  Fuel Pump Hose, Submersible Fuel Hose, NAPA H209
Fuel Pump Hose, Submersible Fuel Hose, NAPA H209 by Joseph Upson
Started on: 03-13-2013 01:46 PM
Replies: 5 (1751 views)
Last post by: Patrick on 07-17-2020 10:56 PM
Joseph Upson
Total ratings: 88
Report this Post03-13-2013 01:46 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Someone asked about this recently and I wanted to make it easier to find when searching for it by adding an appropriate title. Dennis didn't mention how much this stuff costs. In Florida expect to pay $30 per foot. It should have come with a black eye at that price. Whatever the case you don't want to end up with the wrong hose application when changing out a fuel pump.
https://www.fiero.nl/forum/Forum2/HTML/101054.html
BrittB
Report this Post05-09-2015 08:13 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wonder if it's still $30 per foot and has anyone found a less costly solution?
BrittB
Report this Post05-09-2015 08:15 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
BrittB
Member since Dec 2013
Maybe a bit cheaper and still a known name.
http://www.ebay.com/itm/Gat...11%26rk%3D1%26rkt%3D 2%26mehot%3Dag%26sd%3D281582768347
thesameguy
Report this Post05-09-2015 10:10 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The spec is SAE 30R10. $30 per foot is pretty typical at auto parts stores, but rockauto carries it at about $15 per foot - Gates 27093 and Gates 27097 are the two common parts (5/16' and 3/8").
Total ratings: 329
Report this Post05-10-2015 07:32 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The bad thing about SAE J30R10 submersible fuel injection line is the price. The good thing is that if you are replacing a fuel pump, (and pulsator) you will only need about a 3" length. The critical thing is that standard J30R9 fuel injection hose will not hold up in submersible (in-tank) applications. You only need a pulsator with a gyrator style pump. If you are using a turbine pump like the Bosch or Walbro, the pulsator is not needed.
Report this Post07-17-2020 10:56 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...you will only need about a 3" length.
Due to my own issues with this hose disintegrating (as reported Here), my search for a lower cost alternative for the proper stuff has led me to This. Seems perfect!
Part # 121652... $6.95 for SAE30R10 rated, 5/16" ID, 3" length hose.
Unfortunately, this particular site also wishes to charge $22 to ship to Canada, so I won't be ordering from them... but it would be interesting to hear if anyone in the States checks into and benefits from this. Let us know!
