  Slave cylinder air leak due to worn or stripped bleeder valve threads clutch bleeding
Slave cylinder air leak due to worn or stripped bleeder valve threads clutch bleeding by Amida
Started on: 09-25-2013 02:19 PM
Replies: 3 (1165 views)
Last post by: Spoon on 09-25-2013 11:35 PM
Amida
Total ratings: 63
Report this Post09-25-2013 02:19 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
FYI: During the clutch bleeding procedure if your clutch system stays soft and spongy and you always find air in the slave cylinder after several attempts at bleeding then you may need to check the bleeder valve seats for pitting/dirt and the threads in the slave cylinder for stripping. While bleeding my system I discovered that the bleeder valve threads in the slave cylinder were giving way & stripping which failed to provide enough pressure to make a tight seal at the valve. New slave cylinder on order from RodneyDickman.com .
[This message has been edited by Amida (edited 09-25-2013).]
trotterlg
Report this Post09-25-2013 04:16 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the valve won't tighten down I can see you would have a problem, but it does not seal on the threads, it seals by closing off a hole in the bottom, so loose threads have nothing to do with leaks. Larry
Amida
Total ratings: 63
Report this Post09-25-2013 04:29 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Correct, valve threads were stripping away and eventually would not tighten anymore.
Spoon
Total ratings: 61
Report this Post09-25-2013 11:35 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had that same problem about 6 years ago. The ball end of the bleeder had pitted. I polished it up and the pedals been hard ever since.
Spoon
