  Alternator pulley sizes seem to vary in diameter, which caused a problem....
Alternator pulley sizes seem to vary in diameter, which caused a problem.... by Patrick
Started on: 10-06-2013 02:48 AM
Replies: 5 (1171 views)
Last post by: Patrick on 10-09-2013 03:31 AM
Report this Post10-06-2013 02:48 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I got my '86 GT several years ago, I soon got sick of the alternator belt squealing everytime it rained. Sure, I could tighten the belt, but that was always a temporary repair as two weeks later it would squeal again. I bought Dodgerunner's auto belt tensioner and was very happy with it. Solved the problem completely. The belt never squealed again.
Fast-forward... and a month or so ago I acquired an '88 Formula. I want to sell the 86 GT, so I figured I'd transfer the belt tensioner over to the Formula. I noticed the pulley on the Formula's alternator had an extra rib, but after researching here, I learned that installing the belt towards the inner ribs on the alternator would work fine in regards to belt alignment.
However, I noticed something just didn't seem right when I installed the alternator belt on the Formula. It seemed like the auto tensioner pulley was closer to the crank pulley than what I remembered on the GT. There was very little space between the two pulleys. It was almost like the belt was now too long.
And then a couple weeks later, the belt started squealing! What the heck...!
Anyway, to make a long story short, I discovered that not only was there an extra rib on the Formula's alternator pulley, but also that the diameter of the Formula's pulley was smaller (2 3/8") than the one on the GT (2 5/8").
These pictures will show the difference.
The top pulley is flipped over so that the pulleys are sitting outer end to outer end.
I now have a larger pulley installed (taken off a junk alternator I had sitting around) with the correct number of ribs. The larger alternator pulley will result in less drag on the engine (alternator still charges just fine, even at idle), and the replacement pulley is much lighter as well. (Different type of construction.) It was a win-win situation to replace this pulley.
And the belt doesn't squeal anymore!
Report this Post10-06-2013 02:58 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Small pulley has less belt contact and makes Alt RPM higher.
Yes, I've said in past that squealing belts are symptom of other problem.
Wrong alt pulley is one.
Report this Post10-06-2013 03:07 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thought I should post this image from Dodgerunner's thread to show how the belt tensioner is installed on a 2.8 and why it would be a problem to have the tensioner pulley arm rotated too close to the crank pulley. (The auto belt tensioner would be at the end of its travel and no longer able to take up the slack of the belt.)
[This message has been edited by Patrick (edited 10-06-2013).]
Report this Post10-06-2013 08:18 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've frequently found that aftermarket alternators for a particular application will have a different pulley. I guess it's because the alternator is used on a number of vehicles. My wife's Grand Am went through at least a half-dozen alternators in it's 300K mile lifetime. They should have had 5-rib pulleys, but most came with a 4-rib pulley. Even with the correct number of ribs, the pulleys also varied in diameter. Usually smaller than the original. After I learned about the differences, I just had the parts store swap pulleys before I left the store.
Total ratings: 463
Report this Post10-06-2013 02:09 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
In the pics that you posted, the smaller pulley is one that I usually see installed on 4 cylinder alternators. The larger one is installed on the V6 alternators.
Talking specifically about 88 Fieros.
Report this Post10-09-2013 03:31 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Raydar:
...the smaller pulley is one that I usually see installed on 4 cylinder alternators. The larger one is installed on the V6 alternators.
Yes, the alternator on the Formula is a rebuilt one (I can tell by the label on it), so I guess that explains why the wrong pulley was on it.
Ya can't assume anything is correct these days!
