  New fuel pump went out 2 weeks after install.
New fuel pump went out 2 weeks after install. by 1987Fiero_GT
Started on: 09-07-2013 06:29 PM
Replies: 18 (1789 views)
Last post by: 1987Fiero_GT on 09-15-2013 11:06 AM
1987Fiero_GT
Report this Post09-07-2013 06:29 PM Click Here to See the Profile for 1987Fiero_GTSend a Private Message to 1987Fiero_GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys!
My fuel pump went out shortly after I bought my 87 Fiero GT. I purchased a new one from "The Fiero Store", dropped the tank and replaced it. Car ran great for two weeks and died on the way to work. I got into things today desperately trying to disprove my worst fears only to determine that the new fuel pump went out on me.
I have a couple of questions before I go and replace this thing again.
1. Has anyone had issues with the FP's sold by the Fiero Store? I think it was an Airtex or something like that.
2. Has anyone run into another issue/component causing fuel pumps to burn up?
I just don't want to make this task a habit!!! All input is greatly appreciated!
Mytime
Report this Post09-07-2013 08:50 PM Click Here to See the Profile for MytimeSend a Private Message to MytimeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm just going to say what others here have said. If you are going to replace the fuel pump, go with AC Delco. From what I've heard here on the forum, you are going to get a more reliable product. Replacing a fuel pump aint a fun job. There are other places to get standard parts like a fuel pump besides TFS. Not that they don't do a great service for us Fiero enthusiasts, there are just other choices of dealers that offer a better variety of products out there.
dudewithoutfiero
Report this Post09-07-2013 09:21 PM Click Here to See the Profile for dudewithoutfieroSend a Private Message to dudewithoutfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
are you sure that the fuel pump went bad? i had a similar thing happen to me and i thought the pump was bad until i dropped the tank and found the fuel line that i used to connect the pump to the metal line had a split in it causing the pressure to bled out and not get enough pressure for the car to run. make sure when you put it all together that you use submersible fuel injection fuel hose, the regular type will not last too long bathed in gas.
css9450
Total ratings: 87
Report this Post09-07-2013 11:10 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
I would agree. The stock Fiero fuel pump is a common item and should be available over the counter at any auto parts store. Many GM cars used the same pump. Autozone has the AC Delco for $79, for example.
Boostdreamer
Total ratings: 98
Report this Post09-08-2013 06:38 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
How is your fuel gauge set? If there is a possibility that you are running the tank too low, you could be causing the pump to suck air. That brings a swift death to fuel pumps. I went through this with my '87. I easily solved it by driving my '86.
Jonathan
My '85 L67 Build Thread
Report this Post09-08-2013 08:47 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
See my Cave, Electric Motors
Bad power and/or ground can kill FP etc
benoitmalenfant
Report this Post09-08-2013 10:17 PM Click Here to See the Profile for benoitmalenfantSend a Private Message to benoitmalenfantEdit/Delete MessageReply w/QuoteDirect Link to This Post
Another thing not mentioned in earlier posts: I hope you also had replaced the strainer, most fuel pump manufacturer won't honor waranty if you can't show proof of purchase of a strainer.
Ben
87 GT / 88 GT
84 Indy #1863
1987Fiero_GT
Report this Post09-09-2013 05:36 PM Click Here to See the Profile for 1987Fiero_GTSend a Private Message to 1987Fiero_GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for all of the input. Here some additional info concerning my troubleshooting efforts.
First off, it ran fine after installation. One day on the way to work it just died. My first step was to check the fuse (good)!
Next step, I swapped the Fuel Pump relay with the AC relay, even though the Oil Pressure switch should have by-passed the relay and pumped gas. Not to mention it should not have died under these circumstances anyways.
Before tearing into it. I checked the plug on the engine side of the firewall and reseated it. No change. Next, I put my ear to the center console and turned on the ign. I heard the pump go thump! And about 2-3 seconds later it thumped again. Indicating to me that the voltage was cycling on and off as designed. Just to be sure, (actually a desparate attempt to prove myself wrong) I fed 12v from the battery to terminal G on the ALCL. No help!!
I then checked the ground wire under the console in front of the ECM. "SOLID" connection.
