  Lets build a Super Duty! (Page 1)
Lets build a Super Duty! by FieroMaster88
Started on: 02-27-2013 10:25 PM
Replies: 44 (2638 views)
Last post by: kwagner on 07-02-2014 09:10 AM
FieroMaster88
Total ratings: 168
Report this Post02-27-2013 10:25 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm in the parts collection stage right now. The block is getting machine work done right now. I have an iron super duty head with 1.7 roller rockers and weber carbs. I have to figure out the ignition system. This engine will be going into my Indy. Advice and encouragement is welcome! Heres the book I'm using:
Here's the head, edelbrock intake and valve cover:
Here's the Weber carbs:
And a link to the Indy restoration thread:
https://www.fiero.nl/forum/Forum1/HTML/087225.html
88 Coupe: 2.0L Turbo 4 Cylinder, W2A, T25 Turbo.
84 Indy #64: Restoration Project/Super Duty swap
[This message has been edited by FieroMaster88 (edited 02-27-2013).]
Report this Post02-27-2013 10:32 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
RWDPLZ
Total ratings: 306
Report this Post02-27-2013 10:56 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
IT BEGINS
Stainless1911
Report this Post02-27-2013 11:00 PM Click Here to See the Profile for Stainless1911Send a Private Message to Stainless1911Edit/Delete MessageReply w/QuoteDirect Link to This Post
Me too. Hey, share the popcorn!
Is that for a Duke? What are you estimating here for HP?
[This message has been edited by Stainless1911 (edited 02-27-2013).]
FieroDan86
Report this Post02-28-2013 01:33 AM Click Here to See the Profile for FieroDan86Send a Private Message to FieroDan86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds awesome! Looking forward to hearing about your progress.
Is that Cannon manifold for the SD head or something else? Are you planning on trying to run the Edelbrock manifold with a different carb as well?
Kento
Total ratings: 131
Report this Post02-28-2013 09:05 AM Click Here to See the Profile for KentoSend a Private Message to KentoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Big question is Do you have the Block and Crank? That is a little needed item to make this happen :P heheeheh Will you run the single intake with a 2brl or the 2 duals?
88 Formula CJB Arrived Finally. #689 of 1252
Time to start Working TONY!
There are Two kinds of Fiero's : Notchies and Donors!
[This message has been edited by Kento (edited 02-28-2013).]
FieroMaster88
Total ratings: 168
Report this Post02-28-2013 09:13 AM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have the block, crankshaft, pistons and a ton of other parts. Waiting for them to arrive and I will post pictures and get started. I have not decided which intake/carb setup to use yet most likely the webers.
Stainless1911
Report this Post02-28-2013 09:36 AM Click Here to See the Profile for Stainless1911Send a Private Message to Stainless1911Edit/Delete MessageReply w/QuoteDirect Link to This Post
Which engine?
FieroMaster88
Total ratings: 168
Report this Post02-28-2013 09:45 AM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I believe they are for a 2.7L.
Total ratings: 237
Report this Post02-28-2013 10:30 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Go EFI...
Get the injector bosses on the Edelbrock piece bored and go single throttle port injection.
OR
Get TWM or Extrude-a-body throttles and use the Weber manifold for Throttle-per-cylinder EFI.
FieroMaster88
Total ratings: 168
Report this Post02-28-2013 02:22 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
That would be cool however I would like to use the parts I already have. I have plenty of time to decide this wont be a super quick build.
RWDPLZ
Total ratings: 306
Report this Post02-28-2013 02:28 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd stick with the Webbers, but add a filter and pipe it into the side air intake so it isn't sucking in dirty, hot engine bay air.
FieroMaster88
Total ratings: 168
Report this Post02-28-2013 03:09 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
That's the idea I had. I have to find a way to do it but need to have the engine in the car so I know how much room I have to work with.
Does anyone know if a crank from a merc. marine 3.0L engine would work?
[This message has been edited by FieroMaster88 (edited 02-28-2013).]
