  Modified stock air canister and base to 3.5 inch for 3800na
Modified stock air canister and base to 3.5 inch for 3800na by MulletproofMonk
Started on: 08-01-2013 10:12 PM
Replies: 3 (1183 views)
Last post by: CC Rider on 08-02-2013 10:48 AM
MulletproofMonk
Total ratings: 78
Report this Post08-01-2013 10:12 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I saw ALJR's thread Another option for 3800 air cleaner, I liked it. Stock look, more air flow, easy to change filter and I could point it at the 3800na boot. So take a look at ALJR's thread to give him some props.
The can is hard to weld because it is so thin. Don't bust my chops about my welds. Should have done what ALJR did, tack it and use JB weld to seal the seams.
So, here is the base with a 3.5" pipe in it versus a stock base.
3.5" pipe with the hold down in it.
Here is the stock can with 3.5" out.
You've got to grind the bottom of the can out too
Here is what the 3.5" pipe looks like on the filter. I know, the filter is rusty. It was and old one in the trash...
Getting the old rod out of the base sucks. I just used threaded rod to replace it.
3" PVC
Suck Suck Suck. Good grief. The audio quaility after compression sucks...
http://www.youtube.com/watc...t2I&feature=youtu.be
-Brian
Removing the roof panel
My HUD install thread
[This message has been edited by MulletproofMonk (edited 08-01-2013).]
MulletproofMonk
Total ratings: 78
Report this Post08-01-2013 10:13 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lets look at the stock base versus the 3.5" Base:
The stock metal base is inside the 3.5
The hold down is thinner too.
I painted the stock base red and put the 3.5 on top of it just for another view.
[This message has been edited by MulletproofMonk (edited 08-02-2013).]
MulletproofMonk
Total ratings: 78
Report this Post08-01-2013 10:15 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
MulletproofMonk
Member since Oct 2005
So, how does it compare to the Silverado intake tube?
Here it is in the rubber end.
Here it is compared to the solid part of the intake tube.
CC Rider
Total ratings: 61
Report this Post08-02-2013 10:48 AM Click Here to See the Profile for CC RiderSend a Private Message to CC RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very nice!
Your welds look as good as mine
I've done this mode several times and like the look and function better then the K&N hanging in the engine bay or down in the wheel well.
Red 1988 GT 5 speed LQ1 Powered
Poly all around, Koni's and Lowered
Items for sale - cradle support - 3800 tranny mounts
http://s733.photobucket.com/albums/ww339/CC_Rider/