I dropped the tank (Full) and put it up on my work table and "CAREFULLY" connected a ground and a hot wire to the sending unit wires, thereby by-passing all wiring/connections in the vehicle. Same result, thump-thump.
I disconnected the leads and removed the and removed the sending unit to make a visual inspection. Looked as good as it did two weeks prior.
So there you have it. So, before I install another one I wanted to get input from you good people. I guess I'll go with an AC Delco and also make some voltage and wiring checks before reinstalling the tank.
Thanks to OGRE for ref his page. I'll be looking at some of the specs and info there as I complete another fuel pump replacement.
Regards,
Jeff
P.S. Yes, strainer too!
[This message has been edited by 1987Fiero_GT (edited 09-09-2013).]
TopNotch
Total ratings: 60
Report this Post09-09-2013 05:43 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been ruinning Bosch pumps in two Fieros (one a 4, and one a 6), for a while, with no problems. I got them at a Napa store.
1987Fiero_GT
Report this Post09-09-2013 05:53 PM Click Here to See the Profile for 1987Fiero_GTSend a Private Message to 1987Fiero_GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Top!
ytzman
Report this Post09-09-2013 06:33 PM Click Here to See the Profile for ytzmanSend a Private Message to ytzmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
My first suggestion is you probably just got a bumb pump. These things happen and a more expensive pump does not guarantee this wont happen again, but I always recommend quality over price, they usually work better and longer.
It's too bad your tank is full, other wise I would suggest power washing the inside of the tank and filling with fresh fuel.
Ford tech hotline had suggested that particle from the original pump failure could be floating around in the fuel causing mulyiple failures. (Still waiting to see if the 3rd one fails in the next couple weeks)
Good luck, let us know how it turns out.
jaskispyder
Total ratings: 205
Report this Post09-10-2013 09:47 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
yup, bosch pump here.
dratts
Total ratings: 118
Report this Post09-10-2013 12:16 PM Click Here to See the Profile for drattsSend a Private Message to drattsEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's two weeks longer than I got on my first replacement. I was so mad. I hate laying under the car breathing gas fumes. Took it back and the next one worked. Parts stores should have to pay for your labor when they sell you a bad part that you have to replace again.
samt
Report this Post09-10-2013 12:59 PM Click Here to See the Profile for samtSend a Private Message to samtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have had a Bosch pump running for over four years in a daily driver..very quiet....can't even hear it....that pump whine drives me nuts
imabuzzkill
Report this Post09-10-2013 01:07 PM Click Here to See the Profile for imabuzzkillSend a Private Message to imabuzzkillEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have about 3 months on a cheapo fuel pump/sender in my K5 Blazer and it just crapped out Sat. Can't wait to drop that 31 gallon tank/skid plate that is full!
I also got 6 months off my tie rod ends on my Buick-China crap!
Life sucks.....
kikinz24
Report this Post09-10-2013 02:57 PM Click Here to See the Profile for kikinz24Send a Private Message to kikinz24Edit/Delete MessageReply w/QuoteDirect Link to This Post
I personally went through 3 airtex pumps in a 99 blazer in the coarse of 2 months finally last time I pulled it they let me just pay the difference for a bosch pump and I never had a problem after that.. last time I ever took the "cheap" route for a fuel pump
samt
Report this Post09-10-2013 03:14 PM Click Here to See the Profile for samtSend a Private Message to samtEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've had problems with Airtex and Carter...Airtex died after about a year...Carter shorted... would run then not run always on restart.took it out and the contacts were black..went to Bosch and no probs....easy to find priced good....Fiero Store? never had anything to brag about in the way of parts from them...maybe just my bad luck?
Total ratings: 465
Report this Post09-10-2013 03:26 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I guess I'll go with an AC Delco...
Be careful.
Should I be ticked off that the fuel pump I received is not what I ordered?
1987Fiero_GT
Report this Post09-15-2013 11:06 AM Click Here to See the Profile for 1987Fiero_GTSend a Private Message to 1987Fiero_GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
After letting the car sit for a week while I made up my mind about the next fuel pump I install, I decided to go with a "Known" American made part. That was a Carter sold at Napa. I was surprised that it was only $51 + tax. The car runs perfect!
Hopefully I won't have to do this again any time soon!
Thanks Guys!!!
