  Supercharging the cadillac 4.9 with Allante intake and Gen V M90 supercharger (Page 1)
Supercharging the cadillac 4.9 with Allante intake and Gen V M90 supercharger by MaxCubes
Started on: 03-20-2013 03:13 AM
Replies: 311 (28045 views)
Last post by: Will on 04-03-2019 08:55 AM
MaxCubes
Report this Post03-20-2013 03:13 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
1988 Fiero with 4.9 Cadillac V8 conversion.... going supercharged...
some quick history....
Its an 88 base model fiero.... used to be a 4 cylinder automatic
.... a few years ago I swapped in the Cadillac 4.9 V8... and also swapped over to a 5 speed Isuzu manual transmission.
I used an ECM and wiring harness from a 1991 Camaro Z28 305 Tuned port injection.... This worked quite well despite that some said it wouldn't work on the 4.9
A few months later I found a Cadillac Allante in a junkyard.... and I quickly bought the intake and swapped on my 4.9 and noticed the a pretty good gain in acceleration.
About a year later... I broke the isusu transmission and I replaced it with another newer isuzu from a 1999 cavalier.... This isusu lasted about two years and then it also cracked ....
And so I found a Getrag 282 from a 1993 Beretta 3.1 ..... Got some shift linkage adapters from Rodney Dickman.... and this transmission has lasted up to the present day
[This message has been edited by MaxCubes (edited 03-11-2015).]
MaxCubes
Report this Post03-20-2013 03:17 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
Report this Post03-20-2013 03:26 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
Member since Aug 2004
A few months ago I was in the local junkyard....
And to my surprise I saw a 2002 grand prix with a supercharger....
I asked them how much they wanted for it and they said 35 dollars..... and so I bought it cause it was so cheap.
I took it home and wondered if I could actually adapt this thing to my 4.9... wondered it it would fit under the hood
I removed the Allante upper intake and started test fitting....
MaxCubes
Report this Post03-20-2013 03:29 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
MaxCubes
Report this Post03-20-2013 03:36 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
So I made a decision to go for it....
and grinded a notch it the deck lid to clear the supercharger snout
... and grinded on the alternator mount so that the alternator would sit as low as possible......
so that in turn the supercharger would sit as low as possible to clear the hood
MaxCubes
Report this Post03-20-2013 03:39 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
I also had to grind on one of the lower ribs on the snout so that the supercharger is almost touching the alternator....
MaxCubes
Report this Post03-20-2013 03:42 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
And ....
it actually fit under the hood !
MaxCubes
Report this Post03-20-2013 03:44 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
Here is how I will be routing the belt....
MaxCubes
Report this Post03-20-2013 03:47 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
Here is a view of my small belt tensioner assembly... I didn't need to do any changes to it for the supercharger...
MaxCubes
Report this Post03-20-2013 03:52 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
[This message has been edited by MaxCubes (edited 03-13-2015).]
MaxCubes
Report this Post03-20-2013 03:57 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
So after all the test fitting and getting it to fit under the hood...... Now the hardest part....
Making a plenum connecting the superchager to the allante intake manifold....
A gasket.... some spray paint.... and drill away....
MaxCubes
Report this Post03-20-2013 03:59 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
Test fitting the plenum base plate.....
Where ever there was a threaded hole in the allante intake, I drilled a corresponding hole in the metal base plate....
This was done for strength, to hold the supercharger steady....as it takes force to drive a supercharger
MaxCubes
Report this Post03-20-2013 04:00 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
MaxCubes
Report this Post03-20-2013 04:02 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
Test fitting the upper portion of the plenum...
MaxCubes
Report this Post03-20-2013 04:03 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
MaxCubes
Report this Post03-20-2013 04:05 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
MaxCubes
Report this Post03-20-2013 04:13 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
This drawing shows what holes I will use and not use....
The orange line indicates the plenum mounting surface
The black line circle indicates where the 4.9 distributor is
In the yellow circle area... I will seal off the bypass valve passage with a freeze plug. This has to be done because the 4.9 distributor is in this area.
The blue area is where I plan to grind a new hole into the bypass passage... so that the bypass valve will still be functional and allow air to flow from the plenum
The rib in the red circle will be grinded away to allow air to flow from the plenum to the bypass passage
The pink circle is where the pcv valve pulls crank case gas... I will plumb this to a valve cover on the 4.9
The purple circles are ports that will need to be plugged
The green circles will not be used and will be covered by the metal plate
MaxCubes
Report this Post03-20-2013 04:20 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
Here are some quick photos showing the plenum walls being welded to the plenum floor...
MaxCubes
Report this Post03-20-2013 04:23 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
Here are some shots after I welded the top part on...
MaxCubes
Report this Post03-20-2013 04:27 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
A couple more photos showing the plenum after drilling eight holes for the individual runners to the lower Allante intake...
MaxCubes
Report this Post03-20-2013 04:34 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
At this point.... I started looking too get a lower mileage supercharger.....
Since I had done so much hard work and hours making a plenum.... I didn't want to bolt on a worn out high mileage supercharger.
After looking on ebay and doing some research.... I realized the the GEN 5 supercharger was a more efficient design
..... found on 2004 and newer Grand Prix GTP's
.... so I bidded.... and won a lower mileage Gen 5 supercharger....
