  Winter storage - gas tank - full or empty?
Winter storage - gas tank - full or empty? by Fierotoyboy
Started on: 09-20-2013 10:00 AM
Replies: 9 (2420 views)
Last post by: James Bond 007 on 09-22-2013 11:05 AM
Fierotoyboy
Report this Post09-20-2013 10:00 AM Click Here to See the Profile for FierotoyboySend a Private Message to FierotoyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm embarrassed to ask this, but I have heard differing opinions.
I put Stabil in my tank before putting my Fiero to bed for the Winter. Should I run the tank low on fuel so there's less gas to go bad or fill it? If I should fill it, how much Stabil should I add?
Thanks!
Old Lar
Total ratings: 214
Report this Post09-20-2013 10:09 AM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd keep it full to prevent moisture condensation which after setting can rust the inside of the tank.. You may want to add some gas antifreeze to the tank to "absorb" some of any moisture along with the Stabil for ethanol fuels.
lateFormula
Report this Post09-20-2013 10:46 AM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
On the day you plan to put the car away for winter go to your local gas station. Take a long narrow funnel and a bottle of Stabil. Remove gas cap, insert funnel, add 5 ounces of Stabil, remove funnel, fill gas tank. Take car to wherever it will be stored, change the oil+filter and it is now ready to sit for the winter.
Kevin87FieroGT
Report this Post09-20-2013 04:58 PM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Clean it up. Fill the tank full...use Stabil. Fresh oil and filter, drive 10 miles, then store.
Lou6t4gto
Report this Post09-21-2013 01:25 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
YES, Tank Full w/ "Stabil". I usually disconnect a vacuum line and put it in some Light Weight Oil, let the car run until it's puffing a little smoke, then shut it off. This puts an oily "Film" on the rings, cylinder walls, valves, & guides. it can sit for a VERY long time that way. If Parked on concrete, put it up on jack stands to prevent flat spots on tires.
Report this Post09-21-2013 02:19 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Parked on ground/grass can rot the tires and is illegal in many areas.
Whatever chemicals in the dirt/grass affect rubber life.
tebailey
Report this Post09-21-2013 02:28 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can't say enough about sta-bil. I've had mine sit through the winters for the past 4yrs, and it's always started right up and ran great every spring.
Report this Post09-21-2013 06:32 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Agree with putting in Stabil, but todays gasoline, at least in this area is already 10% alcohol. Gasoline anti-freeze is basically methyl alcohol. I am not certain that there is a need for more alcohol in the gas so I will simply, ask is more alcohol better?
rogergarrison
Total ratings: 551
Report this Post09-21-2013 06:36 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
In my case first, I never let a vehicle set without driving at least around the block every few weeks. ' IF ' I do have to set a car all winter, I run it till its out of gas and quits. Then I pour in just a few gallons of gas with Stabil added and just crank it till it restarts, runs a minute and shut it back off. Im done. Worked fine for 30 years. Last thing I want in spring is fighting with a car and a tankful of bad gas. Another reason not to park your car on gravel or grass for extended time is it causes massive chassis rust...especially if you use a car cover. Ive never had a gas tank rust inside except when it had lots of gas left in it. Empty tanks dont rust inside...only the outside. I leave the steel gas cans for my lawn equipment empty all winter...yet to see any rust inside them. Just my opinion, do what you feel.
just to add, most newer cars all have plastic gas tanks that never will rust
[This message has been edited by rogergarrison (edited 09-22-2013).]
James Bond 007
Total ratings: 263
Report this Post09-22-2013 11:05 AM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
I agree, a full tank is Good, and an added bonus would be Stabil (both would be best). If you have time,save this link (below) and read it at your leisure.
https://www.fiero.nl/forum/Forum1/HTML/088012.html
