  AR electronic cruise control wiring question (Page 2)
AR electronic cruise control wiring question by Curtisk1060
Started on: 09-10-2013 01:17 PM
Replies: 41 (2699 views)
Last post by: jelly2m8 on 06-25-2023 02:16 AM
VanGTP5000
Report this Post03-25-2018 04:30 PM Click Here to See the Profile for VanGTP5000Send a Private Message to VanGTP5000Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had the chance to pull the Cruise Inhibit signal wire Pin H from the plug as a test to see if leaving it "open" would solve my problem. It didn't. I tried both the "FH" servo and the "AR" servo. Neither one would engage at over 40 mph. All pins test positively as I cycle through the functions on the cruise stalk and brake pedal.
-Van
[This message has been edited by VanGTP5000 (edited 03-27-2018).]
jelly2m8
Total ratings: 243
Report this Post06-25-2023 02:16 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Didn't know what tread to put this in, but I wanted to Affirm I got an AR labelled Cruise Servo to work successively. It's on a 3800 swap, it's wired Via Darth's instructions on his site with the 5 post relay and by grounding the Cruise inhibit wire. Works flawlessly, better and more precise than the OEM Vacuum module.
I tried the AB labelled module that came from my original donor and nothing, purchased a AR module yard marked as ' 98 Lumina' plugged that in and insta worked
[This message has been edited by jelly2m8 (edited 06-25-2023).]
