  Air Conditioning O-Ring Sizes and Locations
Air Conditioning O-Ring Sizes and Locations by RWDPLZ
Started on: 05-19-2013 04:59 PM
Replies: 32 (3038 views)
Last post by: theogre on 08-12-2016 05:44 PM
RWDPLZ
Total ratings: 305
Report this Post05-19-2013 04:59 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been working on a write-up for a while on the different o-ring sizes used on the Fiero, with pictures, diagrams, explanations, etc. Recently I started a new job, and have not had the time to work on it, so I thought I'd post the important information here so people could make use of it, now that it's getting hot outside.
-84 Fieros use different lines and o-ring sizes than the later years, hence the two different tables.
-Use 525 Viscosity mineral oil designed for air conditioning systems to lubricate the o-rings, even if converting the system over to R-134A. NAPA sells a quart bottle, which is WAY more than enough, part # 209500
84:
85-88:
1984 Fiero SE
[This message has been edited by RWDPLZ (edited 06-09-2014).]
jscott1
Total ratings: 415
Report this Post05-19-2013 10:27 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Right click...save as.
thanks!
sricka01
Report this Post05-20-2013 02:13 AM Click Here to See the Profile for sricka01Send a Private Message to sricka01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you so much and this chart couldn't have arrived at a better time! Well maybe 5 hours ago. I guesstimated which orings to use from my assortment kit, pulled vacuum, and it's not holding!
sricka01
Report this Post05-20-2013 03:38 AM Click Here to See the Profile for sricka01Send a Private Message to sricka01Edit/Delete MessageReply w/QuoteDirect Link to This Post
sricka01
Member since Jul 2008
RWDPLZ,
When I was installing new Hi/Lo switches I was hesitating. The compressor had black rings already in the grooves. The Santech packages had green Orings and I couldnt decide whether to dig out the black rings from the reman'd compressor or just install the switches with these existing Orings.
What is the correct choice?
RWDPLZ
Total ratings: 305
Report this Post05-20-2013 06:54 AM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Black o-rings CAN be HNBR material, not just the green ones . If your new switches came with o-rings, I'd pull the black ones, lube the new ones, and put those in.
Switch info:
https://www.fiero.nl/forum/Forum2/HTML/117640.html
Tom Slick
Report this Post05-20-2013 08:01 AM Click Here to See the Profile for Tom SlickSend a Private Message to Tom SlickEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks!
Ditto...
Total ratings: 329
Report this Post05-20-2013 09:52 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have not had to use any special "captured" O rings on a Fiero A/C system. All of them (except for the compressor outlet lines) use the standard variety A/C O rings. I use the green R-134a compatible rings. If you have a GM assortment kit with #6, #8 and no 12 A/C O rings you'll be set. Just watch the O ring thickness (material cross section diameter) and match accordingly.
sricka01
Report this Post05-21-2013 12:24 AM Click Here to See the Profile for sricka01Send a Private Message to sricka01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm so confused right now. Everyone has varied opinions on what orings to use. To further complicate, I bought a SUPERCOOL tackle box set of o-rings contains 350 orings (part #OR350), and I cannot match it up some of them with the chart up above. It has a printout picture for each compartment but the sizes are all over the place but not specific. UGHHH!!
RWDPLZ
Total ratings: 305
Report this Post05-21-2013 10:43 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
I made the same mistake and bought a large assortment like that. Basically useless, since the called out sizes don't correspond to what the manufacturers use. I even went as far as to take a set of digital calipers and start measuring them to see the sizes, but they were almost all odd-ball ones.
If you can wait until this weekend, I have in my notes the part number of a small kit that contains almost all the o-rings, for roughly $7, available at most auto parts stores. It's at my parent's house, and I'll be up there then. IIRC it contained all but two of the o-rings for the 84, don't remember on the 85+
Every accumulator I've bought so far has come with o-rings for the accumulator inlet and outlet connections, so that's a couple less to worry about.
RWDPLZ
Total ratings: 305
Report this Post05-21-2013 10:48 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
RWDPLZ
Member since May 2002
You can tell if the connection requires a captured o-ring or not by looking at the line at that connection. A square shoulder means a standard o-ring, while a tapered cone-shaped one uses a captured.
