the Fiero with the "two-switch" schematic hairballrm shows above.
https://www.fiero.nl/forum/Forum1/HTML/090413.html
hairballrm
Report this Post04-26-2013 07:28 PM Click Here to See the Profile for hairballrmClick Here to visit hairballrm's HomePageSend a Private Message to hairballrmEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump for you RW
http://projectorretrofit.com/ Please Like me on Facebook
hairballrm
Report this Post04-09-2014 08:05 AM Click Here to See the Profile for hairballrmClick Here to visit hairballrm's HomePageSend a Private Message to hairballrmEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yearly anti-archive bump
hercimer01
Report this Post07-29-2015 08:20 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
bump
