  quick alternator wiring question
quick alternator wiring question by scott0999
Started on: 09-21-2013 11:31 AM
Replies: 1 (159 views)
Last post by: phonedawgz on 09-21-2013 06:52 PM
scott0999
Report this Post09-21-2013 11:31 AM Click Here to See the Profile for scott0999Send a Private Message to scott0999Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 86 GT that I'm doing a 3400 swap on, using an alternator from Achieva 3.3L
the connector has the big red wire, brown, and brown/white stripe
I'm assuming the brown/white isn't used right? then just connect the others to match. just need to make sure its that easy or not
thanks
Total ratings: 291
Report this Post09-21-2013 06:52 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
CS130
Read the paragraph in The Orgre's cave about CS alternator wiring - "Wiring WARNING! There are two major variations of the CS power regulator! If you are not 100% sure which one you have in your hand then don't hook up anything to Terminal I/F."
http://home.comcast.net/~fierocave/cs130.htm
88 Fieros with the CS130 used three wires of those colors.
[This message has been edited by phonedawgz (edited 09-21-2013).]
