  rubber brake lines vs stainless steel (Page 2)
rubber brake lines vs stainless steel by mmeyer86gt/gtp
Started on: 07-07-2013 12:25 AM
Replies: 41 (4123 views)
Last post by: Will on 07-15-2013 11:25 AM
Marvin McInnis
Total ratings: 227
Report this Post07-15-2013 01:13 AM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Will:
... racers have no choice but to use custom braided stainless lines.
I wouldn't go quite that far. Since WW-II racers have depended on the aerospace industry for a lot of hardware, including PTFE/stainless hoses, but there are aircraft-spec hydraulic hoses suitable for race car brake use that incorporate rubber lining and non-metallic fiber reinforcement. So there are other choices available. I don't have applicable race experience, so I don't know the factors that go into the selection of PTFE/stainless hose over the rubber/non-metallic alternatives. However I suspect that superior properties at high temperatures and low expansion under pressure (and thus higher precision brake modulation) are major considerations.
[This message has been edited by Marvin McInnis (edited 07-15-2013).]
Total ratings: 236
Report this Post07-15-2013 11:25 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Resistance to glycol-based fluids is critical for brake hoses... Not sure what airplanes use for brake fluid. Non-brake hydraulics use Skydroil or similar because it's non-flammable... Chemically it's pretty nasty stuff, but I don't know how it compares to glycol.