RWDPLZ
Total ratings: 306
Report this Post02-28-2013 03:27 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
I remember there used to be discussions on that way back when, and I think the answer was yes, with a LOT of machine work. I also remember KRP wanted $1800 for an SD4 crank last time I checked.
https://www.fiero.nl/forum/A...100421-2-080867.html
https://www.fiero.nl/forum/A...110502-2-095328.html
https://www.fiero.nl/forum/A...120111-2-093668.html
And of course the infamous
https://www.fiero.nl/forum/A...0502-2-023474-6.html
FieroMaster88
Total ratings: 168
Report this Post02-28-2013 06:23 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well the block I purchased comes with a crankshaft but it needs to be repaired. If it can't be repaired I do have the 3.0 crankshaft from a merc. Engine.
MarkS
Report this Post03-01-2013 05:54 AM Click Here to See the Profile for MarkSSend a Private Message to MarkSEdit/Delete MessageReply w/QuoteDirect Link to This Post
I agree..but do yourself a favor, run it once through the gears with those velocity stacks right behind your ears. Its an intoxicating sound you don't often hear anymore..
BR,
Mark
FieroMaster88
Total ratings: 168
Report this Post03-01-2013 02:43 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm sure it will be run without at least once.
tbone42
Total ratings: 128
Report this Post03-01-2013 03:37 PM Click Here to See the Profile for tbone42Send a Private Message to tbone42Edit/Delete MessageReply w/QuoteDirect Link to This Post
The car used to be mine, the engine used to be Toddsters. Talk about an internal conflict waiting to happen. You could walk out in the garage one night and hear that thing arguing with itself about politics.
I will be watching with great interest!
Lilchief
Report this Post03-01-2013 08:19 PM Click Here to See the Profile for LilchiefSend a Private Message to LilchiefEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have the 2nd or 3rd generation mercruiser crank? The 3rd has chevy rod bearing size, crank # 423-804957T01
85 GT 3.4
14.9 @ 90 1.9 60' Old TH125/3.06
Unknown New 4T60/3.42
Silicoan86
Report this Post03-01-2013 09:28 PM Click Here to See the Profile for Silicoan86Send a Private Message to Silicoan86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Your 4 cylinder turbo build is one of my favorite threads on here.
This thread will be awesome.
FieroMaster88
Total ratings: 168
Report this Post03-01-2013 09:56 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I think it's an early mercruiser crank, I'll have to check. The crankshaft that came with the block is being checked to see if it can be repaired. Once I get all the parts here I'll be ordering gaskets and start putting it all together. Then it's time to pull the car apart, fix the rust, install the new suspension and the engine. I think I'm going to try painting the car myself too.
Lilchief
Report this Post03-01-2013 10:25 PM Click Here to See the Profile for LilchiefSend a Private Message to LilchiefEdit/Delete MessageReply w/QuoteDirect Link to This Post
Which head are you using? I've got a 437 that I'm going to use on my 3.3. I had the head flow tested and here's the flow sheet. https://www.fiero.nl/forum/Forum1/HTML/084256.html
Valve sizes are 2.125 in, 1.6 ex. Your motor going to be NA or boosted ?
85 GT 3.4
FieroMaster88
Total ratings: 168
Report this Post03-01-2013 11:18 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's the cast iron head. It's going to be na, no boost.
Blacktree
Total ratings: 350
Report this Post03-02-2013 10:41 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
ITB's on a Super Duty would be HAWT. But even as is, this should still be a pretty cool build.
FieroMaster88
Total ratings: 168
Report this Post03-03-2013 03:39 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, reading through the info I have it says there was a different head gasket for an iron head vs. the aluminum head. A search online for the part number turned up nothing. Any idea what gasket I should get?
RWDPLZ
Total ratings: 306
Report this Post03-03-2013 04:16 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
The iron head uses 10031324, Pace Performance lists one for $32.01
http://paceperformance.com/...324-f-gasket-cy.html
Also GM Parts East
http://www.gmpartseast.com/...31324_gasket-cy.html
I also remember pricing out the hardware kit years ago at the GM dealer, if you give them a part number they MIGHT be able to get it still?
FieroMaster88
Total ratings: 168
Report this Post03-04-2013 10:53 AM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here's the merc. Crank I have:
Lilchief
Report this Post03-04-2013 11:58 AM Click Here to See the Profile for LilchiefSend a Private Message to LilchiefEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hum, looks like a first generation crank. Have you read this , http://www.s10forum.com/for...-differences-392998/
85 GT 3.4
fierosound
Total ratings: 287
Report this Post03-04-2013 06:56 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have a look at your head to see what you'll need on the exhaust side.
