  Flat heat shield between front exhaust manifold and head.
Flat heat shield between front exhaust manifold and head. by jimmo
Started on: 09-28-2013 10:46 AM
Replies: 10 (1156 views)
Last post by: Arns85GT on 09-29-2013 04:51 PM
jimmo
Report this Post09-28-2013 10:46 AM Click Here to See the Profile for jimmoSend a Private Message to jimmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just removed my front exhaust manifold to weld it up. I want to reinstall it without the flat heat shield between it and the head. Has anyone left it out without problems?? The car is an 86 gt 2.8 (stock) no cat converter. I dont want to have a gasket on both sides of the shield. I feel thats why my manifold bolts were probably loose when removing it and its likely to happen again.
hiwil88formula
Report this Post09-28-2013 11:35 AM Click Here to See the Profile for hiwil88formulaSend a Private Message to hiwil88formulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I left mine off and have it had any issues.
Report this Post09-28-2013 11:56 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's not the way it's supposed to be done. There is NO gasket installed between the heat shield and the head. The gasket goes between the heat shield and the exhaust manifold.
Report this Post09-28-2013 12:17 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Both my engines only have one gasket and it's between the head and heat shield. One of the engines is original, so I assume that was a factory install. 87 engine, so there was no recall on it.
Total ratings: 463
Report this Post09-28-2013 12:35 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I left mine off when I did my engine swap.
Mine had been installed flat against the head, with the gasket next, and then the manifold.
(If you look at the shield, you can probably tell how it was installed. Different surfaces will leave different "indentions" on the shield.)
Having said all that...
If you're running "catless", I'd leave the shield off.
It was installed to keep vital fluids off of the cat, in the event of a violent engine failure, and "ventilated" block.
[This message has been edited by Raydar (edited 09-28-2013).]
Report this Post09-28-2013 12:45 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Both of your engines must've been built on a Monday morning or Friday afternoon.
Report this Post09-28-2013 01:04 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
One gasket only, between manifold and shield.
Per Recall 88-C-24
http://www.fieronews.net/fusion/downloads.php
Shield is to keep leaking oil off of exhaust manifold.
jimmo
Report this Post09-28-2013 01:15 PM Click Here to See the Profile for jimmoSend a Private Message to jimmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks a lot guys. I was just assuming it took 2 gaskets. My original gasket was shot and mostly gone so I couldnt tell if there was only one or two. Im gonna leave the shield off.
Report this Post09-28-2013 06:35 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 3.4 was done by one of our mechanics, the 2.8 was a factory engine. Guess so.
PatrickTRoof
Report this Post09-29-2013 12:16 AM Click Here to See the Profile for PatrickTRoofSend a Private Message to PatrickTRoofEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dang, I can't remember if I put the heat shield next to the block when I put mine back together. Now it's gonna bug me until I can go check.
Arns85GT
Total ratings: 202
Report this Post09-29-2013 04:51 PM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
That shield is intended to keep any breakage or oil away from the CAT. I found that re-assembly brought vacuum leaks with it so I deleted it. Better seal, and, no, no broken parts or sprays of oil, and........ (no CAT)
Arn
