  Modifying Intake manifold with Brazing instead of welding
Modifying Intake manifold with Brazing instead of welding by zkhennings
Started on: 08-13-2013 05:24 PM
Replies: 20 (3804 views)
Last post by: zkhennings on 08-19-2013 01:12 PM
zkhennings
Report this Post08-13-2013 05:24 PM Click Here to See the Profile for zkhenningsSend a Private Message to zkhenningsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am doing something similar to the DAWG modification on my upper intake manifold, but I only have a MIG and I have near a full tank of C25 and don't want to buy another tank of pure argon. Plus I have never welded aluminum let alone cast aluminum... So I was wondering if brazing is a realistic solution to this or would it be prone to cracking and breaking? UIM doesn't see much heat or structural load so I can see this maybe being a possibility. I have MAPP gas torch so it burns hotter than propane but not as hot as Oxy...
I guess also how much would it cost to get a pro to do this (from those that have had welders weld things for them).
My other solution would be to get my friend with a synchrowave TIG to weld it, but he has never welded cast aluminum either (he is good at regular aluminum though)
Or get him to essentially spot weld it and then I can fill in the cracks with Brazing. Just throwing ideas out, let me know your opinions,
Zach
trotterlg
Report this Post08-13-2013 06:36 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry, brass won't stick to aluminum. Larry
daveg
Report this Post08-13-2013 06:43 PM Click Here to See the Profile for davegSend a Private Message to davegEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did this last year with a spare upper intake plenum and paid $350 for a local shop to do the mod.
Dave
Total ratings: 259
Report this Post08-13-2013 06:50 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
You might try alumiweld... its an aluminum compatible brazing rod.
trotterlg
Report this Post08-13-2013 06:53 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have some of that stuff, it does seem to work. Larry
BlackEmrald
Report this Post08-13-2013 07:20 PM Click Here to See the Profile for BlackEmraldSend a Private Message to BlackEmraldEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can't MIG aluminum without a spool gun anyway. I'd be interested to sew where this goes, as brazing is a perfect solution, if a good filler rod is found.
Total ratings: 259
Report this Post08-13-2013 09:38 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sure you can. I have done all my aluminum welding with a ProMig 175 w/o a spool gun, just the $65 aluminum kit (feed wheels, liner, and tips). Now it is tricky to setup and requires focusing on welder and work placement to give the wire the straightest path, but it does work.
tesmith66
Total ratings: 135
Report this Post08-14-2013 07:11 AM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
I use this on aluminum. I get it at the local farm store.
zkhennings
Report this Post08-14-2013 10:41 AM Click Here to See the Profile for zkhenningsSend a Private Message to zkhenningsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yea I was referring to aluminum brazing rods...
So do you guys think it would be strong enough?
And fieroguru I know it is not bad welding aluminum with a Mig, but have you tried cast aluminum? Just wondering what your opinion is on that.
zkhennings
Report this Post08-14-2013 10:43 AM Click Here to See the Profile for zkhenningsSend a Private Message to zkhenningsEdit/Delete MessageReply w/QuoteDirect Link to This Post
zkhennings
Member since Oct 2010
Dave
Thanks for the info!
[This message has been edited by zkhennings (edited 08-14-2013).]
zkhennings
Report this Post08-14-2013 10:46 AM Click Here to See the Profile for zkhenningsSend a Private Message to zkhenningsEdit/Delete MessageReply w/QuoteDirect Link to This Post
zkhennings
How well does it work? It looks interesting, says it is stronger than aluminum and requires no flux
Total ratings: 259
Report this Post08-14-2013 10:58 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did quite a bit of welding on cast aluminum on my 4.3L intake modification. The hard part is gettting all the pores in the cast aluminum clean and free of oxidation.
zkhennings
Report this Post08-14-2013 11:00 AM Click Here to See the Profile for zkhenningsSend a Private Message to zkhenningsEdit/Delete MessageReply w/QuoteDirect Link to This Post
This looks like a promising product
TopNotch
Total ratings: 60
Report this Post08-14-2013 12:27 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have some -- it works great. The only problem is that aluminum is a very good conductor of heat, so your whole piece is going to be very hot by the time you finish the job. I tried repairing a water pump with the stuff, and it worked just fine, except that the bearing seals got too hot and were burned out. But for an intake manifold, it should be fine.
BV MotorSports
Total ratings: 189
Report this Post08-14-2013 01:25 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have used a product called durafix with great success. I have used it when making aluminum hardpipes for intercoolers. It works fantastic!
http://www.durafix.com/
[This message has been edited by BV MotorSports (edited 08-14-2013).]
hiwil88formula
Report this Post08-14-2013 01:29 PM Click Here to See the Profile for hiwil88formulaSend a Private Message to hiwil88formulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had this done a few months back. Cost me $150 at a local shop, even kept the EGR.
zkhennings
Report this Post08-14-2013 01:35 PM Click Here to See the Profile for zkhenningsSend a Private Message to zkhenningsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool! Well that is great to know I can do it for a reasonable amount of money, is there any aluminum in particular I should use to bond better with the cast aluminum? Or will some standard like 1/8 inch sheet aluminum be fine?
mcguiver3
Report this Post08-14-2013 07:03 PM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had a local welder do my intake last year and he charged me $75 to weld it.
I did the prep and fitting of parts.
I did try it myself with a spool gun on my MIG but it was not enough amperage to properly weld the AL.
AL takes a lot of heat to weld and the manifold is thick. Takes a good size MIG to do the job right.
Bob
zkhennings
Report this Post08-15-2013 09:15 AM Click Here to See the Profile for zkhenningsSend a Private Message to zkhenningsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bob
What kind/ sized aluminum did you use for the added material? I am looking at 1/4 aluminum plate but it might be overkill
mcguiver3
Report this Post08-15-2013 11:51 AM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
The first time I did it I cut off the intake snout from the side, blocked off the hole and drilled a 1 1/2" hole in the top of the manifold and welded the TB flange to the top of the upper intake manifold.
The second scenario was to mount a Camaro TB, so I had a 1/2" plate welded to another spare upper intake and drilled out for the air Intake and taped the 4 holes for the mounting screws. Both times the welder charged me $75, but I did all the fitting and setup. All he had to do was weld.
Bob
zkhennings
Report this Post08-19-2013 01:12 PM Click Here to See the Profile for zkhenningsSend a Private Message to zkhenningsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have some of the HT-2000 Brazing rods on the way, I will do this modification in the next few weeks and I will post pics and steps on here.