Header gaskets - there are two listed for the 2.5L (sometimes).
More often that not, you'll only find the gasket for the stock Iron Duke.
Here's a pic of the exhaust ports on my SD4 aluminum cylinder head GM PN 10038433
Fel-Pro SD4 header gasket PN FPP-1441 is what matches the ports.
Here's a comparison of the difference in exhaust gaskets.
The top one matches my SD4 head's exhaust ports, the lower is a stock Duke gasket.
While it will bolt on, a header built for the Iron Duke head actually blocks a portion of the exhaust port.
You can see how by how much when the SD4 gasket is matched to the Duke gasket underneath.
[This message has been edited by fierosound (edited 03-04-2013).]
FieroMaster88
Total ratings: 168
Report this Post03-05-2013 02:08 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I will have to make sure I get the correct exhaust manifold gasket! That's a huge difference!
FieroMaster88
Total ratings: 168
Report this Post03-06-2013 08:23 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
So does that mean the crank I have will fit in the engine with no modification?
I picked up another cast iron Super Duty cylinder head and Edelbrock 2 barrel intake today. The smaller engine parts were shipped out and are on the way. The block is still at the machine shop and will be shipped with some of the larger parts once it's finished.
Lilchief
Report this Post03-06-2013 10:05 PM Click Here to See the Profile for LilchiefSend a Private Message to LilchiefEdit/Delete MessageReply w/QuoteDirect Link to This Post
The one you have pictured will take the most modifying of the 3, and I don't know if it can even be done. Did you read all the thread I posted, it's probably the most informative.
FieroMaster88
Total ratings: 168
Report this Post03-06-2013 10:10 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've been reading it on and off. Every time I start I have a screaming baby to take care of. I hope the super duty crankshaft I have is fixable because that would be the best.
FieroMaster88
Total ratings: 168
Report this Post03-09-2013 11:04 AM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I got some boxes in the mail yesterday. Had pistons, rods, clutch parts, bolts, ignition parts all kinds of stuff. Ill get some pictures later and post them. Still waiting on the block and crank.
fierosound
Total ratings: 287
Report this Post03-22-2013 04:58 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
PN 10031328 from here http://www.gafiero.org/docs/SuperDuty.pdf
This should be it http://www.newgmparts.com/p...Search&siteid=213815
and from here too http://autoplicity.com/prod...e_pkg_eng_build.aspx
[This message has been edited by fierosound (edited 03-22-2013).]
FastIndyFiero
Total ratings: 70
Report this Post03-22-2013 08:23 PM Click Here to See the Profile for FastIndyFieroClick Here to visit FastIndyFiero's HomePageSend a Private Message to FastIndyFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I ordered one of the GM hardware kits from gmpartsdirect a few years back. It was in a bit of rough shape, but pretty much everything was usable. The lifter cover they sent was bent pretty well though. There were alot of steel parts that were in the white and had surface rust. If you can still get it, it's a really good deal.
My Web page | The Turbo Super Duty Build.
You know that little voice that says it can't be done? I duct-taped its mouth shut and pushed it down a flight of stairs. (Leader of the Insurgency)
FieroMaster88
Total ratings: 168
Report this Post03-24-2013 06:24 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm still waiting on the block. The crank is not salvagible. Where can I get a 2.7L super duty crankshaft?
RWDPLZ
Total ratings: 306
Report this Post04-17-2013 06:31 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Kansas Racing Products, $1375, can pick whatever stroke you want
http://kansasracingproducts...Products/Prices.html
FieroMaster88
Total ratings: 168
Report this Post04-17-2013 10:07 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm still waiting for the block and other large parts. Hopefully soon...then ill find a crankshaft.
DarcyJL
Report this Post04-17-2013 11:14 PM Click Here to See the Profile for DarcyJLSend a Private Message to DarcyJLEdit/Delete MessageReply w/QuoteDirect Link to This Post
I might have a line on a couple used cranks, i will let you know as i am dealing on them right now. I will get back to you when i know.
What are you using as an oil pan?
