  Connector part numbers help - C203 - C500 - new pins?
Connector part numbers help - C203 - C500 - new pins? by mcgavin
Started on: 04-13-2013 10:52 AM
Replies: 28 (3065 views)
Last post by: Will on 08-14-2021 08:01 PM
mcgavin
Report this Post04-13-2013 10:52 AM Click Here to See the Profile for mcgavinClick Here to visit mcgavin's HomePageSend a Private Message to mcgavinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am starting an engine swap and I'm trying to keep things as clean as possible on the wiring side. Does anyone know where to find new pins and or connectors, unassembled?
I need parts for C203 (15 pins, between driver and passenger seat) and C500 (34 pins, at the battery).
Report this Post04-13-2013 11:19 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
New pin are available...
a few sources in my Cave, Wire Service
I suggest crimp then solder for best results.
[This message has been edited by theogre (edited 04-13-2013).]
mcgavin
Report this Post04-13-2013 12:01 PM Click Here to See the Profile for mcgavinClick Here to visit mcgavin's HomePageSend a Private Message to mcgavinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for the link. I hopped through some pages and that is a great write up of all sorts of different wiring issues.
Maybe I overlooked something, but I didn't see part numbers for pins or connectors for C203 and C500. Also, where could they be ordered from? Terminal Supply (because there is a physical store about 8 miles from my house) and Mouser.com are my two go-to shopping sources for wiring parts, but I'm not sure if they would help with parts this old.
Also, somewhat related, do you know what C203 pin C is used for? It looks BRN/WHT or BLK/WHT in the car. I went through all of secion 8A in the service manual twice and that is the only pin who's function I don't know out of everything in C500 and C203. This is in a 1988 GT, manual transmission.
Bloozberry
Total ratings: 311
Report this Post04-13-2013 12:17 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is a list complied by PFF member Jncomutt a while back:
Bulkhead small pins Male
Mouser Part #: 829-12077628
Manufacturer Part #: 12077628
Bulkhead small pins Female
Mouser Part #: 829-12084200
Manufacturer Part #: 12084200
Bulkhead mid pins Male
Mouser Part #: 829-12129497
Manufacturer Part #: 12129497
Bulkhead mid pins Female
Mouser Part #: 829-12129493
Manufacturer Part #: 12129493
Bulkhead Large pins Male
Mouser Part #: 829-12064736
Manufacturer Part #: 12064736
Bulkhead Large pins Female
Mouser Part #: 829-12052456
Manufacturer Part #: 12052456
C203 Female Pins
Mouser Part #: 829-12162595
Manufacturer Part #: 12162595
GM Weatherpack Male pins (Fuel Pump pigtail, MAP,etc)
Mouser Part #: 829-12146501
Manufacturer Part #: 12146501
GM Weatherpack Female pins
Mouser Part #: 829-12089188
Manufacturer Part #: 12089188
Most of the GM 3800 sensor pins (Cam/crank, ECT,etc)
Mouser Part #: 829-12124075
Manufacturer Part #: 12124075
Injector Pins
Mouser Part #: 829-12103360
Manufacturer Part #: 12103360
mcgavin
Report this Post04-13-2013 02:15 PM Click Here to See the Profile for mcgavinClick Here to visit mcgavin's HomePageSend a Private Message to mcgavinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome! That looks like most of what I need. The C500 is a real mess with whatever that sealant stuff is thats injected in the connector. I kind of doubt you can find those new anymore though.
ericjon262
Total ratings: 67
Report this Post04-13-2013 02:17 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
C203 Female Pins
Injector Pins
yet another item that should be stickied somewhere...
Total ratings: 291
Report this Post04-13-2013 02:32 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://i386.photobucket.com.../fieroX/IMG_2009.jpg
ericjon262
Total ratings: 67
Report this Post04-13-2013 02:36 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
I only see one third of the connecter in there, got the other 2 thirds? I might be interested in purchasing one from you if the price is right.
Built not bought... Because bolt-ons don't.
mcgavin
Report this Post04-13-2013 03:28 PM Click Here to See the Profile for mcgavinClick Here to visit mcgavin's HomePageSend a Private Message to mcgavinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those are hardly new, they are all out of the original sealed package. They are more or less garbage now
Ok, so how do I buy one of those bad boys? Any idea what the goop in the connector is in case I make a new one and want to inject the same stuff?
fieroluke
Report this Post04-13-2013 03:53 PM Click Here to See the Profile for fierolukeClick Here to visit fieroluke's HomePageSend a Private Message to fierolukeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd be interested in a m/f pair also!
Best regards
Oliver
Total ratings: 291
Report this Post04-13-2013 04:31 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Only this part of the connector was made. To purchase contact FieroX. I have some also but I would have to charge more than he sells them for, so you might as well go directly to the source.
They are lacking the secondary terminal retention fork, but you can use your old one. Same thing for the missing back cover.
Use dielectric grease instead of the goo that was in the old ones.
He also has some new C203s
mcgavin
Report this Post04-13-2013 08:34 PM Click Here to See the Profile for mcgavinClick Here to visit mcgavin's HomePageSend a Private Message to mcgavinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know this is barely related, but ...
...do you know what C203 pin C is used for? It looks BRN/WHT or BLK/WHT in the car. I went through all of secion 8A in the service manual twice and that is the only pin who's function I don't know out of everything in C500 and C203. This is in a 1988 GT, manual transmission.
FIEROFLYER
Total ratings: 180
Report this Post04-13-2013 09:20 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
C203 pin C is the SES lamp or check engine light wire depending on what you want to call it. Dan
DARN Cars now open with
mcgavin
Report this Post04-13-2013 10:39 PM Click Here to See the Profile for mcgavinClick Here to visit mcgavin's HomePageSend a Private Message to mcgavinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm missing part of page 8A-21-3, so I guess that's where its at. I should have glanced and the Iron Duke diagram since they share stuff like that.
