  Paint code for factory chassis black?
Paint code for factory chassis black? by mark1970
Started on: 07-08-2013 08:56 PM
Replies: 2 (594 views)
Last post by: Tha Driver on 07-09-2013 06:58 PM
mark1970
Report this Post07-08-2013 08:56 PM Click Here to See the Profile for mark1970Send a Private Message to mark1970Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is there a paint code for GM chassis black? as there are so many variations of satin, matte,etc. black and would like to know before ordering a gallon .... To be clear the black I am looking for would be for frame suspension firewall door jams etc.
Thanks in advance for your help
rogergarrison
Total ratings: 551
Report this Post07-09-2013 02:36 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Im sure there are different blacks on all the different components, although some may be the same too. I know on Corvette restorations I did there was no less than 5 different blacks used on different chassis and underhood parts. The manufacturers were never smart enough to use just one black and be done with it.
Tha Driver
Total ratings: 204
Report this Post07-09-2013 06:58 PM Click Here to See the Profile for Tha DriverClick Here to visit Tha Driver's HomePageSend a Private Message to Tha DriverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Satin, semi-flat, semi-gloss are all pretty much the same. On suspension parts, I always sandblast, prime with PPG epoxy primer, & paint with semi-flat black urethane. On the spaceframe, if everything is smooth you only need to sand it well, & you don't HAVE to prime it - but I prime with the epoxy as it gives maximum adhesion.
Manufacturers just use whatever paint they can get the cheapest at the time...
~ Paul
aka "Tha Driver"
Custom Fiberglass Parts
