  Is it ok to use RTV instead of gasket for oil pan? (86 2.5L notchie)
Is it ok to use RTV instead of gasket for oil pan? (86 2.5L notchie) by Jdlog
Started on: 10-04-2013 04:54 PM
Replies: 16 (5186 views)
Last post by: Raydar on 10-06-2013 02:49 PM
Jdlog
Report this Post10-04-2013 04:54 PM Click Here to See the Profile for JdlogSend a Private Message to JdlogEdit/Delete MessageReply w/QuoteDirect Link to This Post
Long story. I usually do my Fiero's fixing myself but, for now, I can't.
A mechanic was given instructions and the proper parts to install a new oil pan gasket.
I just picked up the car and found the new gasket still in its box. The mechanic said that it was better to use RTV, which is what he did.
Is this kosher or I am going to have car issues because of this?
NetCam
Report this Post10-04-2013 05:05 PM Click Here to See the Profile for NetCamClick Here to visit NetCam's HomePageSend a Private Message to NetCamEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well it can be done, but that doesn't mean it should be done. If done properly, a good bead of RTV will seal the oil pan, but personally I've always used both. You could very well have this last you years, but if he didn't do a good job you could have a leak in days, weeks or months. Make sure you keep your receipt.
trotterlg
Report this Post10-04-2013 10:36 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it were better to use RTV the factory would have done it and saved a dollar. Is it leaking yet? Larry
Arns85GT
Total ratings: 202
Report this Post10-04-2013 10:53 PM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a friend who is a GM mechanic. He told me he much prefers RTV over a gasket
When I tried it, I torqued the bolts too soon before it had set up hard, and got a leak. When I used a cork gasket I over-torqued the cork and got a leak.
Lesson being, if you don't know exactly what you are doing, you get a leak, and if you do know what you are doing you won't regardless of the method.
I'd hang on to my receipt and run it a few days. Don't panic it is likely ok
Arn
Lou6t4gto
Report this Post10-05-2013 12:15 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Been using RTV instead of gasket for Years. never a leak.
Kitskaboodle
Report this Post10-05-2013 12:34 AM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I think of RTV I think of Permatex"Form-A-Gasket". Personally, I have only used it for low heat applications like rear end covers. Using RTV around hot oil, tranny fluid and antifreeze would make me nervous. If it were me I would have insisted they use a quality oil pan gasket like the newer Fel-Pro blue rubber ones. (even if I had to pay the mechanic extra) Like my dad always says, "There is never enough time to do it right but there's always enough time to do it over".
Kit
hercimer01
Report this Post10-05-2013 01:29 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
88 dukes don't even have an oil pan gasket as an option.
88 Coupe under construction
84fiero123
Total ratings: 325
Report this Post10-05-2013 07:33 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
depends on the type of RTV you use as well, remember they are all different kinds and colors, those colors usually correspond to what the RTV is good for. Oil, water, gas, tamps you name it they got a different one for it, I like the copper colored one. been using it for decades on everything from differentials to oil pans.
but unless used properly, RTV or Gaskets, even both together can fail.
Steve
[This message has been edited by 84fiero123 (edited 10-05-2013).]
rogergarrison
Total ratings: 551
Report this Post10-05-2013 10:56 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Newer cars dont have many gaskets. Working on my Sebring, even the valve covers, oil pan, trans pan and everything else Ive taken off ONLY has RTV and no gasket. It dont leak a drop of anything on garage floor.
smartaxel
Total ratings: 83
Report this Post10-05-2013 11:41 AM Click Here to See the Profile for smartaxelClick Here to visit smartaxel's HomePageSend a Private Message to smartaxelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mitsubishi 3000gt vehicles were factory RTV on the oil pan. No gaskets at all. Granted those cars were designed to use RTV from the factory, however, If done properly, yours likely won't leak. Personally, though, I think I'd have a problem if the mechanic didn't install as we'd agreed (Eg. using your gaskets).
Zac88GT
Report this Post10-05-2013 12:37 PM Click Here to See the Profile for Zac88GTClick Here to visit Zac88GT's HomePageSend a Private Message to Zac88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not necessarily. The Northstar came with gaskets from the factory and then they put out a TSB saying throw them away and use RTV instead.
Dodgerunner
Total ratings: 323
Report this Post10-05-2013 12:54 PM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have always found the success is in the prep. RTV usually does not fail itself its the bond between the rtv and the surface.
If you get the surface oil free so it can bond then you can have good success.
I wipe the surface with lacquer thinner several times and have had very good luck with all my rtv.
Jdlog
Report this Post10-05-2013 05:54 PM Click Here to See the Profile for JdlogSend a Private Message to JdlogEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the feedback folks! It appears like I'll just have to watch things in case the RTV was not the right one or was improperly done. So far so good; the oil pan is holding well.
I still do have one remaining minor oil leak. When I picked up the car, the mechanic told me that he could not find the oil pressure sending unit, which had begun to leak a little. I can take care of this when I get the part, which I just ordered. It is one of those large ones that drives the oil pressure guage, not just the oil "too late" warning lamp.
Not having pulled one from an iDuke before, that I remember, I do wonder if I need to drain some oil in order to replace it.
[This message has been edited by Jdlog (edited 10-05-2013).]
Blacktree
Total ratings: 350
Report this Post10-05-2013 06:21 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I personally prefer to use RTV silicone on oil pans, because the oil pan gasket can be a PITA to deal with.
Like mentioned above, as long as the mechanic didn't mess it up, it'll be fine.
edit to add: You don't need to drain any oil to replace the oil pressure sender.
[This message has been edited by Blacktree (edited 10-05-2013).]
TopNotch
Total ratings: 60
Report this Post10-05-2013 09:56 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
And the Helms manual specifies RTV -- it even tells you what size bead to lay down.
84fiero123
Total ratings: 325
Report this Post10-06-2013 09:41 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Manuals can and do have mistakes, maybe not in this case but I have found them in just about every one I have ever read.
example when I changed the engine on my 86 Suburban the manual said to turn the oil pump a certain way to prelube the engine before start up for a new engine. I forget what the manual said but it the opposite defection clockwise or counterclockwise.
that was one manual, think it was Haynes but it has been over 20 years so I could be wrong. found similar mistakes in Motors, Chilton, and others, never the same mistake but they all can have mistakes in them. so don't be fooled and always double check when you aren't absolutely positive about something, think here or another manual.
Steve
Total ratings: 463
Report this Post10-06-2013 02:49 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by 84fiero123:
Manuals can and do have mistakes ...
Off topic...
The "engine" section of the 88 Helm (factory) manual for the Fiero says that the exhaust manifolds are "cast nodular iron".