Standard (evaporator to accumulator):
Captured (84 accumulator outlet):
[This message has been edited by RWDPLZ (edited 05-21-2013).]
sricka01
Report this Post05-22-2013 06:07 PM Click Here to See the Profile for sricka01Send a Private Message to sricka01Edit/Delete MessageReply w/QuoteDirect Link to This Post
so captured essentially looks like a flared end or turtleneck sweater. However you want to call it.
Total ratings: 329
Report this Post05-23-2013 10:21 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know about standard or captured but I just replaced all of the O rings on one of my A/C systems and just matched the sizes. No leaks so far. Perhaps you do need captured rings here and there but just matching them has worked. Maybe I'm just lucky!
Joseph Upson
Total ratings: 88
Report this Post05-23-2013 01:05 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's where I've run into problems before, thickness. The condenser O-rings and apparently the manifold connection at the frame rail coming from the compressor may be an issue also. I'll have to check the vacuum on the system again today to make sure.
NAPA # 801745 O-ring kit
This kit appears to have all of the proper size O-rings in it for the 85 up. It's the only one out of the universal kits I purchased that had the proper O-ring for the condenser as matched to the original.
RWDPLZ
Total ratings: 305
Report this Post05-23-2013 06:23 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
The condenser uses captured o-rings at the inlet and outlet, one being the oddball #6 size, the other #8. The manifold at the frame rail, at the rear of 85+ cars, uses standard o-rings, #8 and #12.
Note the straight shoulder:
josef644 posted these pics a while back
Tom Slick
Report this Post05-25-2013 08:08 PM Click Here to See the Profile for Tom SlickSend a Private Message to Tom SlickEdit/Delete MessageReply w/QuoteDirect Link to This Post
is there an equivalent version of the NAPA kit at Autozone?
the only reason i ask cause there is an 20% off coupon from AZ available, a penny save is a penny i can spend somewhere else.
thanks...
Joseph Upson
Total ratings: 88
Report this Post05-25-2013 08:15 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks...
That's a tough call because that's a NAPA specific part number in their packaging with no other numbers, so it's likely a NAPA specific kit. It turns out I did have the wrong O-ring at the exhaust end of the compressor hose at the frame rail as indicated by loss of most of the vacuum after 30 minutes. It appears I had a metric o-ring in place and on comparison the standard o-ring was thicker. The o-ring on it initially was incorrect also as it had been crimped on two sides where it stuck out from beneath the sealing surface but it held under pressure. Just make sure you get standard o-rings and measure them if you have to.
[This message has been edited by Joseph Upson (edited 05-25-2013).]
Tom Slick
Report this Post05-26-2013 04:16 PM Click Here to See the Profile for Tom SlickSend a Private Message to Tom SlickEdit/Delete MessageReply w/QuoteDirect Link to This Post
i went to AZ today to return a loaner tool i borrowed. while there i saw an O-ring kit but all the rings were in metric, i guess that is the wrong kit.
[This message has been edited by Tom Slick (edited 07-05-2013).]
Tom Slick
Report this Post05-27-2013 11:34 AM Click Here to See the Profile for Tom SlickSend a Private Message to Tom SlickEdit/Delete MessageReply w/QuoteDirect Link to This Post
would this conversion kit work?
http://www.napaonline.com/C...TEM408886_0407004630
thanks...
RWDPLZ
Total ratings: 305
Report this Post05-27-2013 06:15 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks...
That appears to be just a universal kit. Also, it includes Ester oil, which is NOT approved for use in AC systems by any manufacturer.
I found my notes, the kit is Santech part # MT2547, and it includes
2x Compressor switch
1x #6 captured
4x #12 captured
3x #12 standard
3x #8 captured
2x #8 standard
1x orifice tube
4x #6 standard
2x V5 compressor control valve seals
So for an 84 or 85-88, it would be missing one #8 captured, and the compressor suction and discharge port o-rings.
The Four Seasons equivalent appears to be part # 26735, I'll have to get one and see what exactly it includes.
sricka01
Report this Post05-27-2013 11:49 PM Click Here to See the Profile for sricka01Send a Private Message to sricka01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I cannot find either part # on napaonline.com
RWDPLZ
Total ratings: 305
Report this Post05-29-2013 06:10 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
NAPA doesn't carry Santech, and pretty sure they don't carry Four Seasons. So much of their stuff is rebranded it's hard to tell.
Tom Slick
Report this Post05-31-2013 09:59 PM Click Here to See the Profile for Tom SlickSend a Private Message to Tom SlickEdit/Delete MessageReply w/QuoteDirect Link to This Post
did you ever get a chance to get above part # and see if it will suffice?
thanks...