Thank you!
FIEROFLYER
Total ratings: 180
Report this Post04-14-2013 09:18 AM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
The C500 is the same connector as the Fiero C100 up front just different colour wires and the C203 was used in many other GM vehicles up into the 90's including even trucks and the space shuttle/dust buster Trans Sport vans as well as the F body cars. Dan
mcgavin
Report this Post04-14-2013 11:02 AM Click Here to See the Profile for mcgavinClick Here to visit mcgavin's HomePageSend a Private Message to mcgavinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Dan. I was starting to notice that yesterday. I have two service manuals, one for a 1988 Fiero and one for a 1995 Beretta. Then I also have the service manual Techline eSI thing on installed on my computer. With that you can just pick a car and then search the term "connector end" to get a quick list of what it all looks like for a car. My installation goes through 2005 with is just enough for the 3500 info I needed. I'm really familiar with the sensor connectors on the engine, and some of the interior ones ( I have a BCM swap under my belt - shameless site plug ). This whole engine new engine swap and changing to a Megasquirt ECU is pushing me. I already did one Megasquirt install, but I just made a foot long adapter harness to the car's OEM ECU connectors. I left a lot of wiring around that I didn't need and it was real messy. I'm trying to avoid that.
In the Beretta, it looks like C200 around the steering column is the same connector as C203 on the Fiero. Thats easy enough to find a in a junkyard.
I think I've got my wiring harness about finished on paper. It looks like I can keep the C500 connector on it's own harness apart from C203 if I move just a couple wires into C203 at pins I'm not using (coolant fan switch to HVAC connector and coolant gauge sensor to the ignition switch). I still can't believe they had 3 different coolant sensors/switches on the Fiero.
mcgavin
Report this Post06-22-2013 01:47 PM Click Here to See the Profile for mcgavinClick Here to visit mcgavin's HomePageSend a Private Message to mcgavinEdit/Delete MessageReply w/QuoteDirect Link to This Post
C203 Female Pins
Injector Pins
There is a chance that I made an error somewhere, but I think that there needs to be a correction to this list. I ordered all sizes of the male pins listed and none were the correct size for the wire to the starter solenoid. After measuring it and rechecking the part numbers, I think the part number that will work for the large pins is 12065196. It is a 4.8mm blade in my car. The large pins listed in the qutoe are a 6.3mm blade, which does not work for the starter terminal. The mid pins are a 2.8mm blade, so that doesn't work either.
FieroNate
Report this Post08-15-2013 02:21 PM Click Here to See the Profile for FieroNateClick Here to visit FieroNate's HomePageSend a Private Message to FieroNateEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone know the quantity of the pins required for these?
Anyone know if the center connector is available for the C500?
Anyone have a delphi part number on them?
fierogtx
Report this Post05-27-2014 03:30 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
added to my favorite great link
ericjon262
Total ratings: 67
Report this Post04-17-2020 07:45 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
Blast from the past, but yeah, the terminals listed above are NOT correct. the mid pins on the bulkhead are not metripack 280's. so if someone has the correct pins, it would be a huge help/
this is the closest I have found so far, but it looks too wide based on the picture.
https://www.eficonnection.c...sealed-12ga-terminal
[This message has been edited by ericjon262 (edited 04-17-2020).]
mcgavin
Report this Post04-17-2020 11:30 PM Click Here to See the Profile for mcgavinClick Here to visit mcgavin's HomePageSend a Private Message to mcgavinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Going by what I posted, and looking at Mouser where I bought almost all my pins when I changed my engine+ECU, it is a 480 series pin:
https://www.mouser.com/Prod...5AK9w5s05garzJQOAAFT
Total ratings: 291
Report this Post04-18-2020 09:10 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you need just a few, send me a PM and I'll send some.
ericjon262
Total ratings: 67
Report this Post04-19-2020 02:53 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
thanks, I must have misread your post, I think I found what I need. the above linked, and the link below appear to be the correct terminal.
https://www.mouser.com/Prod...IJZ52nOtSF7g0jRHE%3D
Phonedawgz, I'm going to shoot you a PM.
cognita semper
Total ratings: 237
Report this Post04-21-2020 09:57 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
CarQuest has metri-pack pins in packs of 5 or 10.
Ooooooh, Shiny!
Anyone have the PN for the bulkhead pass-through clamshell halves where the engine wiring harness goes through the firewall and into the passenger compartment?
ericjon262
Total ratings: 67
Report this Post04-21-2020 07:01 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ooooooh, Shiny!
I could go for the clamshells as well!
I ordered 10 of each from mouser, it's about 10 times each pin I needed, it's also only about $14...
cognita semper
[This message has been edited by ericjon262 (edited 04-21-2020).]
ericjon262
Total ratings: 67
Report this Post04-23-2020 07:57 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have verified these to be the correct terminals. I have them installed in my C100. Thanks everyone for the help.
cognita semper
Total ratings: 237
Report this Post08-09-2021 07:12 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, but do you have the part number?
Total ratings: 291
Report this Post08-14-2021 07:02 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Part number for the connector? This connector is not available without a special order.
Part number for the pins? There are several part numbers. First there are two widths of the blades. Next for each width, there are different terminals (part numbers) depending on the thickness of the wire the terminal is designed to crimp to.
Total ratings: 237
Report this Post08-14-2021 08:01 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was referring to the connector bodies. I've had Metri-Pack terminal part numbers for a couple of decades now.
Finding new parts for the bulkhead pass-through would still be great. I'm kind of close to just saying F@#$ it and throwing down for a Deutsch bulkhead disconnect.