MaxCubes
Report this Post03-20-2013 04:44 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
The GEN 5 supercharger has a larger outlet versus older generation superchargers....
This photos illustrates the difference....
This is a 3800sc II manifold with a series 3 intake gasket laid on top.... you can see the area that would need to be grinded away to use and GEN V supercharger
MaxCubes
Report this Post03-20-2013 04:47 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
Same goes for the plenum I just made....
The yellow line represents the area I need to cut to open up the manifold for the GEN 5 supercharger
MaxCubes
Report this Post03-20-2013 04:55 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
A few hours of work later.... I have the plenum opened up....
I also port matched and contoured the runner holes for best flow...
Here is a bottom view.... The four little "legs" are spacers welded on... as these bolt holes sit lower than the other holes closer to the runners.
MaxCubes
Report this Post03-20-2013 04:58 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
MaxCubes
Report this Post03-20-2013 05:12 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
Now its time to get a throttle on the supercharger....
I cannot use the Gen 5 supercharger throttle.... It is "fly by wire" ..... no throttle cable
So... I went and found a 2000 up Northstar throttle at the junkyard.... This throttle is 75mm ....
which will flow good and uses a throttle cable.
I had to make a throttle adapter plate to mate it to the supercharger.
... which took a few more hours of measuring, drilling and grinding....
This photo shows how I had to redrill a couple of holes to align with the supercharger
MaxCubes
Report this Post03-20-2013 05:16 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
And here is a photo of the throttle mounted....
.....the throttle is actually mounted upside down.
When mounted right side up.... it would rub a little on the hood.
MaxCubes
Report this Post03-20-2013 05:20 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
MaxCubes
Report this Post03-20-2013 05:26 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
And here is a shot of the 3 inch pulley I order from Pulley Boys...
The stock pulley is 3.8... so I am hoping the 3 inch pulley will get boost up to a decent level
you can easily see the difference in size...
MaxCubes
Report this Post03-20-2013 05:37 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
painted car silver
newf
Total ratings: 116
Report this Post03-20-2013 08:20 AM Click Here to See the Profile for newfSend a Private Message to newfEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wish I had a fifth of you knowledge when it comes to engines. Awesome work!
Arns85GT
Total ratings: 202
Report this Post03-20-2013 08:33 AM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very cool! and NICE WORK!
Any plans to do a dyno run?
Arn
The Aura
Report this Post03-20-2013 11:30 AM Click Here to See the Profile for The AuraSend a Private Message to The AuraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow, Great work.
4900sc has a good ring to it.
MaxCubes
Report this Post03-20-2013 12:30 PM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by The Aura:
Wow, Great work.
Lol... yea I never thought of that .... cool
4900sc .... I should change my username
MaxCubes
Report this Post03-20-2013 12:41 PM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
Here are a few more quick shots from my cell phone....
Some shots of the my Fiero next to my luxurious yacht
Stuff gets pretty dusty here in El Paso, Texas...
MaxCubes
Report this Post03-20-2013 12:58 PM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
Thanks for the kind words....
I am definately low buget and so I do all my own work. Most of my performance upgrades are parts from the junkyard.
....one can learn a great deal just browsing around the yard and doing research.
.... for example, before I bought the supercharger... I unbolted it from the grand prix and took it to a cadillac deville in the same junkyard
....set it on top of the 4.9 and did some of my research and development poor man style
arte444
Total ratings: 151
Report this Post03-20-2013 04:22 PM Click Here to See the Profile for arte444Send a Private Message to arte444Edit/Delete MessageReply w/QuoteDirect Link to This Post
Since FOY is out of the race I guess its you and me now!
Who will finish first =)
-Kyle
Email: kakagiraffe@gmail.com
1988 Notchback 4.9 V8, 5spd Isuzu, Spec Stage 4
True Dual Exhaust, Delta Cam (212,000 Miles)
1992 Honda Civic EX
2006 Pontiac G6 Ecotec
nosrac
Total ratings: 51
Report this Post03-21-2013 09:00 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
This will also get the heat up to blow the engine up level.
You WILL need a intercooler and supporting mods for a 3.0 pulley.
3800SC guys can't just pulley down without Cam or 1.9 Rockers, IC, headers, etc.
Also, you may need bigger injectors as the M90 will flow enough air to max out 36# injectors on a V6.
What size injectors do you have anyway?
Total ratings: 237
Report this Post03-21-2013 09:53 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't forget that he has two more injectors than a V6...
The 3800 needs an intercooler, but the 4.9 may move enough more air that it's not a problem.
Also, how to the crank pulley diameters of the 3800 and this installation compare? Both are involved in drive ratio, obviously.
MaxCubes
Report this Post03-26-2013 10:04 PM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
.... I started the engine today!!!! .....
.... To my surprize it started up... no problem.... no check engine light
Idles quite well... with bypass open...
.... Idles rough like if it has a lumpy cam when the bypass valve is closed... and makes that supercharger whine when reved with bypass valve closed.
No supercharger noise when bypass valve is open.
I haven't really driven it yet since I don't have the throttle cable connected to the throttle yet.
Even when I do connect the throttle .... I will keep the bypass valve open untll I can get the ignition timing and extra fuel needed first.
.....I will try to post a short video on youtube with the engine running... maybe in a day or two