RWDPLZ
Total ratings: 305
Report this Post06-01-2013 10:23 AM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry, been busy with work. I just checked Autozone and NAPA's sites, and they don't sell them. Advance does, but none of the stores in my area have any in stock. As far as I know, there aren't any mom-and-pop type shops here downstate, I bet Thirlby's back in Traverse City would have it.
I'll stop by the local Advance and order one, and post the results later.
RWDPLZ
Total ratings: 305
Report this Post06-01-2013 05:16 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
RWDPLZ
I stopped by O'Reilly's and they had the part number in their computer, but couldn't even order it. Went to Advance, and they claim it'll be here tomorrow by noon.
RWDPLZ
Total ratings: 305
Report this Post06-08-2013 10:11 AM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just went through and took inventory of what comes in the 26735 o-ring kit, and it's almost identical, except it has one less #6 standard (not used on Fiero anyway) and DOES include the compressor suction and discharge port o-rings. Otherwise, still missing one #8 captured needed for a full set for a Fiero. It would be the most complete option we have now.
Tom Slick
Report this Post06-08-2013 11:42 AM Click Here to See the Profile for Tom SlickSend a Private Message to Tom SlickEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks for the update.
spad
Report this Post06-28-2013 10:25 AM Click Here to See the Profile for spadClick Here to visit spad's HomePageSend a Private Message to spadEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is the true difference between standard and captured o-ring? Does them both have round profile, but captured is only thicker?
I chanced o-ring between evaporator and offrice tube, and have a doubt that it may be leaking. Old one had small profile, but I thought it was just formed like that over the years. I replaced it with proximately same size o-ring from FOUR SEASONS 26735 kit.
(I have used ~1300 $ to get A/C working and still I'm at this point. Damn.)
Tom Slick
Report this Post07-06-2013 12:11 PM Click Here to See the Profile for Tom SlickSend a Private Message to Tom SlickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would like to know the answer to this as well.
in this chart, the Four Seasons shows the same part# for the #8 (standard & capture) o-ring (24131) but the AC Delco shows two different part number.
is this a mistake in Four Seasons or is it okay to use the same o-ring for both standard and capture o-rings?
thanks...
edit:
should the #8 part numbers be:
captured - 24131
standard - 24608
or vice versa?
[This message has been edited by Tom Slick (edited 07-06-2013).]
RWDPLZ
Total ratings: 305
Report this Post07-06-2013 03:50 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just looked it up, and the #8 standard Four Seasons part number should be 24608, thanks for catching that. I'll edit the data later and re-post the corrected table. The AC Delco numbers are correct.
The difference between the standard and captured is basically the cross sectional area. Standard are thinner, and captured are fatter.
Standard:
Captured:
Ponnari
Report this Post07-28-2015 07:10 PM Click Here to See the Profile for PonnariSend a Private Message to PonnariEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is a great write up!
Found some additional info that I thought would be helpful, hope it's ok to post it here
"Because in a split second, It's gone"
Ayrton Senna
TXGOOD
Total ratings: 87
Report this Post07-29-2015 08:13 AM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know this is an old thread but I never saw it.
The chart will come in handy.
I do find it ironic though that every part number I looked up for these o-rings says "Does not fit your 1986 Fiero"
But, I think on Amazon, unless it`s a vehicle specific part it will say that.
Total ratings: 329
Report this Post07-29-2015 12:47 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Still some great info here. I sometimes have trouble matching O rings but have a large assortment of them. If I am not sure I just measure them with a caliper both OD and cross section (thickness) and go from there. If the NAPA kit works as stated that should eliminate most of the matching problems.
Its may not always be necessary to replace all of the old black O rings with the green compound rings when doing a conversion. We've done some where we left the old ones in place at non-critical locations and the system remained tight and leak free for years. What we have noticed is that the high and low side Schrader valve fittings, the switch port and fill port are often leak points.
Report this Post08-12-2016 05:44 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can get:
Refrigeration Technologies, NYLOG (video tell red/blue label means)
Highside Chemical, Leak Lock Gold with Teflon
Both are used as thread & seal sealer/lube for AC jobs of all kinds. Not aftermarket items to seal leaks in a close system.
Google Amazon etc for them to find different sizes.
(Leak Lock is no longer available thru Supercool as my cave said.)
Is a old thread but keeps refrigeration sealer/lubes w/ o-ring sizes...
