  Another Engine Swap (56k umm.. probably not) (Page 2)
Another Engine Swap (56k umm.. probably not) by 1fast2m4
Started on: 05-05-2013 08:55 PM
Replies: 42 (4349 views)
Last post by: 1fast2m4 on 02-27-2016 03:05 PM
1fast2m4
Report this Post04-15-2015 05:42 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
( Edit: I got my own 1st post on My own 2nd page )
Got the Engine back in Finally
Ordered A fuel system that will work with my Return Less rail
Fuel system is installed.
I discovered a clearance issue @ the throttle body / deck lid. The torsion rod will need to go, and the deck lid will need a small notch to clear the throttle bracket.
I purchased Tom Light's old ZZP stage 2.5 Trans, so she is coming back out next week and while the engine is out I'll also be installing a set of Yella Terra 1.9 roller rockers
1986 SE 3800SC/4t65eHD (12.871@104.96)
HX-40, FrozenBoost I/C, 80lb injectors & E85 Coming soon.....
[This message has been edited by 1fast2m4 (edited 04-15-2015).]
1fast2m4
Report this Post05-10-2015 08:23 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
We got the Old trans out and the new one in Saturday
Basicaly a ZZP stage 3 trans (with a 7/8" chain in place of the discontinued 1" chain)
ZZP 2750 stall 245mm converter, ZZP aluminum transmission pan, 4340 input shaft, 7/8" single chain gear set, Sonnax Billet 3rd Clutch Piston, Chromoly pump shaft, ZZP output shaft
1fast2m4
Report this Post02-27-2016 03:05 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
just got a pile of parts from various vendors, Innovative SCG boost controller, also ordered the Araut rear bump steer kit. this thing WILL be on the road by the 1st of May
